Results 1 to 36 of 36
    Veteran Member Two Rings silva's Avatar
    Feb 13 2004
    London , ON Canada
    TPMS: Disable error messages and warning lights in Instrument Cluster
    I searched many forums for this and never came up with a conclusive method on how to disable the TPMS warnings on B8 A4s, or any recent Audi model that uses TPMS sensors in each wheel. Therefore, after reading about a few methods that worked on older A6s and A8s, and came up with a method to do it on the 2009 and newer Audi A4/S4.
    In the luggage compartment (trunk) fuse panel, find fuse #1 in the black fuse holder. The black fuse holder is closest to the front, and fuse #1 is the closest to the center of the vehicle.
    Remove the 5 AMP fuse.
    Next, using a VCDS cable, connect to control module 19 - CAN Gateway
    [IMG]www.rsquattro.net/repairdocs/B4A4TPMS/Control%20Module%20Selection.jpg[/IMG]
    Once connected to 19 - CAN Gateway, choose Installation List
    In the Installation List window, find and remove the check mark beside 65 - Tire Pressure. Click Save Coding.
    Close the Installation List window, and close the 19 - CAN Gateway control module.
    Next, open 17 - Instruments control module and choose Coding - 07:
    In the Recode Module window, choose Long Coding Helper:
    In the Coding helper window, select Byte 4 and remove the check mark (check marks not shown in image below) beside Tire Pressure Monitoring (TPMS) Installed:
    Exit the Coding Helper.
    Back in the Recode Module window, click Do It! to save the configuration.
    If coding is accepted, a confirmation dialog box will be shown. Click OK, and close the 17 - Instruments control module.
    Sep 05 2012
    Most Audis use an indirect TPMS system based on the ABS system, as opposed to requiring sensors on each wheel. So if you are getting warnings with different tires you just go into the menus and tell it to store the new pressure reading.
    I think as of 2010 model year all models are using this system.
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Feb 13 2004
    London , ON Canada
    Indeed, most newer (mid year 2010+) Audis are no longer using TPMS sensors in each wheel, but for those that have them, it's always been a bit of a PITA to get rid of those annoying messages in the cluster.
    Senior Member Two Rings Steelman's Avatar
    Feb 26 2013
    Charlotte, NC
    Thanks!!!! This worked perfectly on my '09 A4.
    RS4 Cab - Avus Silver on Black
    Established Member Two Rings sleeper's Avatar
    Dec 23 2009
    salt lake city UT
    Also in my experience i've had a couple times where this doesn't work if there is a fault code already stored. However when i swapped the stock tires back on, cleared codes stored values (basically reset everything to factory settings and start over) and then went through these steps it has worked perfectly every time. (only on the 2009's)
    Nov 24 2014
    2004 Bmw 325CI Convertible
    Jamaica/NY
    Why am I pulling fuse #1?
    Feb 13 2004
    London , ON Canada
    Quote Originally Posted by mrdecruz View Post
    That's the TPMS Module fuse.
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I get that value of this because when it's below freezing mine always seem to go off if I'm on parked in the garage. But I do want to nl know if my tyres are low and if they are too low it will constantly tell you. Otherwise it's always nice to have an additional VCDS info.
    Senior Member Two Rings kmunz264's Avatar
    Dec 19 2014
    Port Republic Maryland
    Okay so this didn't work for me I think its because I got a shop to try and disable it for me but they failed. So when I went into 19-can gateway 65 was already unchecked and in 17 - instruments I couldnt find tpms. So is there a way to reset everything back to normal so i can start fresh? They didn't pull the fuse though so I'm going for a drive to see if it turns off after 15 miles or whatever it is
    Jan 10 2012
    Republic of Boulder
    Quote Originally Posted by kyleowen94 View Post
    Yo Kyle, it didn't work for my '09 A4 either, but I continued messing with it and finally figured out how to get it to work. What I did was pull the fuse AFTER I disabled the TPMS and cleared the codes. So drive around until the TPMS warning goes away, then immediately make all the settings in VCDS, then finally go back there and pull the fuse.
    BTW, typically people that work in shops are complete retards when it comes to this stuff. They never know shit.
