Results 1 to 25 of 25
    Jan 03 2013
    Baltimore
    Best shocks for h&r OE sport springs
    I have a set of h&r OE sports on my stock non-sport shocks. They have become increasingly rough as expected. I see that we have the bilstiens and koni shocks available. I have not seen much in regard to which shock is best with this spring. Anyone have any input?
    Sent from my XT1060 using Tapatalk
    Veteran Member Three Rings AdrianLee's Avatar
    Jul 19 2011
    2016 A7 3.0T & 2016 Q5 3.0T (Wife's Daily)
    SW Michigan
    Koni FSD Kit should be good. Its a little pricey though. I've heard good things about these shocks
    Active Member Two Rings deceptacon's Avatar
    Jun 28 2013
    BMW X5 ///M
    las vegas
    Bilsteins or koni. Depends on what you want. Koni is twin tube and bilstein is mono tube. Just my preference, I prefer a twin tube for daily driving.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    http://www.audizine.com/forum/showth...oni-FSD-shocks!
    same price as the Koni's you can get a quality coilover such as H&R or Vogtland
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Sep 26 2013
    San Jose
    good luck.
    check out the Koni yellows. They are adjustable so over time you should be able to find a comfort level you like. Not externally adjustable unfortunately, you'll need to remove them in order to adjust. So sad, other cars have options for externally adjustable shocks but not us.
    In the future try buying a suspension kit (springs and shocks together, like the Bilstein B12) or coilovers. No worrying about springs and shocks matching.
    2012 Stronic | Sports Diff Pkg | Chipwerke Pro | aFe Pro Dry | Forgestar F14 18x9 | EBC USR Slotted Rotors | EBC Yellowstuff Pads
    SOLD 2010 B8 A4 Tiptronic | Stasis Engine Tune | Michelin Pilot Super Sports | Forgestar F14 18x9 wheels | Stoptech Powerslot rotors | EBC yellowstuff pads | Bilstein PSS10 - SOLD | aFe Pro Dry Filter
    Me @ Laguna Seca Raceway - https://www.youtube.com/watch?v=z7s8S1Uh7uc
    Jan 03 2013
    Baltimore
    Yeah I am sort of regretting not getting a matched set. Thanks for the input folks!
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    i am in the same boat, i dont necessarily regret springs because it was the quickest and cheapest way to get a solid drop other than cutting springs which is not something i would ever do).
    Personally, i would just save the money you would spend on new shocks and just get coils. you might be able to recoup some of the cost by selling the springs too.
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    Got S4 suspension for cheap - did the job.
    Euro Tails Crew
    Jan 03 2013
    Baltimore
    Yeah I thought about that as well but had read that it does not drop as much due to the s4 being heavier.
    One thing that I have noticed that with the warmer temps (30s) it rides way better and is not as bouncy. Perhaps I will just ride out the winter and maybe things will be better by springtime.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    If you are looking for a stock type ride I would just order some OE replacement shocks for Sports Suspension, like Sachs, Boge, Bilstein Touring Class, etc. from numerous online dealers it will be a little firmer than your non-sport shocks but not overly firm. If you are looking for something a little more than a stock sports suspension ride I would go with Bilstein Sports, they are not adjustable but do you really want to take the Koni Sports off the car every time to tweak the dampening? The Bilsteins ride so well, I had them on my B5 S4, B7 S4, numerous GTI's, etc. AWE had the rears for $90/each a little while ago, shop around, you should be able to get a full set off whatever for $400-$700.
    Established Member Two Rings ChornsYYC's Avatar
    Jan 30 2013
    Houston, TX
    Have the exact same setup as the OP (non-sport suspension with H&R OE sport springs). I'm happy with the ride height the way it is. Thinking about going with the Bilsteins but have read discussion where people claim the HD's may raise the vehicle and the sports could lower it. I'm calling BS on both accounts but would love to hear from someone who has ran either setup.
    Registered User Four Rings Excelerate's Avatar
    Jan 24 2008
    RS7, R8 4.2TT, RS4 S/C, Tundra 5.7, Atlas VR6
    Branford, CT
    Bilstein and KONI make the best shocks for the B8 chassis IMO.
    Jan 30 2013
    Houston, TX
    Sorry to hijack... I can't find the time for a thorough search - anyone know what the recommended Bilstein shock is when running H&R OE sport springs on non-sport suspension. HD's or sport?
    Established Member Two Rings gsommerp's Avatar
    Oct 12 2008
    Dublin, CA
    Quote Originally Posted by ChornsYYC View Post
    I've ran HDs in other cars, and really liked them. The sports are stiffer, however the HDs are stiff enough IMO. I also have H&R OE sport springs and need a little stiffer struts and shocks.
    2014 Audi A4 Monsoon Gray | S-Line | RS4 -Grill | 35% tint all around | 19 x 9.5 VMR 710 | 255/35/19 Michelin Pilot Sport AS3 | HR OE Sport Springs | Koni Sports | APR Stg 1
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We recommend the KONI Sport adjustables. KONI FSD's are fine shocks, but don't work too well with a lowering spring. Bilsteins are nice, but tend to ride a bit more firm on bad pavement.
