Results 1 to 40 of 57
Thread: Phone Mount?
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    Phone Mount?
    Anyone have a phone mount for their car?
    Normally I use mounts from ProClip but I don't like what they have for the B8. Not a fan of vent mounts. I need every bit of AC here in Houston.
    ProClip also has an alternative mount but I'm not sure if I'm sold on it.
    http://www.proclipusa.com/dashboard-..._leftorright=0
    Then there is this leather covered Kuda mount.
    http://www.kudausa.com/audi-a4s4-b8-...ack-a1305.html
    I could attach my ProClip iPhone cradle to it.
    Panavise has a solution too, but I would need to buy a new iPhone cradle and I like how the cradle from ProClip has the integrated lightening cable.
    Curious what others are using for their phones.
    For now I've been placing it in the cup holder or the narrow storage area to the left of the cup holders but neither is ideal.
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Senior Member Two Rings CharlesP2009's Avatar
    Sep 22 2012
    2009 Audi A4, 2009 BMW 335i Convertible
    The Copper State
    I like this Kensington Quick-Release Car Mount:
    Easy to attach, easy to reach, easy to remove, it's secure, and it can be flipped vertical to horizontal. Works great for my iPhone 4!
    I also got one of these for Bluetooth music streaming:
    Established Member Two Rings VAZSTEVEN's Avatar
    Nov 15 2013
    Cental NJ
    I use the iOttie SmartTap holder for my gs3. I like the easy snap-in process. The suction cup is really good and very feels firmly attached. If you wanna move the holder to another spot you simply wash the suction side with water and it mount it.
    Sent from my SCH-I535 using Tapatalk
    2010 Audi A4
    APR k04
    KW V1 Suspension
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    I pulled the trigger on that ProClip mount you're not sold on -- haven't received it yet, so no good review or pics. I went that route after seeing a similar mount in the local shop's Golf R. I was pretty impressed with how sturdy it was without being permanently attached to the dash.
    /I know that's not very helpful
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Jan 13 2006
    Houston
    Quote Originally Posted by auditd0rk View Post
    Well, actually that is a big help... if you'll post some pics of it installed and give your thoughts on it.
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    I posted in the S4 forum, but I'll repost here as it's more appropriate for the thread. Note the photos still show the clear film on the proclip and the back of my phone as I have not finalized the position of the mount and the film makes it easier to removal.
    If you mount in the center, none of the vents are blocked.
    My current mount uses a proclip vent mount, a garmin ball and an arkon slim tab adapter socket. it allows for rotation of my iphone at any angle and quick removal/install. a "slim tab" is used on the back of the phone for mounting. i plan on using this mount for the mobile VCDS app once it's available in Jan. 2014.
    proclip vent mount, garmin ball, arkon slim tab garmin socket head:
    arkon slim tab mount on phone that slides into the garmin socket head:
    phone partly slid in the socket head:
    V1 connection app:
    if you don't need infinite multiple angle rotation, the quadlock mount works as well. it mounts flat but can be rotated 90 degrees for portrait/landscape. i'll likely switch to this system since i use it to mount on my bike as well.
    Mar 05 2009
    Earth
    Phone Mount?
    Have a look at the IOmounts sold by Proclip....they're slick. I've recently changed mine to that style.
    Nov 25 2011
    Quote Originally Posted by CharlesP2009 View Post
    Does this work for Android phones?
    2018 RS3 & 2017 SQ5
    Insta: @ccampbs
    2012 A4
    2015 S4
    2014 SQ5
    Veteran Member Three Rings TheHeiko's Avatar
    May 24 2012
    It's easy to spend a fortune on these things and have a drawer full of them! I had been using an iOttie with Smart Tap mounted on the flat part of the MMI display pod. I was able to angle it so that none of my view of the screen was blocked but the passenger view was really cut down. I do not like mounting anything on the dash so this was the best solution. The pros of this mount and location was that it was not on my dash, it gave me a great view of my phone, it was really the only flat surface to mount on, and the Smart Tap feature is excellent for easy in and out of the phone. The cons: It blocked the MMI screen for the passenger, it is a pretty chunky unit, and it was subject to vibration on certain pavement where my phone would even flip orientation from portrait to landscape.
