it could be the tune , here read this from the s4 tuning wiki
IAT effect on requested boost
ME7.1 will adjust the specified load limit depending on IATs. As IAT's go up, ME7.1 brings the max boost up a bit so that the driver can't tell that the car is slow in hot weather. It can do this because the stock boost curve is relatively conservative, and there is plenty of headroom. Also, at some point, if IATs go high enough, max specified load is pulled to prevent knock.
KFTARX - IAT correction for maximum specified load
However, if you are running a lot of boost, and always want maximum performance, there is no point in increasing boost when it is hot, let alone reducing boost when it is cold. Also, as IATs rise, even with a perfectly flat KFTARX and LDIATA (see below), you will see more requested boost because the ECU knows that a higher P/R is required for a given cylinder fill (PV=nRT for you thermodynamics nerds out there). It is unknown if there is a table for that calculation. To compensate, you may want to taper KFTARX across the board as IATs rise to keep your requested boost sane. In particular, be aware that the maximum requested boost is slightly above the maximum MAP reading. Readers who understand PIDs should recognize that really bad things happen when the measured output cannot reach the setpoint...
In other words, the tune can be tuned to have less boost when the car is cold....
and yes our cars dont like mbcs, again due to the ecu and the tunning , the psi is set by rpm threshold and mbc works a bit different
