Results 1 to 9 of 9
    Veteran Member Three Rings Number54's Avatar
    Dec 04 2007
    Switzerland
    Dipped left headlight
    I sometimes get a "Dipped left headlight" warning on the dash. Its accompanied by a light-bulb symbol with a cross through it, that goes out after maybe 3 minutes of driving.
    The left headlight is indeed out when I get the warning, but sometimes it is fine. So the headlight failure is intermittent.
    Does anyone know what's going on? Is my headlight bad? Can I change just the headlight bulb? Or is there some electrical connections that I should check? I don't know how to start to diagnose this problem.
    Thanks.
    • Audi A3 3.2 Quattro (8P)
    • Porsche 911 GT3 (996)
    • Audi RS4 (B5)
    Senior Member Three Rings gregory.fazekas's Avatar
    Mar 09 2013
    2002 Audi Allroad, 2011 A6, 2004 B6 S4, 2015 Range Rover Evogue
    Lavallette / New Jersey
    Chances are either your bulb or ballast is going bad. Swap the bulls from each side and see if it follows the bulb or stays on the same side.
    Jan 30 2007
    2014 Lexus IS350, 1988 Porsche 944, 2008 Porsche Boxster, 2001 Audi TT Quattro
    Greenville, SC
    My S4 had intermittent dipped headlight for months. Was worried that it was more than the light itself. Ended up buying a $50 bulb from Amazon, replaced bulb... works great now.
    Tom
    2014 Lexus IS350 (present), 1988 Porsche 944 (present), 2008 Porsche Boxster (present), 2001 Audi TT Quattro (present), 2006 Audi S4 (past), 1998 Audi A4 (past), 1975 Audi Fox (past)
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Mine's been that way since I bought the car. I requested it be "adjusted" several times by the dealer over the last 2.5 years. The last time I insisted they take a look at it. They did and told me that it was that way from the factory on purpose so as to lessen the effects of blinding oncoming drivers. I don't know that I believe a word of that. However, my headlights do adjust (move up down) when turned on and that seems to be the "natural" position of that headlight after the initial adjustment so, who knows? Every time I drive in the dark it makes me batshit crazy and I keep swearing I'm going to do something about it...but I never actually do.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    You know its super easy to adjust them right?
    You can still manually adjust the headlight level and direction even on the adaptive headlights.
    after my accident they never adjusted my headlights and my right one was way to high.
    Look at the light housings under the hood. there should be a white cap and a black cap I think... I will take a picture if need be, turn with screw driver and headlights adjust.
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
    Dec 04 2007
    Switzerland
    Ok, thanks everyone. I'm going to swap the bulbs left/right and see if the issue switches sides.
    Really hoping for a bad bulb... I will report back when I get some results.
    • Audi RS4 (B5)
    Active Member One Ring 944Fuzz's Avatar
    Feb 01 2019
    2005 B6 A4 3.0, 79 jeep j10 401 6.6L V8, 98 jeep tj Sahara 4.0, 2004 dodge Durango HEMI, 02 jeep wj
    Concrete, nd
    Ballasts are kind of expensive as far as I can tell can a guy go from projector-beam HIDs to regular halogen bulbs indifferent housings or am I just wishing for a less expensive option
    Fuzz
    Feb 01 2019
    Concrete, nd
    I'm aware that this thread is kind of old but this is a current problem that I am having the intermittent dipped headlight turning off and back on
    Fuzz
    Jul 15 2019
    Southern California
    I had an intermittent Dipped headlight issue on my A3 3.2 Quattro with Auto Adjusting headlights. I took it to Audi multiple times and they couldn't figure out the issue, when the headlights dipped I would sometimes have only one dip sometimes both sometimes one than the other, but if I turned my headlights off and turned them back on they would both come back on.
    I replaced ballasts and bulbs, I had them properly adjusted and everything, it turned out the wiring inside of the headlight assembly was actually brittle so the wiring was exposed inside of the housing and it would cause a short every once in a while and cause my headlights to dip. I ended up rewrapping all the wires inside of my headlights it took a while, but saved me a bunch compared to buying new headlights and compared to having Audi do the work for me :)
