Results 1 to 33 of 33
    Veteran Member Three Rings S4tranquility's Avatar
    Dec 29 2005
    Baltimore
    Cell phone mount.
    Let's see pics of what you're running.
    I am looking for ideas for something stealthy for my iphone 5 that puts it higher than in front of the shifter where I have it now.
    19 S4 Prestige & 17 Q7 Prestige.
    Former: Tesla P3D; 6MT 13 S4 (dual pulley); multiple B5 S4s
    B5 S4 120+ club; Sleeper, Stages, and more B5 S4 vids
    Senior Member Two Rings rico89's Avatar
    Mar 28 2013
    Auburn Hills/MI
    Quote Originally Posted by S4tranquility View Post
    I am using an AIR VENT holder which is linked below! Honestly, could not be any happier perfect location and in easy reach :D
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Glutorange S5 | 4.2 V8 | MT6 | JHM SS | Sachs Performance Clutch | B&O | BBS CH-R 20" | Alcantara | AWE Track Exhaust & DP's| H&R Coilovers | H&R Sways | APR Tune| Hoen Fogs | 10" Sub | Ecodes |
    Previous 2005 Audi A6 C6
    Instagram: @rico_1001
    May 01 2013
    San Jose, CA
    I use this one:
    It actually mounts anywhere on the dash just fine. I have it right about the air vents on the dash, and the suction holds just fine.
    Dec 29 2005
    Baltimore
    I grabbed a non-rotating vent mount on eBay.
    Thinking a good alternative would be horizontally on the belt line trim by the fog light switches might be good.
    Active Member Two Rings imtheneal's Avatar
    Feb 17 2012
    Massachusetts
    I have a Kenu airframe
    http://www.kenu.com/products/airframe
    in my Audi q5 and a proclip for my b7 s4
    Jun 19 2007
    MI
    I got an old fog light switch and glued a garmin ball to it (ditched the double sticky tape)
    Then iphone 4 cradle.
    http://www.mountguys.com/product_p/gn010.htm
    http://www.mountguys.com/product_p/cc005-sbh.htm
    Then i can remove the non used switch (on the fly) and install my garmin ball, then cradle. During my normal day to day driving i remove the ball and reinstall the switch fake.
    I just got the iphone 5 and ill i did was just the iphone 4 mount and extened it 4 mm or so with some more plastic and rivites.
    I might switch the whole design to RAM ball some day.... Also did the same switch trick in my MK2 golf.
    Established Member Two Rings VisionPaintball's Avatar
    Jun 26 2007
    Keyport,NJ
    Quote Originally Posted by imtheneal View Post
    just ordered a kenu. looks good.
    '02 B5 S4 Avant
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    Any pictures of the most popular mounts would be ideal.
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Quote Originally Posted by hotshot32890 View Post
    Yeah really.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Mar 28 2013
    Auburn Hills/MI
    Looks cool, is the Kenu adjustable to move up-down+ left-right?
    Feb 17 2012
    Massachusetts
    It can rotate and you can use your vent to tilt it up and down or swivel left or right
    Feb 04 2012
    93 Eurovan 5sp, 98 TDi GTi, 06 Jetta TDi BT
    Newport News VA
    I used a Brodit/Proclip USA bracket and a universal iOttie mount that I hacked the suction off of and screwed to it. It rotates, I do like the look of the Aduro mount and may mod that one to the bracket if it ever wears out. I like the Brodit clip requires no cutting and doesn't hang on the vents, it can be moved left and right to suit.
    Aduro mount
    http://www.amazon.com/gp/product/B00...vglnk-c1005-20
    Feb 17 2012
    Massachusetts
    Here's my q5 with the kenu
    Jun 19 2007
    MI
    My images from my earlier post
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    Kind of on topic as I've been considering a mount, but does anyone have issues with getting a good GPS signal inside your car? I'm with Verizon(Galaxy S3) and the occasional times I need to use GPS, I end up usually propping my phone up in the cupholder somewhere. If I have it in my lap/passenger seat/shifter area, the signal goes in and out.
    I don't use GPS enough for this to really annoy me, just wondering if anyone else has this happen.
