Results 1 to 7 of 7
    Established Member Two Rings TD_05's Avatar
    Dec 19 2013
    2016 Audi S6 2005 BMW M3 1994 Nissan King Cab
    Midwest
    Wheel Lug Bolt Covers
    Got new black wheels for B7 S4. Figured I'd get black Wheel Lug Bolt Covers instead of black lug bolts. Most sources I've read list the OEM lug bolts as 14mm. Yet, most Wheel Lug Bolt Covers at various parts sites are listed as fitting 17mm Wheel Lug Bolts.
    Are the bolts in fact 17 mm? If not where can I find 14mm Wheel Lug Bolt Covers?
    Thanks
    TD
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Why not use the OEM lug bolt covers? They can be painted black quite easily.
    The lug bolts themselves are definitely not 14mm.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    They are not very expensive, I would just buy them. I got mine from EuropaParts and I believe 17mm is the right order size. Just call them and verify.
    Veteran Member Three Rings Quadfreak's Avatar
    May 01 2012
    WA
    The threaded part of the bolt is 14mm diameter. The head size is 17mm Hex.
    Oct 12 2008
    NW Washington
    There are grey and black plastic 17mm lug bolt covers. They're cheap too. I'll look at the part number tonight when I get home. Need the tool to pull them off too.
    Apr 24 2009
    Frisco, TX
    Dec 19 2013
    Midwest
    Thanks guys...
