Results 1 to 19 of 19
    Oct 21 2012
    2004 Saab 93
    EPC Light but no Check Engine?
    09 A4, today I had it in sport mode to pass this horribly slow driver here in seattle, I punched it when getting on the interstate and the car kinda of just went limp, the epc light came on but the car kept going, obviously with less power. I drove the rest of the way home, I stopped and started it again, the epc light is still on but I have no check engine light. I do have one of the B8's with the oil consumption issue that I couldn't get fixed as the dealership wanted 4K to do the work as it was used and out of warranty. Is it common to get the EPC light without getting a check engine light? This week is pretty brutal for me and I don't think I will have time to take it in, any ideas or suggestions?
    May 16 2008
    WA
    EPC usually means there is an electrical problem of some sort. Try checking it for codes, it should list what is causing the EPC light. CEL is usually more the mechanical/emissions side of things.
    P.S. Yes, Seattle drivers are slow and oblivious 99.999% of the time
    Oct 21 2012
    2004 Saab 93
    Thanks for the reply, will I be able to read the code with my general ODBII scanner or will I need to go to dealer to get VAG read?
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    EPC could be a coilpack misfire
    [B]Current: Shopping now....
    Oct 21 2012
    2004 Saab 93
    Is there an easy/quick way to clear the epc light just on the off chance it was just a fluke?
    May 16 2008
    WA
    Quote Originally Posted by jmcgeejr View Post
    I don't know for sure, but I woundn't be too hopeful lol The drive By Wire system often has a lot ot do with the EPC light (potentiometer, throttle body, etc), maybe that has something to do with it since you mentioned it happened after punching the throttle to pass
    Quote Originally Posted by k9lovr View Post
    I am not sure about the B8s but in the older B5s and such, misfires usually caused the CEL light to flash.
    Pull the negative battery cable off for 30 seconds, might need radio codes and such afterwards.
    Oct 21 2012
    2004 Saab 93
    Quote Originally Posted by getslideways View Post
    How do I get the codes and such that you speak of before hand? Are you sure the 2009 actually uses codes? I have the MMI=FEUX Symphony one that looks like mmi but isn't.
    May 16 2008
    WA
    No idea about the B8s. Maybe they don't use radio codes. B5s did, and they were usually written on a card in the owner's manual portfolio thing
    May 16 2008
    WA
    According to this thread you either don't have a radio code, or if you do and it asks you, the default code is 1234:
    http://www.audizine.com/forum/showth...-my-RADIO-CODE
    Oct 21 2012
    2004 Saab 93
    According to this thread you wither don't have a radio code, or if you do and it asks you, the default code is 1234:
    Cheers mate!
    May 16 2008
    WA
    Report back letting us know if it was just a fluke or not.
    Oct 21 2012
    2004 Saab 93
    Tried the battery disconnect, waiting 30 seconds, pressed brakes to discharge, started up, date and time are wrong, no radio codes asked for but also EPC light still on. I guess I will be contacting the mechanic, this hands down has been the worst car for luck I have ever had in my life :(... Just tried again still no dice,.
    Jun 26 2009
    Bremerton WA
    Any autozone will scan codes for free. Sounds a little like a P0299 code for turbo underboost. That is pretty much the throttle feel I had as well.
    VMR 710's, APR software, Eurocode HFC
    Oct 21 2012
    2004 Saab 93
    I don't think it's a P0299, I actually had that when I first bought the car it was due to a bad turbo, this was something totally different feeling and with the P0299 i got a CEL with this no CEL just the EPC light.
    Oct 21 2012
    2004 Saab 93
    So I got my odbII scanner (it's the automatic tool fyi, which I quite like) anyway since there is no CEL it doesn't report a problem, yet the EPC light is still on as well as it seems to be shifting oddly, like a hybrid between sport and normal. I guess I will be swinging by the dealer tomorrow.
    Sep 26 2013
    San Jose
    +1 Underboost also generated CEL for me.
    2012 Stronic | Sports Diff Pkg | Chipwerke Pro | aFe Pro Dry | Forgestar F14 18x9 | EBC USR Slotted Rotors | EBC Yellowstuff Pads
    SOLD 2010 B8 A4 Tiptronic | Stasis Engine Tune | Michelin Pilot Super Sports | Forgestar F14 18x9 wheels | Stoptech Powerslot rotors | EBC yellowstuff pads | Bilstein PSS10 - SOLD | aFe Pro Dry Filter
    Me @ Laguna Seca Raceway - https://www.youtube.com/watch?v=z7s8S1Uh7uc
    Oct 21 2012
    2004 Saab 93
    Just got done with the dealer, it was a wastegate issue, was told because of the oil consumption issue I have along with the car being cold and it being cold out that that was probably it, they reset the code and took it for a drive all is ok. Luckily I just had the turbo repaired back in may so it's all under warranty if it does happen again.
    Veteran Member Four Rings smetch's Avatar
    Jun 21 2013
    long island
    thought they extended the oil consumption issue to 120k or 7 years I could be wrong tho
    Oct 21 2012
    2004 Saab 93
    If you could provide me with some info on that I would forever be in your good graces.