    PREVIOUS:
    1991 Audi 200TQ Avant
    2001 Audi S4 Avant
    2009 Audi A4 Avant (click)
    2014 Audi allroad
    Dec 19 2014
    Quote Originally Posted by crash1121 View Post
    Well the settings in VCDS are already made is there a way for me to reset everything? Also when I drive around it never turns off
    Jan 10 2012
    Republic of Boulder
    Another reason why you shouldn't let any useless twats mess around with your car's electrics... I'm pretty sure you'd have to take it to the dealer in order to reset everything. I remember once I took my car to the dealer for an oil change and they did a software update just after I had cleared the TPMS warning. I had do the process all over again and drive down the highway for about an hour in order for the TPMS light to turn off.
    PREVIOUS:
    2001 Audi S4 Avant
    2014 Audi allroad
    Dec 19 2014
    Damn okay I was wanting to go in for an oil consumption test anyways maybe I could get them to reset everything while I'm there. But yeah terrible customer service at that place all they are good for is apr tuning. They order wrong parts fall through on appointments lose things
    Jan 10 2012
    Republic of Boulder
    Damn boss, maybe time to find a new shop! They should be able to do the reset for free, especially if they're doing the consumption test.
    PREVIOUS:
    2001 Audi S4 Avant
    2014 Audi allroad
    Dec 19 2014
    Yeah I haven't gone to them in a long time but alright thanks for your help dawg
    Jan 10 2012
    Republic of Boulder
    No prob dewd, and good luck with the consumption test.
    PREVIOUS:
    2001 Audi S4 Avant
    2014 Audi allroad
    Veteran Member Four Rings jschrauwen's Avatar
    Aug 08 2013
    08 R8 TT, 08 A5 3.2 QTip, 90 300ZX TT 572whp 590wtq, Ducati TT2
    Frankford, Ontario, Canada
    My TPMS never goes out. It's constantly flashing due to using winter wheels/tires with no TPMS sensors.
    2008 A5|Ice Silver|3.2 QTip|Premium Pkg|Technology Pkg|B&O & JL10W0-4 sub|15/20mm spacers|HID Fogs|Ext. & Int. LED's|RS5 grill|AWE/K&N Intake|Quad tipped OEM mufflers|CF Mirrors, Spoiler & Diffuser|Facelift Ecode Tail lights|CR-15 Strut Bar|Ecode headlights|Alu Kreuz|ProdigyWerks 6pot 2pc 356mm front 350mm 2pc rear BBK|Eibach springs
    2008 R8|Ice Silver|R-Tronic|Huffman TT Conversion|Focal/Mosconi stereo upgrade|H&R Coilovers|HRE wheels
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Worked like a charm, thanks Silva! I don't know why others had issues....pull the fuse, disable #65 in 19 and then uncheck bit 4 under the long coding of 17- light went immediately off.
    Cheers,
    Ry-man
    Aug 08 2013
    I just replaced all 4 of my TPMS sensors in my summer wheels on Friday with generic 315mhz ones. Did the reset/remember setting in the MMI and the warning went away with 5 minutes of driving.
    Senior Member Two Rings gt854t5's Avatar
    Nov 09 2015
    B8 Avant Prestige; W211 E500 Designo
    East coast USA
    Hey guys- the above instructions worked for me also (using my ODBeleven unit). I think some folks are getting confused with ressetting the TPMS or DISABLEING TPMS. Most, at least on this thread, want to turn it OFF/DISABLE. (I monitor my own psi regularly). With the firgid temps in NE region of USA, my tire pressure is all over the place. I keep my psi at 36-38 year round, but with single degree temps, it drops so my TPMS is always beeping.
    My procedure was connect ODB11: (1) turn on ignation (or start car if you want); (2) Pull TPMS (5A- first fuse in middle block) fuse; (3) Deselect TPMS under module 65. (4)Then under Control units, select 17-INSTRUMENTS-, Long coding, tap over to byte #4 and Deselect TPMS. You MUST press the "check" icon to accept the code. My light went off in 2-3 seconds.
    I turned off ignition, then restart car and there was No more TPMS lights/sounds. Mine will stay off until spring/summer--LoL.
