OK lets look at your statements.
Originally Posted by
fukinavit
People forget that the rs6 engine is what makes the car. It's more than just turbos!
No, it is not more than just the turbos. Take away the turbos, and youll have a car that is slower than an A6 4.2. There are a lot of other things that the RS6 has over the A6 4.2, but take away the Turbos, and it is pretty much an
C5 S6 with nicer bumpers and side skirts, but much slower. DRC suspension is crap, since it is guaranteed to fail, and almost every RS6 owner replaces it.
If you remove the turbos from the RS6 4.2, you will have a mild cammed, single stage intake, low compression 4.2. Yes, it will be slower than a stock A6 4.2.
fukinavit
Peak torque is exactly it, peak is spread from 1500 to 5000 on the rs6 where as 3000 to 4000 on the s6.
LOL, ok. I think you have been reading too many marketing blurbs.
Here is the v10 S6 stock dyno from APR. They convert the figures back to approximate crank HP, with some calculation. On 93 octane testing, they seem to find that the S6 v10 puts out more than the rated TQ. They have a peak at about 440 lb/ft. What is more important for our discussion is the curve, not the figures.
From 2500 to 5000, the v10 S6 has about a 10% difference in TQ. Not entirely flat, but probably not even noticeable when driven.
I couldnt find stock RS6 dyno, but I will assume it is totally flat from 1500-5000. Here is your next problem. These cars are both AUTOMATICS.
After 1st gear 4500rpm, which you will hit pretty much as soon as you hit the throttle from a stop, how do you plan to tap into this "peak" TQ from 1500-4500? The only way you can get max torque in an automatic car is by flooring it. As soon as you floor the car in any gear under 4000 rpm, the car is going to instantly downshift to the lower gear, and youll be at about at least 4500 rpm or higher. Therefore, this broad peak TQ rating is useless, unless you have a manual car and are lazy with your shifting. Gearing down will have a much greater effect on acceleration then having low RPM TQ.
While I agree that area under the curve is important for a street driven car, the v10 5.2 has a flat enough TQ curve that the RS6 is not going to be much further ahead.
Now, consider this. The two cars are side by side, cruising at 35 miles/hr in sport mode. Both cars punch the throttle. Who do you think will take the quick lead? My money is on the S6.
S6 - Better gearing
S6 - Instant throttle response due to high compression
S6 - NA engine = no waiting for turbos to spool up
S6 - Faster shifting transmission
The RS6 may catch up in a second or two, but it will be the S6 that takes the early lead.
From my car, I want the quickest acceleration instantly, when I punch it. I don't want to have to wait a second or two for it to get up to speed. By then, I am already hitting the brakes due to the fact that I am a law abiding citizen, and I don't want to get traffic tickets that will push my insurance payments through the roof.