    I have since gotten a Kenu Airframe. I am usually not a fan of vent mounts because they are not always the most secure and I also live in a hot climate and need maximum venting but I also did not want excess clutter. We don't have a ton of dash real estate in our cars anyway. The Airframe is super minimalist and works very well. It holds my iPhone 5 in a Magpul Field Case very well. I'll see how my AC is affected come summer time but for now, I love the clean and simple look and function of the Airframe. Plus, it's only $25 and is an easy one-handed operation.
    Senior Member Four Rings r6_11b8's Avatar
    Oct 03 2013
    los ángeles
    by far best phone holder I've come across…simple and doesn't look bulky
    http://store.apple.com/us/product/HC...phone?fnode=46
    2011 A4 ice silver metallic
    MODS- 25% tint rear, 75% front, 19" Rotiform BLQ, Solo Werkes coilovers, Custom FXR projectors
    upcoming mods - 10 inch sub
    2009 Yamaha R6 - Shogun FS-Zero Gravity-Custom FE-Hot Bodies Flush Mounts-MotoDynamic Integrated Tail Light-Supersprox -1+2-Taylormade Full Exhaust-PCV-OURY Grips-Corbin Seat-Ebay Shorty Levers
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    Quote Originally Posted by r6_11b8 View Post
    +1 for kenu
    Apr 07 2013
    Chicago, IL
    I am also using the Kenu Airframe and am very pleased with it so far.
    Sep 07 2009
    10 Allez|09 SJ
    Royal Oak, MI
    Quote Originally Posted by Campblett View Post
    I'm going through a boatload of hassle right now trying to get this to work with my Android. I am using the red band ipod cable which powers the tune2air device, but does not show up as a supported AMI device; and using an older ipod cord, the AMI device shows as no device connected but does not power the unit.
    Hello: 2012 A4 Avant - Stock!
    Goodbye 2013 S4
    Goodbye:07 A4 | Huper Optik 30% | Whispbar
    Veteran Member Four Rings wxsgt's Avatar
    Jul 16 2012
    2021 Audi A4 45
    Haverhill, Ma
    Quote Originally Posted by VAZSTEVEN View Post
    I can second this mount, I have it mounted on the left side by the steering wheel and it works like a charm
    2010 Ibis White Audi A4 P+ l Upgrades: RS4 grill, Akebono Brakes, Debadged, Solo Werks S1 Coilovers, Targa Trophy Stickers(guaranteed 10+ HP) l
    2009 Ibis White Audi S5 Coupe | Upgrades: RS Grille |
    Senior Member Two Rings osspasha's Avatar
    Sep 18 2013
    +2
    but OP doesnt want something that blocks his AC
    here is a pic of it in action
    2013 S4 B8.5
    Don't let fear and common sense stop you
    Oct 03 2013
    los ángeles
    i put mine all the way to the right of the vent that way the phone kinda sits towards the middle and doesn't block the entire vent
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Ryan - flickr
    Jan 13 2006
    Houston
    Quote Originally Posted by cory_can View Post
    That is pretty slick.
    Veteran Member Four Rings inNout's Avatar
    Jul 22 2009
    IL->WA
    I'd be wary about anything that clips to the vent. Over time these plastic blades get brittle and eventually will snap after repeated pressure/weight. This happened with my previous Lexus.
    2010 B8 2.0T 6spd K04 + [HPA Motorsport, Rays, APR, Eisenmann, Bastuck, Eurocode, KW, OSIR, StopTech, ArmaSpeed]
    Jan 13 2006
    Houston
    Yeah, i really don't want anything that clips to the vents, for various reasons.
