So I was following along in the AudiEnthusiasts.com site and couldn't get the ambient lighting working following their steps. something was missing because even when I did everything correctly I looked back in the car's system settings on the mmi and it always had the "interior lighting" option greyed out.
So I did some snooping around and found that if you follow the directions he gives PLUS in the hidden menu select car>carbusassignment> interior lighting *change from unassigned to "[CAN Komfort] 1/9". Reset the mmi and you're good. Not sure if others had this issue but thought I'd post just in case.
