Results 1 to 27 of 27
    Oct 30 2006
    B8 A4 Avant 6spd
    B7 RS4 cluster into B6
    Has anyone ever attempted this? Eventually I want to get my build going, and this time I want a cluster that can display 8500rpm.
    Its non issue to immobolize the cluster for me, neither is coding, just wondering if anyone has ever done it, as I'm not entirely sure you'd be able to code rpm signal / vehicle speed correctly.
    -18 718 GTS
    Feb 17 2004
    Liberty Hill, TX
    pretty sure any B7 (A4/S4/RS4) cluster is incompatible with B6 ECUs
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by Matt Devo View Post
    Yup.
    You may be able to talk to MPower to see if he can swap gauge faces and then recode the B6 cluster to match the RPMs of the new face
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Dec 06 2007
    Spoke to Diagnosticator about this extensively in the past, not a feasible upgrade.
    -Kirk
    BetaAlphaTau Member #58
    Jun 27 2011
    B7 = RB8
    B6 = RB4
    Not interchangeable, and likely very tricky to get to work...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 30 2006
    B8 A4 Avant 6spd
    Well thats rather disappointing. Im still going to attempt it if I ever get access to one, ill see what coding I can play with. Would be a shame if I had to settle for a b6 s4 cluster.
    -18 718 GTS
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by Militant-Grunt View Post
    you'll be wasting your time. If your goal is just to have a tach with a higher display limit, then having mpower work his magic on a B6 A4/S4 cluster is your best bet
    Oct 30 2006
    B8 A4 Avant 6spd
    The limit is still only 8k being accurately displayed. In my previous B5 BAT A4, I would just kinda guess when to shift after the needle stopped. Not something I want to deal with again, not to mention I'm putting together my
    oem+ interior bit by bit, it would be nice to make it work.
    -18 718 GTS
    Feb 17 2004
    Liberty Hill, TX
    mpower can swap the gauge and recalibrate the needle, no problem getting it to work 100%, just not with a B7 cluster :)
    Senior Member Three Rings georgio3gr's Avatar
    Jul 14 2009
    Greece
    I searched a lot and the only thing i found out is that Mpower can do everything, maybe even win Jack Norris... I don't know the guy-company, as i read here, he might be the only capable for swapping A4 clusters, but i live at the other side of the planet, thousand of miles away, in a country that everything comes outside EU has to pass throuth expensive customs, so sending my old and new cluster to him and then he sends them back at me, is nearly impossible... Does anyone know for sure what programs can do all the swap job (find SKC, virginise cluster etc) for sure, withouth bricking my clusters and not going to the stealer?
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    Quote Originally Posted by georgio3gr View Post
    That my friend, as we say in america is the $64,000 question. I don't think anyone will openly post that information in this forum, because it can lead to to some illegal practices, particularly odometer fraud. I looked for a while for a way to virginize a cluster myself. I have found no way to virginize a cluster on my own or even the name of the tool that can perform that function. You can retrieve the PIN via your ecu using VAG Commander. That tool is readily available on the nefmoto forum, PM me if you can't find it.
    Apr 09 2007
    Beaverton OR
    One in the RS4 classifieds click me
    Jul 14 2009
    Greece
    Quote Originally Posted by Jflow23 View Post
    Thanks a lot for the answer... As you understand, i don't give a shit about changing my car's odometer miles... I am planning to keep it until i give it for garbish... I just want to get rid of this red "thing"... It just looks weird that 2 or even 3 car models later (since B6), there is not enough knowledge about this, in one of the biggest (if not the biggest) Audi (A4) forum... Thanks again...
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    If all you want to do is to get rid of the red CIS display, look for a B6 A4 3.0 cluster from a car that came with factory Navigation. Those had the color display.
    USP CLUB MEMBER #34
    Jun 27 2011
    Plenty is known about them. But due to the ability to abuse the tools and the potential for people to commit a crime using the tools, the information isn't freely and easily available.
    Also rb8 was never designed to be cross compatible with rb4. Hence why a rb8 cluster is kind of a non-starter.
