Results 1 to 24 of 24
    Active Member One Ring acesys1200's Avatar
    Dec 07 2013
    94 Civic GSR 2.0L Turbo & 91 Civic Si LS/Vtec
    Clovis/NM
    2.0T FSI power limitation???
    So after searching and reading other posts the main limits of this engine is rods limit pushed at 350hp max. HPFP is good for 200HP in stock form, LPFP idk when the limit is reached for sure but after reading Vizi thread it is a problem at just above 400HP. Correct me if my understanding is wrong thus far and is the DW300 LPFP the fix to that? Has anyone tried using the new 400lph pumps? My real quest in this was to find out what is needed to go 500HP+ without needing to be a rich person to get there. Would anyone be able to help point me in the right direction, maybe even some links? I'm new to the direct injection german engineering world but have been moding and tuning for several years now. Any help is much appreciated and thanks in advance. BTW any info pertaining to the quattro tiptronic limits would be helpful as well.
    Dec 07 2013
    Clovis/NM
    Sorry I ment the stock HPFP is good for about 250HP
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Quote Originally Posted by acesys1200 View Post
    If you have a Tip you will never make it to 500HP, they cant handle much power you will need to do a 6 speed swap. Also, to make it to 500hp you will need to be a rich person, because no one has done it yet. There is maybe two people on here that have made it past 400WHP http://www.audizine.com/forum/showth...ig-Turbo-Build is one of them. Read his built from beginning to end and you will have a good understanding where all the limitations are of this motor. And what has to be replaced in order to get above 400HP
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    2.7 swap.
    /thread
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Dec 07 2013
    Clovis/NM
    Well I'm to new to post to drumnjuny's thread but it seems the main hold up in power is the LPFP and I have to ask why ppl keep using stock or OEM upgrades like the S3 pump to the LPFP instead of using say a walbro 400lph pump and just replace the pump instead of the whole unit? His car is a beast of it's own with it's own issues but an engine is an engine just differences in technology within the engine. Air + fuel + the right degree of timing = power. I have a lot of questions and ideas but so new to the Audi engine designs, I would love to chat with a Audi vet and get caught up. I'm sure I don't have any new ground breaking ideas but I don't understand the real hurdles needing to be jumped either.
    Senior Member Two Rings ROH ECHT's Avatar
    Jul 20 2011
    PNW
    There are few over 500whp and those have internals and fueling mods. Roughly around 375whp is the mark to upgrade the internals. I know quite a lot at 350 to 370whp on oem internals.
    To get to 500whp....big turbo, stronger internals(cams, rods, and perhaps pistons), upgraded fueling(both lpfp and hpfp), upgraded valves(DV and WG) and sensors(MAP for sure), and of course larger intake, exhaust, and boost piping. BSH,ATP, 034 motorsport, Frankenturbo, Integrated Engineering, LOBA are all sites to visit in your search.
    K04 PLAY...`07 GTI/GIAC H.O. K04 & DSG tunes/Autotech HPFP/S3 INJ./S3&FORGE FMIC's/TECHTONICS TurboBack/AWE DV/Whiteline Performance springs & W.A.L.K./BSH MOUNT's/NEUSPEED INTAKE&THROTTLE BODY/ECS ST3 BBK/H&R RSB&FSB Voting for my Dragtimes; 2007 Volkswagen GTI : 12.823 @ 112.050 MPH...ZOOM DIS!
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by ROH ECHT View Post
    In the B7 community it's said that 300whp is pushing your luck on stock rods. Several people have bent rods below 350. Obviously the torque onset has a lot to do with how long they'll last but I still wouldn't push my luck if he's going for big power anyway.
    -Hayden
    Dec 10 2011
    CLT | MKE
    Well I'm to new to post to drumnjuny's thread but it seems the main hold up in power is the LPFP and I have to ask why ppl keep using stock or OEM upgrades like the S3 pump to the LPFP instead of using say a walbro 400lph pump and just replace the pump instead of the whole unit? .
    Most people use S3 injectors. I don't recall anyone using the S3 LPFP. A Bosch 044 or Walbro LPFP will work great.
    -Hayden
    Jul 20 2011
    PNW
    That is quite odd as even APR stage 3 kits well exceed 300whp on stock rods.?.?.? And I've heard of no 2.0t fsi's encountering bent rods at 350 whp yet, but if you say so...
    My previous tune was 285 whp and 364 ft*lb torque with no issues. Haven't dyno'd the current tune, as it is only one month new, but there is more power for sure.
    Dec 07 2013
    Clovis/NM
    Thank u guys for the responce
    So others have used an aftermarket pump with success huh? The best HPFP has been proven to be what? Whats the deal with the cams, the profile wont allow enough air? I thought the pistons were already forged stock, anybody know what the limit would b on the tip trans? Anybody try using aftermarket HPFP's? I just ask cause I seen a few on aeromotives site, don't remember the spec's but thought I would ask.
    Self fab'ing, building, & tuning
    Jul 20 2011
    PNW
    The one you keep an eye on to preserve the cam follower. Autotech is good enough but you must take care during installment. HPFPUpgrade has a nice option. APR is reliable. KMD/REVO was at first to be avoided, but some research may prove it to be much better since the involvement of REVO with KMD to control their early quality issues.
    Dec 07 2013
    Clovis/NM
    Another question, the Maestro has stage 1, 2, & 3 base maps, does anyone know the HP ratings for these maps and what all gets changed? Like the boost curve, boost presures, timing, ect.? Also I would guess supporting mods are the same as APR's tune levels?
