Results 1 to 39 of 39
    Nov 17 2013
    Oil Filter Recommendation?
    Oil change soon, time to switch to synthetic and make sure I have a large oil filter. I was going to grab the Bosch 72199WS. Is that a 'large' one or can I go bigger?
    Senior Member Three Rings B6cool's Avatar
    Oct 23 2012
    tricycle
    U supose to run synthetic in our cars from factory to prevent future sludge and other problems. But latter is better than never. The filter u posted is normal and look the same as I'm running now on my 3.0. You can go on ecstuning.com and order mann higher capacity.
    19" BBS CK wheels, Bilstein PSS9 coilovers, 034motorsport front adj. control arms and rear swaybar, Vw Brembo 4-piston front brakes, b7 rear brakes, StopTech SS Brake Lines, Sprint Booster.
    Buy my parts PM me - for sale b6 s4 front brakes Tyrol sport stiffening kit, kW v1 coils. Usp front valance unpainted.
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    I have a Mobil 1 high capacity on my 3.0 now. You can't really go wrong with those, Mann, or Bosch.
    Nov 17 2013
    Quote Originally Posted by B6cool View Post
    I didn't own the car from factory, I don't know what's in it right now.
    Jun 27 2011
    Don't get Bosch.
    Get Mann or OEM.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 05 2013
    Lexington, KY
    best thing to do then is change your oil
    Sent from my XT907 using Tapatalk
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Dec 25 2004
    Earth
    Quote Originally Posted by dunzo View Post
    It
    Turbo=synthetic!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Mann ftw!
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Three Rings tehbry's Avatar
    Aug 12 2012
    Atlanta
    Go with Mann, large filter of course
    http://www.ecstuning.com/Audi-B6_A4-...h/Mann/ES3953/
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by b6Hate4 View Post
    Mann ftw!
    X2
    Oct 23 2012
    tricycle
    I'm using bosch now since I didn't have any spare one. But they do are cheap made than mann or oem
    Aug 12 2012
    Atlanta
    huh?
    Dec 04 2006
    Los Angeles, CA
    are you guys seriously buying from ECS at those insane shipping prices?
    Napa Gold filters are very highly rated, quality filters and they often have sales at the end of month.
    Great filters, get them local.
    B8 2.0T QTip
    Jun 27 2011
    Lots of auto parts stores can actually get mann filters. My local car quest can order them in actually. You just have to ask.
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Quote Originally Posted by AudiTLC View Post
    No lol
    W94025 @ Rockauto.com for $4.90 each, usually an online coupon for 5% off, which almost negates shipping. I buy in 5 to 10 quantity to make the shipping worth it. I go through a lot of filters...
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Aug 27 2013
    Philly
    Yeah for $13 a pop at Advanced..... the guys behind the counter always wonder what the hell is in the box when I check out. Damn 930 filter weighs the same as like 3 fram filters.
    Feb 27 2011
    Winnipeg
    Since you're in Canada part source and Canadian tire stores carry the large Mann filters depending on location, if you ever order from Rock auto throw a few in your cart if they ship from the same warehouse
    Sent from my XT1058 using Tapatalk
    Aug 19 2013
    minnesota
    MANN w950/4
    The MANN w950/4 is the biggest oil filter you can get for the A4. It is made for Volkswagen transporter/trucks and has the same bypass pressure. It is bigger than the so called bigger oil filter. It doesn't get any bigger than this, it will hold more oil and help you extend your oil change interval. I got mine at my local CARQUEST for 11 bucks.
    Here is an ebay link,
    http://www.ebay.com/itm/MANN-FILTER-...a0fe52&vxp=mtr
    I run the w950/4 filter with Motul 8100 Xcess oil. I go about 8-10k per change and no sludge issues.
    You have options with this size filter as well, part numbers and brands are:
    MANN w950/4
    Fram PH4854
    Hengst H19w06
    Knecht/Mahle OC 105
    Purflux LS582
    Tecnocar R240
    However if you don't mind changing you're oil often you can use a smaller filter and less quality oil.
    But don't get lazy and leave cheap oil and filter on for over 3k miles.
