Results 1 to 40 of 57
    Veteran Member Three Rings socialpro's Avatar
    Sep 26 2013
    2023 RS6 || 2022 XC60
    scottsdale, az
    2013 S4 Brake Squeal Resolved?
    Started getting the dreaded brake squeal when its cold outside at low speeds. I searched through forums and found TSBs for older S4s (2010/2011), but have seen nothing on the 2013+up. Anybody experience this and able to get it properly resolved through the dealer or to no avail?
    Had the same thing on my 335 (common issue) and even after dealer replaced brakes it came back within 500 miles, and I ended up throwing aftermarket pads on and had no squeal after.
    Should I even bother with seeing dealer on this or go same route of aftermarket pads? Seems like a waste of money as the pads on the S4 now stop great and car only got 13k miles but that squeal is killing me. Please Help!
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    its the pads and the temp, just swap them done
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Sep 26 2013
    scottsdale, az
    im 90% sure its front pads, is that correct?
    and by temp you mean temperature? I think once they warm up or if its warmer out there is no issues.
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    Do the 2013'2 still have the brake squel issue? WTF Audi the car is 4 years old, fix this shit
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by socialpro View Post
    yes the front pads and yes when the pads heat up or it is warm outside they go quiet
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    no squeal on my previous B8 or current B8.5.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Sep 26 2013
    scottsdale, az
    Quote Originally Posted by staticuxo View Post
    Yeah seems like its hit or miss on all models of S4. Some pull out of dealers lots brand new S4s (based on audizine threads) and get the squeal other times its nothing at all for the life of the car. Guessing it all depends on very minor tolerances in manufacturing / installation that produce those results. And majority of cases is something in between where it starts at some mileage a year or two after car is new. And seems like temperature plays a big factor in this as well.
    Leaning towards the throwing in a new set of pads and being done with this as ultimately that seems to be the only solution with lasting results. Might inquire if there is a TSB for the newer models but feel like its going to be typical dealer BS when it comes to brakes ('high performance vehicle / brakes / typical on all models, etc')...'nothing we can do'
    Established Member Two Rings Maltitol's Avatar
    Jun 27 2012
    Rockville, MD
    I get a fair amount of brake squeal on my '13 too . It definitely only happens when its cold outside, but "warming" the brakes doesn't seem to help much for me. The only temporary fix I found is to go from 60-0 as fast as possible. Seems to clear the problem for the next few trips or until the next morning. I have 17K on mine, and I don't know if Audi will warranty the brakes at that many miles.
    Senior Member Three Rings millerrh's Avatar
    Jun 15 2013
    Austin, TX
    My wife has been complaining about brake squeal on her 2013 Q5. Different brakes for sure, but maybe same root cause?
    2014 S4 Premium Black Pearl | 6MT
    Sports Differential | 19" Peelers | B&O Sound | Carbon Atlas Inlays | CF Supercharged Badges | Bilstein PSS10s | Eurocode Alu Kreuz | Eurocode USS Sways & Endlinks | Roc Euro Intake | AWE w/Res DPs, 102mm
    Mar 04 2011
    New Jersey
    The front pads were replaced on my 2011. The squeal is completely gone.
    Established Member Two Rings srk's Avatar
    Sep 27 2005
    Atherton, CA
    One thing I actually hate about Audi's ( actually all German cars) the break pads creates a hell of a lot of dust yet they squeal. If you put after market pads on, the dealer throws a fit and doesn't want to touch anything about the brakes.
    For my B7 I had replaced the front pads with an aftermarket one that had a whitish powder and left the rears stock. Only after two days of driving the rear wheels would be gray and front would still look clean...
    2014 S4 S Tronic | Monsoon Gray | Nav | ADS | Sports Diff | B&O | Carbon Inlays | 19" Peelers
    Established Member Three Rings LakeShow's Avatar
    Apr 26 2013
    Long Island, NY
    Yes, extreme squealing! Good I thought I was the only one!
    Sep 26 2013
    scottsdale, az
    Just a quick update --- brake squeal keeps getting worse and worse. It is not temperature dependent anymore (as it was when I first got the squeal it was only bad when it was cold out), and brakes pretty much squeal all the time below 10mph at various pitches and it was driving me NUTS!
    Called the dealer to ask about brake squeal - they said what I expected them to say- its very common on all audis, sometimes having A4s, S4s, S6s, S7s etc right of the delivery truck squeal as they take them off, as all audis use same brake pads (?). They said I can bring the car in they will look at it, probably apply some anti squeal paste etc...but did not guarantee the issue not returning, and based on the experience I had with BMWs with the same issue and even bmw swapping out brake pads the squeal comes back within so many miles.
    Ordered a set of akebono ceramic pads last week as I had good luck with them on my previous cars. Just got them installed will keep update whether that resolves brake squeal for good. And hoping less brake dust to boot (stock pads are horrible in that regard as well).
