Results 1 to 23 of 23
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    How long did your front and rear rotors last?
    Just curious. I'm at 32K miles and have only replaced the front pads so far (at 19K miles). Just purchased sets of front and rear pads and plan to have them replaced next week but not certain if rotors will need to be as well. I like buying my own parts, replacing myself when I can or having a reputable shop do so. Should I have rotors ready to go just in case?
    Last edited by piotrowr; 01-17-2014 at 09:59 AM. Reason: Found out front pads actually changed at 19K miles
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    I replaced my pads and rotors at 35k miles. Rotors probably still had a little life in them, but were nearing the spec for replacing so I just did everything at the same time. Pads still had some life as well, but I couldn't stand the brake dust.
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    Your pads only lasted 18k???
    Or did you just decide to upgrade or something?
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    I am at 33k miles and the rotors and pads are in great shape.
    Jul 18 2008
    Scottsdale
    Quote Originally Posted by dennisA4 View Post
    Yes, according to the dealership, when I had it in to check issue with hood latch, they said the front pads are about done. Probably a couple thousand miles early since I had not gotten any warnings but decided to get them done at that time anyway.
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    44k pads and rotors fine but planning to get Adams rotors and Akeobon pads soon together with ss lines.
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Jan 06 2013
    MidWest
    58K and still going. I hope to make it to 65K on original set. Will see...
    Established Member Two Rings markinarch's Avatar
    Apr 17 2011
    2008 Rav4 Limited
    San Antonio
    42000 and pads and rotors are still in great shape!
    2011 A4 Quattro Premium Plus. Teak Brown. 8 Speed. Chrome Grille Strips and Fogs. EC Turbo Inlet. EC HFIC. VAG Mods. PlastiDip Grille and Valence
    Jul 18 2008
    Scottsdale
    Okay it sounds like the rotors are still fine but how I went through the front pads in 19K miles when most here seem to be 2-3X that is surprising.
    Veteran Member Three Rings OB1's Avatar
    Jun 25 2010
    Baltimore
    55k and pads are great. Rotors are starting to get a little warping, but staying strong!
    '12 MG A4 Avant
    Jan 13 2006
    Houston
    Quote Originally Posted by piotrowr View Post
    You said your stealership told you the pads were about done.
    If that doesn't throw up a red flag that answers your question, I don't know what does. ;)
    Unless your tracking your car or something, pads should last a minimum of 30k, if not 50k or more depending on driving style.
    And same with rotors… unless defective or under a lot of stress, they should last much longer.
    Aug 03 2010
    Northern NJ
    When I sold the 2009 A4, it had 46kish on it and the brakes were fine. The rear pads had plenty of material left. The fronts were around 7mm, or "fair" category. They likely had about another 5-10k left on them.
    Driving behavior has a lot to do with how long brakes last. Most of the mileage on my car is not easy highway driving, but I don't slam on the brakes all that often. Slow and steady acceleration and stopping (anticipating and coasting down to a stop) will increase the life of the parts and increases fuel economy. The owner's manual will back this up.
    The Nice Car:
    2018 Ibis White Audi A4 quattro 2.0T - Have HEX+CAN VCDS, PM Me
    The Hoopty Beater: SOLD
    1987 Alpine White Audi 4000cs quattro "special build"
    Veteran Member Three Rings Fburg A4's Avatar
    Oct 06 2012
    Fredericksburg, VA
    could be a sign that something is wrong with the braking system if the pads wore out that fast. or it could be driving style. whole bunch of reasons pads can wear out faster for one driver compared to another. or your pads were not near the limit and the dealer pilfered your wallet.
    as far as the rotors are concerned, there are wear limits specified for the rotor. you can measure your rotor and see how close you are to the limits.
    Veteran Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Q5 3.0T
    at 55k and its all still good. when i went to a dealer for squeaky brakes, they said it might be time to replace the brake pads. I went to another to inspect them, they said I still have 80% pad left. so you might be getting canned
    2010 A4 quattro, Tiptronic, Ibis White
    Jul 18 2008
    Scottsdale
    Well to be honest I trust my dealer quite a bit. They have taken care of me on many occasions with other issues, far and beyond what I've read with others experience with theirs on these forums. My driving habits are not very aggressive but that's relative I suppose. I don't see (so far) anyone getting close to the low pad life I had. I'll keep monitoring the forum but also check with my service rep as to reasons, besides driving habit, why my pads only lasted 19K miles. Thanks for the feedback.
    Established Member Two Rings TylerG's Avatar
    Apr 02 2013
    United States
    i need new breaks and rotors, anyone have any recommendations? budget is around 3-400 (is that too much? haha)
    2010 Ibis White Audi A4 B8 Quattro Premium+ S-Line w/ Nav
    Dec 01 2011
    ^^ check rockauto.com they have good cheap parts. yes 3-400 is enough, 300 is more like what you'd spend on front and rear, for rotors and brake pads.
    and i replaced my OEM pads at 55k and have been on posiquiet ceramic ones since and they are still ok, been 20k miles since and should last at least another 20k or so. i still have my original rotors and car has 75k miles. but im planning on changing rotors next time i do pads. the general guideline is to replace rotors every other brake pad change, thats usually how long they'll last and recommended to change.
    IG @theshawon
    Established Member Two Rings JS + MS3's Avatar
    Jan 31 2010
    LA/CA/USA
    Quote Originally Posted by TylerG View Post
    I recommend Cancun.
    That place is amazing for spring break.
    It's like Disneyland for guys in 20s.
    Senior Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    My brake pad sensor came on last week at 52k. I'll replace all four corners, both rotors and pads. Leaning toward Akebono ceramic pads, and Stoptech slotted rotors.
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage II, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. RS 5 pedals. Apikol rear diff kit. Vag.com mods. Stoptech slotted rotors, Akebono pads. Interior LEDs, BFI heavyweight knob, CF trim. BC BR coils. P3 Guage. ECS SS brake lines, 10/15 spacers. CR 15 brace. USP HFC.
    Veteran Member Three Rings 98A4TurboAWD's Avatar
    Jan 06 2013
    Charleston, SC
    1 of 2 things:
    1, They are lying and the pads are fine. You can easily confirm this by taking a minute to look at the pad.
    2, there is something wrong with your brakes. Maybe a caliper is stuck or the rotor is damaged and causing premature wear to the pad.
    2018 Audi S4 3.0t - EPL Stage 1 93
    09 Audi A4 2.0t Quattro - Automatic - CTS K04 - ECS HFC & 3" downpipe - Integrated Engineering K04 93 Octane Tune - K&N Filter - S Line 19" Peelers - H&R Sport Springs
    98 Audi A4 1.8t Quattro - Stock - Automatic - AEB
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    66k miles on original pads and rotors here.
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    Senior Member Three Rings Celiot29's Avatar
    Jul 17 2012
    boston ma
    Im a Bit surprised they are not investigating the fact that they went so quickly, especially since you dont track it, but they see a lot of,cars maybe its not out of the ordinary. I got 70k out of the front pads and rotars and still hadn't changed my original rear pads and rotors by the time I traded it in with 97k minor warp going on past 60k on fronts
    2013 Audi A4 Quattro brilliant black | light pckg | convenience pckg | 35% all around | RS4 grille | S4 trunk lid | S Line rear valence
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    My 09 avant had over 50th after replacing front pads at 89 rears are still fine. You were screwed:)
