Results 1 to 24 of 24
    Established Member Two Rings heffer's Avatar
    Apr 22 2010
    Idaho
    Center Brake Light or 3rd Brake Light Problem
    So starting Friday night I went to leave a restaurant and I started my car and my dash had a light come on saying center brake light. I had my wife look and she said it was out. When I got home I had her look again and she said it was back on. I didn't have any problems Saturday or Sunday. But when I got in my car to leave work today it went out again. I got home and researched and didn't come up with much. I just started my car and it is working fine again. Has anyone else had this issue? I'm considering replacing the light, but I don't want to waste $50 if I don't need to.
    2009 A4 Quattro 2.0T Stock
    1999 1.8t/APR Stage 1/Supersprint Exhaust/APR R1 SOLD
    Junior Member One Ring
    Oct 11 2013
    location
    I've been having the same issue, but very intermittently. Centere brake light fails and illuminates warning on the dash, then the next time I start up it's working again. Is the entire light fixture $50 or is that the light cost?
    Senior Member Three Rings ramellis65's Avatar
    Oct 18 2007
    New Jersey
    Same shit here it can come on a couple times in one day and then never for a week and then back on for two days and off its stupid and the dealer was like everything check out so its one of those things you just deal with it. Its $150 for that rear center top light
    Apr 22 2010
    Idaho
    http://genuineaudiparts.com/parts/20...iagram=1399962
    It's some what nice to know I'm not the only one. $44 plus shipping. It's just the light but my guess is that's the issue.
    Active Member Two Rings Leaudi's Avatar
    Sep 25 2012
    Chicago/IL
    I had mine do the same thing. I had noticed that it was only when I left the car outside, where the sun would hit the center brake light. I guess it would over heat it or something. Took the car to the dealer because it was getting annoying having the brake light out every other day, they couldnt do anything unless the light was out. I left the car to get the oil consumption test, and by luck the light was out when they started doing the oil test. Car was still under warranty, they replaced the center brake light saying it was faulty. And yes it was about 150$ which I saved.
    RS 4 grill, Afe Pro Dry Filter, Slotted/drilled rotors and red stuff brakes, R8 coil packs with NGK Iridium spark plugs.
    Added close to 40k miles in one year!
    Apr 22 2010
    Idaho
    I'm guessing that fixed it though?
    Established Member Two Rings holyShred24's Avatar
    Oct 28 2013
    Norfolk, VA
    I have the same exact thing but i know for a fact that mine still works even though the dashboard warning light is saying its out. Doest really bug me anymore as long as i know its working. When i talked to the dealership they said one or two bulbs out of the whole led string might be out or acting up thats sending a fault signal saying its out.
    Veteran Member Three Rings Sin_city_Rings's Avatar
    May 09 2009
    Washington, DC
    Same issue here…. seems its a bigger wide spread issue than just me.
    2008 Deep Sea Blue S5 6MT
    PAST: '12 A4, '08 A5, '09 Sline A4, '07 Sline A4
    Established Member Two Rings markinarch's Avatar
    Apr 17 2011
    2008 Rav4 Limited
    San Antonio
    Same issue and just had it fixed Monday. They did replace the light but the cause they wrote on the service sheet said something like "faulty LED harness" or something like that. I'll see what it says when I get home after work and post it here.
    2011 A4 Quattro Premium Plus. Teak Brown. 8 Speed. Chrome Grille Strips and Fogs. EC Turbo Inlet. EC HFIC. VAG Mods. PlastiDip Grille and Valence
    Apr 22 2010
    Idaho
    Dang, not sure how to replace the harness
    Apr 17 2011
    2008 Rav4 Limited
    San Antonio
    Quote Originally Posted by heffer View Post
    Well that may not be exactly what it is. There were so many things I had fixed Monday I can't remember the exact cause of that issue. I do remember I was taken by surprise when I read the cause bc I was just expecting it to say "bulb out".... I'll post it later so don't worry just yet.
    Oct 28 2013
    Norfolk, VA
    Im getting mine looked at next wednesday. I figured im going there to get my cats checked might as well have em check my brake light. Hoping for free stuff since im still under warranty.
    Apr 17 2011
    2008 Rav4 Limited
    San Antonio
    Alright. So it looks like you just need to replace the entire brake light assemble. My service sheet states the following:
    Concern: Customer states - center brake light inop - indicator comes on intermittenly
    Cause: High mount brake light assembly faulty LED circuit proper voltage and ground circuit available.