    Dec 07 2013
    Clovis/NM
    Really, nobody knows anything about this? I must be posting in the wrong place
    Veteran Member Four Rings flatsick's Avatar
    Oct 25 2012
    991 Porsche 911
    Middletown, Delaware
    your goal is unattainable...that being 500+ hp without having a shitton of money to throw into it. You are going to need a built motor (pistons built around the turbo system, aggressive intake and exhaust porting, fortification in the rods, etc,,etc), significant computer modifications (something which noone has knowledge of for that type of HP) or a standalone, a custom turbo setup with a to4e+ turbo if you want efficiency, a transmission that wont break all the time, fuel delivery modifications... I used to build drag import cars, it piles up quickly. 400 HP is more realistic and even then with these cars you will probably have issues.
    as a side note, aeromotive is the only fuel delivery system i would use but way high for only 500hp. I have used them on several high hp cars and they make a quality product.
    Just as a guestimation, here is what i think you will spend at minimum
    Built Engine: $3000
    Fuel delivery system: $1000 (pump, lines, injectors, possibly a custom rail, pressure regulators)
    Custom Turbo system: $4000 (a good turbo will cost you around a grand along, then you have to think about intercooler systems, piping, wastegates, blow off, custom intake)
    Computer: $2000 I used motec/haltech/aem standalones, I have absolutely no idea how they would integrate with a car like this, between dyno and tuning time...rack up the $$$
    Transmission: If you are using a TIP, there is going to need to be some programming, fortification in the torque converter and even then you will probably destroy them quarterly if not shorter.
    Start your budget at $10 grand and factor in 20% for fuckups and specifics... Its not an easy task. It would be fucking awesome however.
    Jul 20 2011
    PNW
    Have you checked in the UK:http://www.mk5golfgti.co.uk/forum/in...oard,33.0.html
    Look up John Hurdy aka: Hurdy to point you in a direction concerning Maestro.
    My new DM K04 tune is quite a nice bump from the old GIAC K04 HO tune I had.
    Boost:
    Old giac tune did 0 to 120 mph in 15.8 seconds
    and the new DM tune did it in 13.3 seconds:
    http://www.youtube.com/watch?v=icftiiZr60A
    Established Member Two Rings SkillzVrt's Avatar
    May 03 2012
    Carson, CA
    That's for you to figure out if your a "tuner". If your not even familiar with the German Cars get familiar with them.High pressure fuel system as well as the engine FSI,TSI, TFSI. Modding these cars will be a lot different from modding your Honda's.
    Active Member Two Rings MadRacer's Avatar
    Jan 25 2014
    Bulgaria
    What is the limitation of the pistons ? What about the SMIC ?
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Y'all have to remember that you can obtain higher whp with fwd than awd because awd has more power loss through the drive train. So if the engine is making 350 bhp a fwd will see more of that on a dyno than an awd could be the difference of the numbers between y'all
    What ever makes sense go with the opposite and you got it
    Jul 20 2011
    PNW
    Quote Originally Posted by schirm View Post
    Rich...yes. Not done yet...no.
    525hp 2.0t fsi in 2007...Time Attack prepped:
    http://www.youtube.com/watch?feature...&v=oRH5UFeNYHk
    You would, at least, need race connecting rods along with a turbo to get there reliably...oh, and lots of patience to wait for the lag to end ;)
    more info link: http://www.audizine.com/forum/archiv.../t-219106.html
    My K04 is plenty for the 2.0t fsi
    3__whp? w/DM K04+tune (no internals) no dyno or 1/4 pulls yet: http://www.youtube.com/watch?v=icftiiZr60Athis is 2.5 seconds quicker to 120mph then the giac k04 ho tune was!!
    http://www.youtube.com/watch?v=a8VGg...OHLU7IwZaFWg_A
    This was when it was 290whp w/giac K04 HO tune (no internals): http://www.youtube.com/watch?v=FnEKOLOUS3k
    Veteran Member Three Rings 2010b8a4apr2's Avatar
    Jul 31 2013
    navarre fl
    tuning companies have told me the tsi's can hold a bit more power but not much more. i have a b8 a4, so fuel components are upgraded, but has tsi setup plus valvelift on head. made 304awhp, and 357awtq. i know i can make more, but im sure i should do rods soon
    Senior Member Two Rings Krmass25's Avatar
    Aug 18 2013
    AMERICA
    Thumbs up
    Look at Integrated engineering. They sell performance shortblocks and you can go even more wild.
    Get their best TFSI block and add H beam connecting rods.
    Get the best head with supertech springs and ferea valves.
    Do the 1.8T oil pump conversion,
    billet timing gear
    arp bolts all over
    fluidampr
    all fueling upgrades
    replace prop shaft and all half shafts
    send tip trans to 517 transmission and have them modify the valve body, upgrade the torque converter
    put all sold mounts on the car
    huge exhaust and maybe even custom hand welded tube headers to replace the iron type manifold
    upgraded intercoolers or single FMIC
    billet valve cover (you will blow the plastic one)
    all big intercooler piping
    port maf
    GTX2876 TURBO with manifold for 525 HP
    CT5 fuel controller with water/methanol injection for 100HP
    tune it all and see what happens
    With that setup technically nothing should break in the motor and it should have a possibility of having more than 525 whp while spraying... technically...
    Established Member Two Rings lowlife89's Avatar
    Jun 01 2013
    EU
    Or buy an S4, exhaust+FMIC+tune and call it a day? there's zero point in dumping a fortune into an A4.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by lowlife89 View Post
    Shit, wish someone had told me this years ago...
    -Adam
    Jan 06 2012
    Riverside
    I knew better and did it anyway..
    Factory power always better than aftermarket power.
    2014 Audi A8L 3.0 TDI - malone stage 2 305hp/490ftlb
    2013 VW MK6 Golf R - APR 302hp/297ftlb
    2008 GTI EFR7163 - 480 whp
