Results 1 to 17 of 17
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    Where did you get your 4 Bar map sensor?
    I found this but after shipping its $98
    http://www.darksidedevelopments.co.u...k-906-051.html
    This one is a little bit cheaper ~$15 but not sure if it comes with the reducer
    http://www.ebay.com/itm/131047905373...84.m1438.l2649
    Wondering if there are any cheaper options?
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Sep 11 2009
    NE
    Quote Originally Posted by Shhmaudi View Post
    Nope, that's the only place I found it sold at.
    Veteran Member Three Rings rnagy86's Avatar
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Quote Originally Posted by julex View Post
    You can basically get it at any VAG dealer. The problem is, you need the reducer that darkside sells with the sensor.
    EDIT: They sell that separately as well.
    Sep 11 2009
    NE
    Quote Originally Posted by rnagy86 View Post
    * if you're in europe. Not so in US as it wasn't installed on any cars imported here.
    Apr 12 2012
    RS4%2CRS6
    Budapest/Hungary
    Really? I can get US only part numbers easily in Europe, thought it's the same the other way around as well. Someone should stack up on these in the US. I can even help out shipping a batch to the US.
    May 05 2011
    SC
    Comes stock on the VW Amarok 2.0TDI. 44 Euros + VAT(~19%) through Audi/VW.
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    Darkside FTW. If you're in a hurry I picked up a few spares, but I'd need it replaced.
    Nov 16 2009
    Sandy eggo
    I think I might hit you up on that^^ pm sent
    Nov 16 2009
    Sandy eggo
    Got it: But since we are on the topic of increasing boost levels (25+psi) is there anything else I should watch for?I already have rods, kinda uncharted territory for me..
    Oct 14 2012
    Upstate NY
    Heat. I don't know what turbos you have, but more!=better.
    Sep 11 2009
    NE
    rods is all you need. Next stop is determining which block you have... If yours is old APB style, watch out for mains, if later BEL style, you're in good shape.
    May 05 2011
    SC
    I've been looking at the BOSCH PN# 0281002576 also. It's a 0.5-4 BAR MAP sensor (5v : 6.0-12.5MA) and can be had pretty cheap (2nd hand) here in Europe if you look hard enough...Not sure about in the US. It would not be an easy "plug and play" like the Darkside sensor w/ the spacer. Looks like you would basically just have to change the connecter, double check the pins, ect. Like I said...just noticed it and was toying with the idea... discuss...
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Just read this old post Are BEL main (bearings?) really that much better/stronger?
    When 'building' a 2.7T (and having the option), should I use a BEL?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by vtraudt View Post
    The main bearings are the same, the main webbings in the block are beefier in the BF/BEL.
    It's also worth mentioning that the OP cracked his mains just last year, maybe should have listened to julex from the begining :]
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by aysix View Post
    There is nothing wrong with cracking the block at the main bearings. Its just at what power level it occurred (I take a cracked block when putting out 1k HP).
    But good to know that the BEL block casting is stronger.
    05 Golf TDI
    Sep 11 2009
    NE
    Get BEL, cheap insurance against nasty surprises. And read that large mega thread about BEL vs APB blocks. It seems like sometime early MY 2001 2.7t were all BEL blocks already although on allroad/A6 platform the engines were technically still APB, not until MY 2003 they were revised and called BEL. You'd have to take a peek under the intake manifold, right next to throttle/PS, BEL blocks have a stamping in that area that can identify them.
    Nov 16 2009
    Sandy eggo
    Oh the good ol days Trayvon... funny finding an old thread on here with daz lol
    FWIW I found a 4 Bar map to be slightly overkill for most of the Jabroni's on here.. If your running a ko4 car youll be fine with a 3bar and can be found at ETspec.com