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    for android, how about a petite bobine with car kit from fuse chicken? only $7.95 now. there is also a iphone 5s version that can be preordered.
    http://www.fusechicken.com/collectio...bine-micro-usb
    Dec 01 2011
    i use the phone mount from verizon, holds most phones and is so easy to use, and nice too. it's the air vent mount, fits and holds great, also very easy to use you can mount and unmount a phone with one hand in like 1 second.
    IG @theshawon
    Jan 20 2010
    Texas
    If you don't use your coin holder, give this a try... http://www.audizine.com/forum/showth...er-iPhone-Dock
    Installed: Grocery Hooks, BLESK Plate bulbs, iPhone Extension, VAG-Com, Luminics JDM Yellow Fogs, Chrome Grille Inserts, Rear 12v power, Underseat Storage, Folding Side Mirrors, B&O Tweeters, E-Codes with BLESK 5000K, Audi Hill Hold, S-Line Rear Bumper, Warning Triangle, DIS Stalk, Full-Function Rear Power Locks, ADS, Mirror with Compass, Q5 Wheels
    Sep 22 2012
    The Copper State
    Yep, they specify Android as well as Windows 8 phones in addition to most iDevices.
    Dec 18 2011
    San Jose, CA
    Mountek nGroove snap.
    Senior Member Three Rings yma4's Avatar
    Dec 27 2011
    San Diego, CA
    Installed my ProClip today. Overall pretty happy with it and like that it doesn't block any AC vents.
    Sorry for the quick pic - had to use my phone to actually take the pic. If anyone wants to see what the clip looks like with the phone in let me know and I'll snap some more.....
    Dec 27 2011
    San Diego, CA
    ^ Just realized the pic is a little dark - I'll take some better ones tomorrow....
    Jan 13 2006
    Houston
    Yeah, if you could grab a pic or two in the sun I would appreciate it. :)
    How's the reach? I assume access to the glove box is fine? What about passengers' knee room?
    Feb 02 2012
    Colorado Springs
    Quote Originally Posted by yma4 View Post
    Now I know what mine will look like... if it ever friggin' gets here.
    Dec 27 2011
    San Diego, CA
    Finally got around to taking a pic of the ProClip during the day. It's pretty sweet and does not get in the way of the passengers knee....
    Dec 01 2011
    ^^ how exactly does that attach? is it just a strong adhesive or does it screw into the dash material
    IG @theshawon
    Feb 02 2012
    Colorado Springs
    The ProClip mount has two adhesive strips and a long edge clip that slides in between the dash and ac/media components. I just installed mine. It's quite secure w/out any dash damage (screw holes).
    Jan 13 2006
    Houston
    The only thing that bothers me about that pro clip mount and the reason i said originally that I wasn't completely sold on it, is the triangular support. I know it's there for a reason, but it looks like a major dust collector. I know I'll constantly be wanting to clean the gunk out of the corner of it.
    Dec 27 2011
    San Diego, CA
    This.
    Dec 27 2011
    San Diego, CA
    I just noticed that the angle of my picture above makes my steering wheel look huge!! Like I'm driving a clown car or something.....
    Feb 02 2012
    Colorado Springs
    Phone Mount?
    Now that you mention it, that steering wheel does look huge.
    Aug 06 2012
    Parker, CO
    Looks great --- -more convinced than ever to get this for my allroad.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Can you mount the pro-clip a bit higher, near the vents or is it shaped to only go in the one spot beside the media controls?
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Dec 27 2011
    San Diego, CA
    Quote Originally Posted by treginginco View Post
    Thanks treginginco! Definitely worth it IMHO
    Quote Originally Posted by amz View Post
    I don't think so - the little triangle on the bottom would hit the buttons.....I'll measure it tomorrow and let you know.
    Jan 13 2006
    Houston
    I may have to get this one... and glue a little figure (copilot) or something to the triangle support.