    Just weird to think that brake squeal is still a concern and a very common occurrence on modern high - line cars in this day and age. I would have guessed that pad and rotor technology / materials would of been beyond perfection after 60 or so years of iteration.
    Feb 12 2013
    Boston, MA
    I was at my service center and there was a poster that had a picture of a brake and it said "when servicing brakes, insist on OEM Audi Parts", I found that pretty funny given how bad OEM pads are for dust.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Both my 2010 and my 2014 have had brake squeal. Not so much on the 2014 so far. BUT, when I did take my 2010 in and complained about it, they did some type of perfunctory adjustments that did seem to make it a little better. They also gave me a pamphlet from Audi telling me WHY they squeal. Pretty much saying that in order to get the best braking performance, they had to use a compound that has this side effect. Really, I would just replace the front brakes with ceramic(Akebono) and get rid of both the squeal and brake dust.
    Apr 19 2012
    Herndon/VA
    2013 s4 17k miles. Brakes squeal embarrassingly loud sometimes when it's really cold. Have a few more months of winter left so I guess I'm just going to have to put up with it. This was common with my G35 too so I'm kind of used to it. Didn't think I'd have to put up with it on a 60k german car. Oh well... I hear BMWs can be worse! Don't even think I'm going to bother with fighting the dealer or this. I am still wondering how to deal with the steering issues right now.
    Sep 26 2013
    scottsdale, az
    Quote Originally Posted by Dr GP View Post
    Yep exactly what I did. Swapped the front pads with AKEBONO today, not a single squeal now (time will tell if anything appears), and I would say brake performance is 90% of the Audi OEM pads feel. They feel slightly softer and initial bite is not as strong, but from previous experience and other threads brake performance should get better over time.
    Overall an easy not overly expensive ($80 from tire rack) 'permanent' solution mod to the annoying brake squeal.
    Veteran Member Four Rings achilleas101's Avatar
    Mar 09 2010
    2015 Acura RDX
    Falls Church, VA
    just experienced the squeal on my '13 with 7300 mile on it, last night. it was about 20 degrees outside. barely noticed it, so it wasn't as bad as i've had before on my old A4 that i'd put Hawk ceramics on. those puppies squealed like i was a semi with air brakes, but only happened in the hot months. so it's weird that these do it in the cold.
    Gone but not forgotten:
    2013 S4 Imola Yellow | Black leather/Silver Alcantara | 6MT | B&O | Sport Diff | Silver 19x8.5 Avant Garde m550 | XPel Ultimate full hood/fenders | Eurocode SS
    2003 A4 3.0 6MT;
    1998 Acura Integra GSR 5spd
    Gone and most likely in a junk yard somewhere: 1990 Toyota Tercel
    Established Member Two Rings kstrike155's Avatar
    Danbury, CT
    I had the squeal for a while and kept complaining to Audi about it. They insisted that it would go away in the warmer months.
    July came along and it hadn't gone away, so I mentioned it at my 35k service. They took a look and found that a couple of the pads had cracks in them. The dealer replaced all 4 rotors and all pads under warranty for me.
    I couldn't believe it (thanks, Audi!), and it hasn't squealed since (I did get one little peep out of it the other night, but it was close to 0F outside). Currently at 55k.
    2018 Audi S4 Premium Plus
    Daytona Gray - Black optic package - Fine Nappa leather package - Carbon Atlas inlays - S Sport package - Navigation package - Dynamic steering
    Senior Member Four Rings dbX79's Avatar
    May 24 2012
    2011 BMW 328i Coupe
    Atlanta,GA
    I noticed it on my last A4. Now I have a S4 and it's been squealing more and more. I think cars can hear it easily. Kind of embarrassing really. I'm hoping there is a good reason for the squeal like the brake pads are made out of a better material for braking. The SA says it's normal during cold weather.
    2013 S4 Ibis White | Black Nappa Leather | DSG | MMI Navigation Plus | B&O | Sports Differential |Carbon Atlas Inlays | 19" 5 Spoked Peelers | VAG Com |
    Senior Member Two Rings RedSox S315's Avatar
    Jul 09 2013
    Bay Area
    I just started having this problem. It's only happening when its below freezing outside and braking from 10-0 mph. I only have about 9500 miles on the car and I'm surprised that this is happening already. Should I take it to the dealer and see what they say?
    2017 S6
    2014 S4 - [SOLD]
    Sep 22 2013
    LOL What the fuck??? I have the same problem on mine, 12,000 km now and he literally said the exact same thing.
    Wait so, this squeaky thing isn't covered under warranty?
    Feb 26 2014
    2011 BMW E93 M3, 2011 Ford F350, 1995 MB E320 Cabriolet, and a bunch of old toys
    United States
    I got horrible brake squeal on my '12 S4 from about 5k miles on...along with extended cold cranks. Of course ze Germans say "cannot replicate".
    Veteran Member Three Rings barbear1978's Avatar
    Jul 07 2016
    'murrca
    geezus will the hits never end... 2015 S4 w/ 12k miles. 25 degrees out and the brakes are squealing like crazy. people stare... audi needs to fix this shit.
