Hi All,
2006 A4 Audi 2.0T FSI 2WD.
I know this thread has been used many times, but all I can find is ones blaming the PCV. I recently replaced that with a 034 motorsport catch can, draining the oil to the turbo oil pan.
I also have recently replaced the valve cover and valve cover gasket. My valve cover had turned to junk and had a loose panel, letting a large amount of oil in.
Problem: I noticed an excessive amount of oil around the oil cap and around the valve cover. It had drenched the bottom of it. I know you're not supposed to, but I opened the oil filler while running and it didn't falter at all at idle. No idea why? I hear it is supposed to.
It appears that whatever the problem is continues to ruin the valve cover gasket and leak into the spark well plugs, causing a bad smell.
Even weirder, the car runs great. Boost feels pretty good, but I'm thinking about hooking up a boost to get a reading.
Think it could be related to the Camshaft/HPFP/Cam follower issues?
Any ideas? Thanks in advance!
Best,
Mark