    Veteran Member Three Rings g huns's Avatar
    Aug 13 2012
    Lexus RX350
    Wakarusa, Indiana
    I run NAPA Gold filters in all my stuff. Mostly made by Wix, I think. NAPA also carries a small number of Mann filters at some stores, and can order any Mann filter you want.
    When I bought my car, it had a giant sized Mobile1 filter. I deciding which filter to use at my first OC, I read somewhere that the Mobile1 filter's bypass valve was set way lower than the OEM recommendation. Don't remember where I read it, or know how accurate the info was, but I decided to avoid the Mobile1 in the future.
    2012 A6 3.0 Premium Plus w/Sport Package
    Aug 27 2013
    Philly
    can the 3.0 run the mann 950 too? If so, I'd like to start using that.
    Veteran Member Three Rings TwinTipSkier's Avatar
    Nov 18 2009
    2012 VW Sportwagen 2.5S
    Tampa, Fl / Boston, Ma
    Quote Originally Posted by jacobsen View Post
    Yes... Never knew this. I like it.
    What does that bring the total oil capacity to, 5+ quarts?
    -John
    IG: johns550cc
    | '12 A4 Avant Brilliant Red | Thread |
    | '02 A4 1.8TQMS -gone |
    Aug 19 2013
    minnesota
    Quote Originally Posted by SJorge3442 View Post
    Yes it should but, the splash shield might be in the way once it's on. :(
    Jun 27 2011
    the 950 is huge, but honestly probably overkill.
    I'm running the 940/25 and even that is a pain to maneuver in the engine bay due to its size. I would imagine removing it when its full of oil is an exercise in patience or trying not to murder everyone in sight after you spill oil all over your engine bay, subrame, and driveway/garage/street/self.
    -CP
    2017 Q7 3.0t
    Aug 19 2013
    minnesota
    Quote Originally Posted by TwinTipSkier View Post
    I think at least 5 quarts. Motul comes in 5 liter jugs and I'm not sure what the conversion is exactly, like .25 more in a liter I think.
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    Parts source in canada has Mann filters. I use K&N filters, and never touch Fran.
    Dec 30 2009
    lol so true.
    I think Old Guy turned me onto using a bag to catch it all, so I started using a white garbage bag wrapped around the oil cooler and hanging from other stuff, while removing and cleaning it up for the new filter.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Jun 27 2011
    Quote Originally Posted by Timtheguru View Post
    lol so true.
    Yea a gallon sized ziplock helps for sure, but I still get a little spillage. A 3 gallon garbage bag would be the best bet however, I never considered a regular garbage bag...
    -CP
    2017 Q7 3.0t
    Dec 30 2009
    I've been using the hefty white ones with super stretchy sides and the red plastic "handles" to hang it. Let me know if you need one.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Jun 27 2011
    Can you order those from ECS?!
    -CP
    2017 Q7 3.0t
    Dec 28 2006
    Western Maryland
    Here's the next generation for oil change cleanliness:
    Dec 30 2009
    Ha, that was the thread you referred me to bags, makes sense now why my washer fluid jug didn't work for the job when I cut it up, I did it upside down. How do you hold that in there?
    The V6 engines are so nice for oil changes, filter and plug right next to each other.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Apr 07 2011
    You don't really even need to hold it. For me, it just sat there like it belonged there. But there is a handle...
    Dec 28 2006
    Western Maryland
    Exactly. I just shove it up behind the filter and it gets wedged in place. Remove the filter and all the oil drips down into the neck portion of the jug.
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Yup OG exactly what I use now after reading Heywier's post. Works great!
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by A4Maine-iac View Post
    Thanks for giving Heyweir credit for the pic! I have posted it numerous times but couldn't recall who I lifted it from.
    Jun 27 2011
    Damn. And to think I just recycled an empty washer fluid jug the other day.
    -CP
    2017 Q7 3.0t
    Nov 17 2013
    I'll check if my local Partsource has the MANN filter, largest one they have. Thanks folks.
    Apr 07 2011
    Here ya go. Click
    Aug 19 2013
    minnesota
    I did an oil change yesterday and with the w950/4 it just about an entire 5 liter jug of Motul. 1.32 gallons. Pretty sweet.