    Correction: replaced high mount brake light
    Tech notes: high mount brake light assembly faulty LED circuit; 12.7 volts per side correct and ground circuit 0.1V correct into assembly failure internal
    Part# VWN 8K5945097
    Hope this helps!!
    Oh and I also noticed today that all my VAG coding was erased. No more needle sweep, ambient lighting, DRL always on, key fob window controls... sad day. Now I need to find someone with a cable I can borrow. :(
    Apr 22 2010
    Idaho
    Thanks for your help markinarch!
    Established Member Two Rings hoodis's Avatar
    Feb 10 2011
    2011 Specialized FSR Comp EVO, 2004 Balfa DH 2Step, 2011 Moment Jaguar Sharks 180cm
    Palo Alto, CA
    Have the same problem, beyond warranty now.
    Goes off and on. If you actually press on the top of the car you can get it to reactivate when it's out, and the guy at 034M had seen it before.
    The part is $44, but any idea of installation costs? Is it a difficult thing to access and service?
    2011 A4 2.0T: Quattro 6MT, Ibis White on Black Titanium Sport Package. Aftermarket: JHM K04r, APR Stage 2 93 octane, STASIS cat back exhaust w/ resonator delete, JHM ST Shifter + BFI weighted knob, ECode HFIP + Alu Kruez Stabilizer + Sway bars w/links, 034 HF Cat + Catch-Can + FMIC, 18" V708 Matte Black Wheels w/ Dunlop Wintersport
    Veteran Member Three Rings vacsimile's Avatar
    Nov 15 2008
    2004 Audi S4, 1991 Nissan D21, 2001 GTi VR6
    Outer Space
    I've done at least 100 of these. Really easy to install. Just pull down on the edge of the headliner that overhangs the third brake light. You'll hear and feel the clips slide out of the slots when you get it. Then take the third brake light and slide it down towards the bottom of the rear glass. It helps to peel the bottom edge of the light away from the glass and get your fingers under it, palms on the other side and pull down and back. Don't pull straight down, pull towards where the rear glass meets the trunk lid.
    Feb 10 2011
    Palo Alto, CA
    Quote Originally Posted by vacsimile View Post
    Carlsen Palo Alto was ready to charge me 3 hours labor for this shit. smh.
    Thanks Vacsimile. Think I could handle it myself? Very little DIY experience.
    Also, considering it goes off and on, would just replacing this part possibly not fix my problem?
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I had a similar issue with an older car of mine. The 3rd light would work, mostly in the mornings, but never in the afternoon. Turned out to be a failing soder point on the LED strip. I replaced the entire light, as it wasn't worth my time to rip it apart to micro soder. Different car, but very similar issue.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Nov 15 2008
    Outer Space
    Quote Originally Posted by hoodis View Post
    This is such a common problem that I would be surprised if it didn't fix your problem. I can't say for sure, obviously, without even seeing the car.
    I don't know if you could do it yourself, that really just depends on you. It's not a difficult job but you do risk damaging the rear glass if you pull the light down wrong. At your own risk.
    For reference I charge half an hour for this job.
    Veteran Member Three Rings Scorpio's Avatar
    Apr 15 2009
    Texas
    Had same issues over a year ago, out of warranty. I bought new one from GAP, installed it and no issues since
    Apr 11 2014
    Pittsburgh, PA
    I had the same sporadic third light failure. It's real easy to replace. But after I tore apart the light I replaced, I figured out the solder on the circuit board worked loose. Had I known this I could have fixed it with one touch of the soldering iron. The led's were all fine. Just a bad solder joint. I suspect this is your problem as well.
    May 09 2015
    usa
    Mine was bad solder joints as well. It was the 2 solder pads holding the pins for the connector -- easy to get to without disassembling anything, just remove the 3rd brake light from the car and the solder pads that are likely bad are visible right next to the connector.
    To remove the light from the car you have to lift the headliner out of the groove in the light assembly and then slide the brake light in the direction of the rear license plate.
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    Any help to remove the third brake light in B8 Avant?
    May 13 2015
    United States
    I just removed mine and the solders looked fine. The problem seemed to happen more often when it was really hot outside. Just applied more solder on the 2 pins and reinstalled. It hasn’t happened in over 2 weeks now. Seems like there just wasn’t enough penetration from the factory. “Cold solder” is what my buddy who helped me said was most likely the issue.
    2011 Audi S4 DSG JHM HD Overdrive 179mm/EPL 57mm | AWE Tuning Audi S-FLO | Intake EPL 93 Stage 2 + TCU tune | ECS full drivetrain insert kit | 034 Street Density Motor Mounts
