Results 1 to 8 of 8
    Established Member Two Rings Giorgi's Avatar
    Oct 12 2011
    Tbilisi
    Cool What is this center console part called?
    Hello, happy holidays to everyone!
    So, when I bought b5 s4, it had this thing broken, so I removed it, I am not sure what was there (seems like ashtray maybe?) what is it called and ideally does anyone know partnumber?
    Admit it! LY3H is the fastest color
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    That's your OBDII port fascia.
    2000 Achat S4
    Senior Member Two Rings rsxsty1e's Avatar
    May 25 2009
    Quote Originally Posted by jaychen View Post
    this plus an ashtray. obdii port was moved to below the steering wheel, they just never removed the part from where it is on the b5. you can see the obdii symbol on the bottom left of the cover.
    Feb 19 2011
    Earth
    Ah i see, so NA cars had the OBDII port moved?
    My car is a Euro so all B5's have it there (even 2001 S4's).
    2000 Achat S4
    Jun 01 2008
    Apopka, FL
    Yes. OBD II in N/A are universally located under the dash kick panel by the driver side.
    if there's not a P/N located on the underside of the cover,it's going to be apart of the the whole tray. I'd have to look at ETKA or you would have to call a dealer.
    May 25 2009
    yup, I should have mentioned it was moved for north american cars.
    Jul 26 2008
    Brisbane, Australia
    It is the cover to the rear ashtray and access to the OBD port. Why, what is wrong with yours?
    Oct 12 2011
    Tbilisi
    The cover is broken as in plastic is destroyed
