Results 1 to 15 of 15
    Apr 22 2013
    MS
    RaceChip Tuning?
    2019 Audi RS3|Daytona Gray Pearl|Unitronic Stg 2|APR FMIC| APR 4 inch inlet| APR CF Open Intake| APR Catless downpipe| APR Midpipe| MSS Springs| URUS paddle shifters
    Jan 20 2013
    CA
    because racecar!
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    I would like to see real numbers on a piggy back.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Piggybacks suck. Proven power or not, it's technology that works by manipulating sensor values to and from the ECU.
    Jan 02 2011
    2018 4M Q7, 996 Turbo, 2014 Q5 3.0T
    MN
    Early for April fools isn't it?
    But seriously...skip this shitbox.
    2018 Audi Q7 3.0T: Glacier White Metallic/Black, Prem +, Driver Asst. Pkg, Vision Pkg, 20" 10-spokes - Dadwagon 3.0
    2014 Audi Q5 3.0T: Moonlight Blue/Black, S-Line, Sport Interior, Nav, Adv Key, VAG-com's, 034 Intake tube Wife's Daily Driver - Momwagon 3.0
    2001 996 Turbo: Black/Black, Tip, Diamond Black BBS RS-GT's - Summer Car
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    But if I put this on my APR Stage2+, I'll have even more powah!
    Established Member Two Rings Bus Driver's Avatar
    Dec 09 2012
    Malaysia
    I personally have used the Racechip Pro..impressive power gains in fact I dynoed and got almost the same whp as a remapped car. Only thing is the torque is about 30nm less. That was on factory setting and you can adjust the power incrementally up to a point where you get into limp mode which means that's the max you can get out of the device.
    With the Stronic on Auto, gear changes are smooth but in manual mode it gets a bit jerky during shifts at normal acceleration... During hard acceleration all is good. Had it for about 2 months before I moved to GIAC.
    2010 S4 DSG-ADS- Sports Diff-B&O-RocEuro-AWE Catback- GIAC S2/DSG-P3 Gauge-Alcon 365mm 6pot-H&R OE -Eurocode F&R ARB/Endlinks- 19" Breyton BE- Michelin PSS 255/35
    Established Member Two Rings SCtuning's Avatar
    Jun 15 2005
    Vegas SoCal
    Quote Originally Posted by Bus Driver View Post
    Thanks for the feedback. Most say it sucks without any on hand experience. I was curious also. I have a friend who has an Audi A1 with a tuning box. Drove it and was impressed. I'm sure a flashed ECU would perform better. Just an assumption.
    Posted from the Davespeed R&D facility.....
    Senior Member Two Rings B8A42010's Avatar
    May 15 2011
    Everywhere
    I remember when we tuned my brothers 2g eclipse gsx with a GM maf translator. 4 dials and a wideband gauge and we got the car to run 12.4 on stock turbo housing but bigger compressor wheel (with other mods obviously). The beauty if a piggyback is if u have no way to tune at all or the programs out there are ridiculously expensive.
    Jul 28 2013
    2017 Ford Edge Sport; 2004 Ford Exploder (as my wife calls it) V6, 7 passenger
    Rabat, Morocco
    Has anyone else tried one of these? I'm leaning towards the drive up to Germany once APR does their summer sale, but there is a certain appeal to having the piggyback sent to me and just being able to plug it in - even it if produces slightly less power. Also, with the 6MT I'm not concerned about the shift issues.
    thanks
    Aug 05 2013
    N/A
    Quote Originally Posted by plev72 View Post
    thanks
    If you knew how piggybacks worked, you'd know to stay away from them. Piggybacks work through signal manipulation. They change what the ECU sees in terms of values for timing/boost/fuel and a few other things in hopes that the ECU will alter controls to give produce more power. Alternatively, they also alter the signals going back to the power plant, meaning that the timing/fuel values going to the engine can be increased/decreased to actually fool the engine into doing something the ECU never actually called for. When it's all said and done, you are left with a system that can cause mixed results. An appropriate way to alter engine performance is to alter the original sender of said signals with new values. This is what a standard ECU flash does. You change the maps you need to on the ECU to get the right results. You don't depend upon a man-in-the-middle way of control for the engine.
    Jul 28 2013
    Rabat, Morocco
    At the risk of using the big word of the day, while it dose seem obvious that going direct is better than going through a middle man - I would think that chip tuning has a pretty lengthy history. Is there any empirical (that would be the big word of the day) evidence that chip tuning will damage the computer, fuel system, or anything else with the car? Again, if HP gains are roughly equal, there is something to be said for being able to adjust settings directly instead of having to go through a third party anytime you want to change something - or whenever Audi decides to reflash the computer during a tune up.
    Aug 05 2013
    N/A
    Do what you want. I've run piggybacks as far back as the 90's and I know what they can do and what they cannot do. I also know what they can do in more modern EMSs where some things don't go as smoothly as they used to in the old days. Without having to go into a ton of detail, there used to be a time when EMSs would send data to the engine for it to do one thing and wouldn't care too much about seeing anything back in terms of finite control. For the most part, maps were fairly static and without a ton of variation every single second to the next. As time progressed and EMSs got fancier, it became normal procedure to have a constant bidirectional communication with the engine and its various sensors every single second and multiple times per second even to make sure it can be controlled as conditions changed (be them environmental and/or physical in terms of engine performance). The piggyback systems of then and even now simply cannot and will never be able to control an engine's output both at a performance and safety level as the ECM can directly. It's common knowledge that most piggybacks just increase timing and maybe fuel (sometimes they even lean things out to get more power on certain applications) to do what they do. In such cases, the ECM can and will see this happening via other sensors unless those are also intercepted, but the fact remains... most piggybacks are set at certain values and the makers tell you to change those if you want to, but when drivability and smoothness of the engine is affected, to dial it back. Well, this drivability and smoothness of the engine is the shit mixture of improper fuel/timing being used. It's what makes an engine stumble or "hiccup" in certain situations. Is this the type of tuning you want to run on a modern day EMS?
    Like I said, do what you want. Most people need to experience things for themselves before they understand the real truth behind things. I'm pretty sure Italy is free enough for you to do that if you want.
    Senior Member Two Rings Tyrnnus's Avatar
    Jun 23 2011
    Calgary, AB, Canada
    I would consider it this way:
    How much is a new engine worth? I am hearing $25K over here. Where are piggy backs were more commmonly used? on less complicated engines. and these engines are worth less than $10K. Add it the fact that a new ECU is $1000+labor.
    To me it is like comparing modifying a lawnmower engine vs modding the space shuttle
    If the piggy back units worked well enough on the B8S4, I think there would be more options and more widely used.
    But as Swank said, its your car, your money, and your choice.
    2012 S4, Moonlight Blue, Premium, 6spMT, Sports diff, B+O, Supercharged badges
    GIAC Stg2 w/ AWE Pulley, Roc-Euro Intake, Alu Kreuz
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    I'll just leave this old but good gem here:
    I'll also add that the piggybacks DO NOT work as well enough. Do a search on here for "MTM piggyback" and read the 20+ page thread all the way through that Voltrons Head started. It will bring you up to speed on how well they work in great detail.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