    Senior Member Two Rings rsxsty1e's Avatar
    May 25 2009
    i just picked one up and put it in my b5. i like it. are your vents strong enough to the point where they can hold the weight without rolling down? or do you put something to jam it from moving?
    im using a quarter right now, but ill prob make a small CF wrapped piece to use as not to scratch the vents.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by goalieman24 View Post
    Same phone, and I've never had a problem with GPS. Usually locks in less than a couple seconds. Do a search on screw tightening and see if that helps your GPS issues.
    2001 Corvette (C5) Z06
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    insert picture of hand
    Jun 14 2012
    2000 Jeep Wrangler TJ
    Tampa, FL
    CD magnet phone mount from amazon! and then bluetooth to the rear cd player and its the best setup ever. wire free and magnet connection. they also make the mount with a sticky suction cup
    Feb 17 2012
    Massachusetts
    Quote Originally Posted by rsxsty1e View Post
    Mine are pretty strong and I'm not doing anything to reinforce it... But I'm a little concerned about how it will hold up in the long run. Definitely post pics of what you put in there I would love to see it!
    May 25 2009
    using a quarter right now to keep the vent in position, but haven't had any issues so far.
    Veteran Member Four Rings Street Nasty's Avatar
    Jan 20 2009
    B5 S4 Avant
    I use the montauk CD phone holder. It's like 20 shipped on Amazon. I don't use CDs do it works perfect.
    Jun 26 2007
    Keyport,NJ
    My airframe works great.
    Just ordered another one for my wifes car.
    '02 B5 S4 Avant
    Jun 26 2007
    Keyport,NJ
    Looks great. Did you wrap the trim yourself?
    '02 B5 S4 Avant
    May 25 2009
    Quote Originally Posted by VisionPaintball View Post
    thanks man. yeah with help from a friend a few years ago. taking the beltline trim off was very nerve-racking.
    Veteran Member Three Rings R1CH-5100's Avatar
    Jun 27 2005
    '13 Triumph Street Triple
    San Diego
    Quote Originally Posted by Street Nasty View Post
    That's pretty cool. I've always wondered if anyone made one of these. More useful for us would be a cassette slot mount.
    May 25 2009
    Quote Originally Posted by R1CH-5100 View Post
    they actually make that too.
    http://www.amazon.com/iDeck-Integrat...ssette+adapter
    ion is coming out with a bluetooth cassette deck, someone posted about it in the b6 forum i think. anyway, im sure it will have its limitations like charging it, but thats a pretty cheap and effective way for a decent interface. ill be giving it a shot when its available
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    i just stick it in the coin slot / cup holder area, then fish it out from under the seats every time I see a fun corner. Sorry, no pic available, but it's a pretty common build.
    Jun 27 2005
    San Diego
    That's also pretty cool. Doesn't work for us Android users though. I wouldn't mind just a device mount that utilized the cassette slot.
    There was a guy in the classifieds last week that made a ipad mini mount using the radio keys slots, a pretty good idea.
    Veteran Member Four Rings AudiB5owner's Avatar
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    RAM Mount, Panavise Custom Mounts, Proclip
    Good if you have multiple devices or a seamless OEM look
    B5 A4 1.8T FWD
    Mar 07 2014
    Texas
    I just got the Neutron S mount from http://www.bungajungle.com/. It's a magnetic mount. Overall pretty happy with it:
    Pros:
    1) Really strong hold (when there is direct contact with magnets and metal disc).
    2) Small size, discrete
    3) Inexpensive ($20)
    Cons:
    1) Anodized aluminum already scratched a bit
    2) Magnetic hold did not work through my case, had to cut a hole in my case.
    I cut a hole in my Speck Candyshell for the metal disc. It turned out really well, and is perfectly flush.
    Veteran Member Three Rings rage385's Avatar
    Sep 06 2012
    2001.5 Audi S4, 2009 Daytona 675
    United States
    I use this one. I love it!!
    InfiniApps Slyde CD Slot Mount for Smartphones, Cradle-less Univers... http://www.amazon.com/dp/B00DPMNNUO/..._tTeBtb05YNFSZ
    Sent from my XT1080 using Tapatalk
    Active Member One Ring alloyd68's Avatar
    May 04 2015
    My phone holder is an imagnet. You might like it.
