You can use the same screws from the flapper motor and they will be the perfect length. FYI....
vizi
05.5 B7 A4 longest running with no motor issues at 373whp
Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
B6 A4 1.8T Dolphin Gray qM
4L Q7 3.0T Glacier White PP
239whp / 284wtq dyno proven (uncorrected)~270whp/305wtq with new goodies dyno results will be coming soon
Stock K03
08 Audi A4 Quattro TIP / S-Line / Ocean Blue / Bi-Xenons / APR Stage 2+ / JHM HPFP + FMIC / ECS Snub / RS4 RSB / P3Cars / APR CAI / LED DRL, License, Interior / RS4 Covers / R8 Coil Packs / Spulen TIP / 034 HFC / tt DP / Magnaflow / Cupra R / 034 mounts / Thor Skid / H&R / Hawk HPS / Goodridge / Stoptech / DV+
Vorsprung durch Technik
Sean
The New
B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
The Old
B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
Quartz Grey B7 A4 Quattro 6MT
Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
Dat Der Build Thread
Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
Stock K03