    We've got both available, email or PM if you're interested.
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    I actually have the OEM Sport shocks on the H&R OE sport springs. At first they were alright but they are occasionally feeling a little bouncey/floaty, mostly on larger bumps at higher speeds.
    I think my recommendation would be to replace the shocks and springs with a paired set. Someone just recently posted in another thread you can buy Bilsteins for the B8 with matched Eibach springs.
    Anyways, for me after much thought and research on the H&R OE issue, I decided to majorly splurge and purchase the Stasis Ohlins coilovers through Europrice. I will post my impressions after Eurocode completes the installation when I can get the car to them later this month.
    Sep 26 2013
    San Jose
    Quote Originally Posted by B G 8er View Post
    I look forward to hearing about the Ohlins. Price and maintenance turned me off, but I've been in a car with Ohlins and was amazed at how much grip that car had around the track. It might have been a different type of coilovers, but all Ohlins have that pedigree for great suspensions.
    Sep 28 2011
    Valencia, CA
    I was able to take advantage of some special year end pricing from Alex @ Europrice so the price was rather comparable to what I would have had to pay for a set of Bilstein PS10s or KW V3s, etc. I am hoping the ride quality and performance characteristics are high above the others as Alex is promising. He explains that the maintenance can be stretched out and after speaking with Jeff at Stassis' Tech support, he told me their website needs to be updated, that Stassis is no longer automatically charging customers the servicing costs if the servicing to maintain the warranty is skipped prior to rebuilding the dampers. I also spoke with Ohlins USA and they explained that Satsis buys individual "parts" from Ohlins (not entire dampers) and builds the dampers to their own specs thus the technology of the dampers is Ohlins however, the dampers are actually a custom Stassis product. He explained to me the resason Stassis is so strict with their warranty policies is because technically, these products are "racing" technology which has been adapted for dual street use. They are made for performance first above "long term durability". They assume most product owners will drive on them aggressively plus, they have to contend with the fact that many of their coilover sets will see poor conditions such as rough roads, inclement weather conditions in places like the NE with road salts, etc. I don't have any intentions of tracking my car and live in S. Cal. I am as cautious as possible over LA pot holes and the worst my car will probably see will be occasional canyon runs with fellow Audi enthusiasts.
    Sep 26 2013
    San Jose
    Unless of course, you would have also noticed the PSS10s on sale near the end of the year . LOL
    Interesting stuff, I didn't know Stasis did the dampers themselves.
    Sep 28 2011
    Valencia, CA
    Quote Originally Posted by audiAYYY4 View Post
    Good Point! Another interesting benefit of the Stassis coilovers is you can set them minimum lowering near the OEM sport package suspension height.
    Sep 26 2013
    San Jose
    Oh so thats even a little higher than H&R OE springs (just trying to keep on topic, lol).
    The front struts for the Bilsteins can probably be adjusted higher than OEM, non-sport. So much of the shock body is threaded. I'm at 26" gtf and tons of room to go up (at least 2-3" ).
    The back springs would be the limiting factor. I dont have a pic of that, but if I had to guestimate I would say I could maybe get to 27" ground to fender. I'm not sure what OEM sport or non-sport are. Someone once told me there non-sport was 28", I think.
    I wonder if Stasis makes the shocks custom to the A4, instead of something that might work for both A4 and S4, and possibly others. Custom would be awesome.
    Senior Member Three Rings millerrh's Avatar
    Jun 15 2013
    Austin, TX
    The front struts for the Bilsteins can probably be adjusted higher than OEM, non-sport. So much of the shock body is threaded. I'm at 26" gtf and tons of room to go up (at least 2-3").
    While the Bilsteins might have a large threaded body, they have limits to where you can set the perches. I'm sitting at 26.2 fender-to-ground right now and getting spring binding sounds from them. I suspect it's cause I'm too high. I'm going to go check this weekend against this spec in the manual.
    2014 S4 Premium Black Pearl | 6MT
    Sports Differential | 19" Peelers | B&O Sound | Carbon Atlas Inlays | CF Supercharged Badges | Bilstein PSS10s | Eurocode Alu Kreuz | Eurocode USS Sways & Endlinks | Roc Euro Intake | AWE w/Res DPs, 102mm
    Sep 26 2013
    San Jose
    Quote Originally Posted by millerrh View Post
    Oh, thanks for clearing that up. I guess I don't know how high they can go then.
    Sent from my DROID BIONIC using Tapatalk
    Jul 19 2007
    San Diego, CA
    The max height of the suspension is going to be dictated by the length of the shock. You can spin the perches all the way up if you want, but at some point the shock will top out and the car won't go any higher.
    Typically Bilstein sport shocks are about an inch, sometimes more, shorter than the factory shock. This will generally limit the car from getting near the factory ride height.
    Sep 26 2013
    San Jose
    Quote Originally Posted by Mike@PureMS View Post
    I see. Thanks for the info.
