Results 1 to 16 of 16
    Active Member One Ring Ti B7 A4's Avatar
    Jan 09 2014
    Philly burbs
    What's this warning light mean? ("BRAKES!" but not your typical low pads warning)
    So i'll say upfront that i know my pads are low and that I've been waiting for the warning light to go off before i change them, however the lights I've been seeing recently aren't what i expected to see for low pads, now are they in the manual at all.
    I've done some google and forum searches to no avail....
    So here's the details
    Like i said, i know my pads are low, but the light i expected to see for low pads is this, or similar (not my pic):
    Initially i had my "BRAKE" light (as in the light that goes on when you put the e-brake on, the small red one) blink a few times with an audible chime dinging as it blinked on two separate occasions around Christmas time while i was driving (in pretty cold weather, i think this may end up being relevant). according to the owners manual this could be a low fluid/old fluid issue, but since i knew my pads were low i wasn't too concerned about a possible low fluid level know that the two could be related.
    ....still haven't gotten a low pad warning though
    now in the past week i've gotten this a few times. it's a large "BRAKES!" in the center of the display that blinks in alternating fashion with the typical "BRAKE" light that's associated with the e-brake with an audible chime that dings away while they're blinking. they blink/ding for um,maybe 30secs then they stop and go away until a few days later.
    not suer if it's relevant, but i do seem to notice a correlation with untypically cold temperatures. it may be coincidence, but i thought it worth mentioning
    manual isn't any help, i've been coming up blank on google and some forum searches so i'm hoping someone here knows what this is
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    Did you check your brake fluid yet?
    It's probably a combo of low brake fluid and worn brake pads. You can check both visually in a matter of seconds.
    I'm thinking that prior to the rotors wearing through the wires in the pads, you were probably a little low on brake fluid for one reason or another. Now that the pads are worn quite a bit, the piston has to push out further than normal, so the fluid in the reservoir is lower than what it would be with new/less worn pads.
    I could be completely wrong.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Jan 09 2014
    Philly burbs
    The ebrake / "BRAKE" light by itself seemed to indicate a fluid issue from my interpretations if the manual, the addition of the additional giant red icon with the exclamation mark in my center display I would think indicates something else but I can't find any resource that says what it is
    Veteran Member Four Rings glissoar's Avatar
    Oct 16 2010
    2010 Jk Unlimited
    virginia beach
    Cool first post, sounds like you take shit for care of your care so I will provide no helpful input to this thread, go home your drunk
    Troll out
    2008 A4 *For Sale*
    CTS K04, United Motorsports Tune, Brute Rods, CP pistons, 9:1 compression, Autotech Fuel pump rebuild, ARP head and main bolts, RS4 injectors, Custom built FMIC, 034 cat (gutted), AWE Exhaust, Stasis SS Coilovers, Stack boost gauge, Hydrographic dip trim, Ti Front Grill
    Oct 20 2008
    Denver
    Quote Originally Posted by glissoar View Post
    Troll out
    y so serious?
    Jan 09 2014
    Philly burbs
    Troll out
    You got me. Because I have a warning light that I've never seen before clearly I take "shit care of my car"
    Or maybe it's because I wait for my brake pads to hit the sensors before changing them that makes you think that, I'm not sure. Brace yourself for this though... I also wait until the TP roll gets down to the cardboard before changing it ragging than throwing perfectly good tp into the trash by changing the roll early.
    I've driven and maintained my own audis longer than you've probably been driving period. And audizine sure is living up to its reputation here.
    Heavy on stupid teenagers trolling, light on helpful and knowledgeable adults
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    Quote Originally Posted by Ti B7 A4 View Post
    I LOL'ed
    but i dont agree about the " Light on helpful and knowledgeable adults." Dont jump in the curtains for one sacarstic post. The firs pic show 3 problem lights, even if it's not your pic, maybe it lead to misinterpretations.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Veteran Member Three Rings midnight407's Avatar
    Oct 21 2011
    Brilliant Black B7, '06 STi borrowed/stolen from the roommate
    Northcenter/Ravenswood Chicago
    sounds like you take awful care of your b-hole, bro. my brown eye only gets the freshest
    midnight407
    Chicago, IL
    Mar 24 2013
    Oakdale, CT
    There may also be a difference between red and color DICs when it comes to brake warnings. Flush and refill the fluid and replace pads/rotors and call in the morning if symptoms don't improve.
    -Adam
    Jul 19 2011
    Northern Minneapolis, MN
    Troll out
    You sound drunk. lol And I would say that 90% of members get on here because they have a problem, then hopefully like it, stick around, learn, and help others.
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    Troll out
    Hahahahaha you're always a dickhead............dickhead #trololololol Aside from checking your brake fluid, maybe see if you can find someone local with Vagcom and see if you can gather any more info on it.
    -JOEL
    The Real Black Mamba
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by midnight407 View Post
    Baby wipes for the win bitches
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Oct 21 2011
    Quote Originally Posted by vvenom800tt View Post
    same. always yelling at my gf when she makes fun of me....."THEY ARE ADULT WIPES. YOU'VE NEVER DATED ANYONE WITH A FRESHER ASSHOLE THAN ME"
    midnight407
    Chicago, IL
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    lmao
    I've recently been on that baby wipe trend myself. Sure beats having to take a shower after some of those dirty ones
    2008 A4 S-line 2.0T
    JHM Stage 2
    Senior Member Two Rings Hopperstien's Avatar
    Jul 29 2011
    2007 Corvette
    Palm Beach, FL
    BLAHAHA! Midnight you funny.
    Ti-Try harder next time. simple search.
    http://www.audizine.com/forum/showth...-light-is-this
    You have a brake issue.
    '14 Q5 3.0
    pw211:I would owon it ND THEN beat the **** aout of it witeh a god damn penguin
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by Schweini View Post
    lmao
    Exactly. Just think, if you got poop on the palm of your hand would you wipe it with a dry tissue and go about your day? (hopefully not, lol) You would wash your hands, right? Same principal here. ;)