    '09 B8 Avant Prestige/Dark Beige/RS4 Grille/aFe filter/ECS Intake-hose/SS Lines & Slotted rotors/Red Coils/S5 split-spoke 19s/LED Interior kit/TTRS FBSW/B8.5 shifter/VAG-Com mods.....TBC
    Aug 08 2013
    Quote Originally Posted by gt854t5 View Post
    In the cold winter temps, tire pressures do drop but it doesn't mean you've lost air out of your tires. Your tire pressure "should" rise once you start driving for a while until the tires get warm enough and the air pressure inside will rise and the warning "should" go away.
    Veteran Member Four Rings streamline's Avatar
    Sep 03 2004
    Pittsburgh, PA
    I just tried this on my 09 A4 and followed the same procedure without luck. I did experience an error when deselecting 65 and saving coding on the Installation list, but when i returned it was unselected and removed as an installed button. Any thoughts?
    Ryan
    2009 A4 Avant: Brilliant Black
    2002 Allroad 2.7T: Atlas Grey
    Established Member Two Rings maquino's Avatar
    May 15 2013
    2017 Mazda CX-5 GT
    Boston
    Can someone post a picture in this thread of the fuse location? would be helpful. TYIA
    Edit: nvm. Found it. Worked like a charm. Easy as pie.
    Mar 08 2019
    MA
    Can anyone confirm this method works for the newer cars? Im about to put my winters on and they have no sensors. My summer setup definitely has TPMS sensors so Im not so sure the newer cars use the ABS sensors. Im specifically talking about a 2013 B8.5 allroad.
    2013 allroad Glacier White/Black Sport. Many Mods.
    Jul 16 2018
    Atlanta
    2009 was the only B8 A4 MY in the US to have direct TPMS. So you have no wheel sensors nor any J502 TPMS control module in your 2013.
    Veteran Member Three Rings 98A4TurboAWD's Avatar
    Jan 06 2013
    Charleston, SC
    Has anybody tried this? I'm trying it, but vag com is giving me a security clearance error. Did they make a software update that makes this not work? I'm using latest ross-tech update.
    2018 Audi S4 3.0t - EPL Stage 1 93
    09 Audi A4 2.0t Quattro - Automatic - CTS K04 - ECS HFC & 3" downpipe - Integrated Engineering K04 93 Octane Tune - K&N Filter - S Line 19" Peelers - H&R Sport Springs
    98 Audi A4 1.8t Quattro - Stock - Automatic - AEB
    Jul 16 2018
    Atlanta
    For which module? CAN gateway, address 19, or instrument cluster, address 17?
    I'm still on 19.6.2, until they get it together and start posting an actual change log of some manner, I'll wait on going 20.whatever.
    Jan 06 2013
    Charleston, SC
    Quote Originally Posted by Smac770 View Post
    Anything that requires long coding. When I click "Do it!" on any screen I get the security clearance popup. I'm guessing they want me to pay for ross-tech? I use the free version with their cable.
    Jul 16 2018
    Atlanta
    VCDS is free if you have their cable. I assume you mean you have some knock off cable or generic cable and using VCDS Lite?
    Yeah, you're going to need a real tool to do the real work.
    Jan 06 2013
    Charleston, SC
    No, it's a legitimate ross tech cable that is tied to my VIN. I will get a snap shot of the error later.
    Nov 20 2013
    Montreal Canada
    I'm trying to disable TPMS as well because my MMI isn't working anymore.
    I removed the fuse and tried to disable TPMS but also got a security message.
    Hope someone can provide some guidance.
    Thanks.
    Jan 06 2013
    Charleston, SC
    I emailed ross tech. I'll let you know what they say.
    Jul 16 2018
    Atlanta
    You guys using the new version 20.4.1 or the prior 19.6.2?
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by 98A4TurboAWD View Post
    Not trying to be an asshole, but are you aware that if you hit Security Access - 16 and put your cursor over the box, VCDS will often give you the code in a pop-up? Not sure it works on every year/module, but it works often enough that I've never wondered how to get past that screen on my last 4 Audis.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jan 06 2013
    Charleston, SC
    Quote Originally Posted by mtroxel View Post
    Bro, that was the answer. I'm back in business. Hell yes. Thank you.
    Veteran Member Three Rings Aris3.2's Avatar
    Mar 13 2020
    New Jersey
    Worked as per instructed 2 min job done no more tpms error.