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Quote Originally Posted by barbear1978 View Post
    Stock pads are the problem. Get new pads, preferably ceramics - squeal will go away
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    I changed to ceramics, still squeals. It's not as loud, but happens more.
    Mar 24 2015
    Denver
    Hmm, mine haven't made a peep since switching, I did replace rotors as well though. Maybe a regrease would help?
    Jul 07 2016
    'murrca
    my problem is, why am i and others having to deal with this on a $60k car? it's only 8 flippin' months old. $20k car? got it; its a part of the package. but these vehicles are supposed to be built better than that.
    Aug 12 2013
    Lexington KY
    Two options for brake squeal:
    1. Bed those damn things: Go from 60 to 5mph with hard almost emergency braking. Don't lock them up but as hard as you can. Do this 3 - 4 times to heat up the rotors and pads and burn off any residue or junk on them. Don't come to a complete stop while they are hot or you'll transfer more pad material onto your rotor. Do this 3 -4 times without stopping and then coast and let your brakes cool off. Once cool, you should be good to go for a while. Called bedding your brakes.
    2. Flip those crappy oem brakes out. I went with Akebono brakes. Unless you are super meticulous, you can't tell the difference. Innitial bite might be a hair less, but you have no brake squeal and no brake dust. 2 problems solved for basically $50. I just did my fronts. Do it yourself too. It's super easy to do.
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    I getting ths on my 13 as well.
    What is the best front pads for low dust and sound?
    Do we need to change out the rotors with pads?
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Akebono brakes are really good and if the rotors are not worn then just replace the pads. I just did the pads and the squeaky brake syndrome stopped. If you plan to track the car then I would replace both...
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Quote Originally Posted by ojmcneill View Post
    This ... in addition to using CRC Disk Brake Quiet when installing pads. Although you may get some squealing when the weather gets cold, it will be limited. Proper bedding is a must.
    Dealerships would save money from time spent dealing with this question, if they either properly bedded the brakes after each brake job they did or provided the customer with the proper procedure indicating it will significantly reduce squealing.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    I had mine replaced (rotors and pads) under warranty at 20k under Factory Warranty. If it squeaked again, my SA was going to submit fit Q5 calipers, but unfortunately the problem hasn't returned lol. If you're under Factory Warranty still, they will cover replacement (was only the fronts that were replaced).
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Established Member Two Rings CraigAudiS4's Avatar
    Nov 16 2016
    Olney, Maryland
    2015 S4 21,000 Miles. Mine just started squealing the other week when temperatures went below 30, went away when it got warmer and went a away again when it rained. Only does it under light pressure such as when in slow traffic.
    Service in a few months so I will see if the dealer can fix.
    2015 S4 Phantom Black with RS4 Grill, 19" stock Rims with Dunlop Signature HP Ultra High Performance All Season Tires, Painted Mirrors Black and still 100% stock Engine.
    Mar 21 2015
    Quote Originally Posted by CraigAudiS4 View Post
    They can't fix it, do yourself a favor and get different pads now. Don't waste your time at the dealer for this.
    Apr 05 2016
    Portland, OR
    This.
    I finally gave up on mine. My pads have 70+% life or so left in them, they only started squealing in <40 deg weather.
    It has been below freezing here for the past week. I can no longer stand it, 3 of the 4 corners are squealing worse than a city bus. Kill me.
    Pads, SS lines and new fluid should arrive next week. Haven't decided if I want to do rotors too as mine are still in good shape. Ugh.
    Geoff
    Oct 20 2014
    Pittsburgh, PA
    Actually my local dealer fixed mine, as I said in my response a little higher up in the thread. Got me brand new rotors and pads at 20k miles (front only was squealing) no charge. All under warranty. At 35k miles now and no issue this winter. Basically free brakes and the only issue was having to drive a crappy loaner for a few days and two visits. First visit they replaced the pads only, second was rotors.
    SA said there wasn't a TSB, but was a known issue. Dealer had to send an audio recording of the brakes squealing to AoA for warranty approval, but I had no issue or need to push either my dealer or AoA at all. So if your dealer is lazy then maybe you might have to push lol.
    Good luck!
    Previous:
    Senior Member Two Rings osspasha's Avatar
    Sep 18 2013
    There is a TSB for brake squeal, my dealer completed the TSB on my 2013 S4 and the brakes are really quiet even in -40C calgary weather. i will ask my service advisor to pull the TSB number when I go pick up my car for a different TSB (engine rattle tensioner and chain)
    2013 S4 B8.5
    Don't let fear and common sense stop you
    Danbury, CT
    Quote Originally Posted by jokingjimmy View Post
    Same here, as I also mentioned above. Dealer replaced mine at 35k miles. I'm now at 82k miles. Very seldom squeals. And, hey, free brakes!
    Mar 21 2015
    The few of you got lucky then. I wouldn't want oem pads if they did replace them for free anyways.