    Find a b6 s4 or a 3.0 with the color screen.
    -CP
    2017 Q7 3.0t
    Apr 09 2007
    Beaverton OR
    Quote Originally Posted by CyberPMG View Post
    He still has the same problem with virginizing and retrofit.
    georgio3gr, keithwbloom mentions that he can probably talk you through the virginizing process provided you have access to VAG-Tacho and a chip burner. May be worth PMing him.
    see this ad/thread click
    Jul 14 2009
    Greece
    Sorry my friend but from the whole conversation you understood that my problem is to find and buy a cluster with colour display?
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    ok, now I'm lost. Is that not what you're trying to do. If that isn't what your goal is, what exactly are you trying to do? and then what do you mean by red thing?
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Jul 14 2009
    Greece
    Quote Originally Posted by Myst420 View Post
    Yeah my friend, that's my goal... But as Jflow23 explained above, clusters are protected by immo code... You cannot just find a used colour cluster and swap it with your "red" one... It's a whole process starting from exporting SKC (secret key code) from old cluster, virginising new and copying your old cluster's data to the new one... All these, need a special program-tool to make it work.. That's my problem...
    ps: Jflow23 thanks again... I'll contact him...
    Jun 27 2011
    I am 100% certain there are people in Europe who do this service though. Tom (mpower) is one of many in the US who do this. You just need to do a little more googling.
    -CP
    2017 Q7 3.0t
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    It can be done DIY, you just have to do a little more research. There are programs sold on ebay (with cable) that can read the SKC from your cluster. I believe there was even a writeup made a few months ago about doing this with an A6 cluster (whether it's the same exact process, I don't know) but the SKC of the old cluster was obtained by swapping it into the car and reading with the aforementioned software. Then you would use VCDS to program your keys to the new cluster.
    02 A4 Quattro 1.8T
    Jul 14 2009
    Greece
    Yeah, you are right... There are always people that will try selling their 300000 miles car for almost new... Just to explain, i'm talking about RB8 cluster just because i have an 20vt engined B7 (Greece) and they use RB8, not RB4 like B6...
    Searched a lot... Maybe it's the illegal part in the middle that they are afraid of and noone mentions the cluster swap at his services... I'll keep searching...
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Maybe you should have mentioned that BEFORE you starting asking about this in a B6 forum. You would probably get more help in the B7 section, since that is what you have.
    02 A4 Quattro 1.8T
    Jun 27 2011
    Thats more or less the gist of it. You need a particular kind of OBD2 cable, but nothing that isn't easy to find on ebay. And then you need a specific version of some software (again, nothing that isn't easily found through google) and then its relatively simple to retrieve your SKC. I researched this a ton a year ago hoping the process was the same for the b7, but since its RB8 and IMMO4 its far more complicated. For the RB4 IMMO3 clusters in the b6, its relatively trivial as long as you get the cable configured correctly, install the proper drivers, and get the correct version of the software to work.
    I can't remember the name of the software right now, but its freely available...
    -CP
    2017 Q7 3.0t
    Jun 27 2011
    You should have said that at the beginning. The engine is irrelevant, the cluster and whatnot are tied to the chassis. Try asking in the b7 forum, though be prepared for them to be even less helpful that us, haha. B7 guys are less versed in this stuff.
    -CP
    2017 Q7 3.0t
    Jul 14 2009
    Greece
    The process is almost the same for both B6 (RB4) and B7 (RB8) even immo 4 is a bigger bitch than immo 3, so if someone knows something more in B6 section might help B7 members too (and me off course)... If i had found the answer there, i wouldn't ask for more in here... Whatever, some of your answers helped me a lot... I'll be happy to read from someone who knows more... I hope i'll solve this and return you the favor...
    Jun 27 2011
    I know RB8 needs a lot more than the SKC though. Retrieving it is the same process (though last I looked the software didn't support RB8 yet) but after some conversations with mpower, there is more to it that just retrieving the skc. With RB4 the SKC basically allows full access to the cluster and IMMO. In RB8 there are more layers of security.
    I was in touch with him 8 months ago trying to get a second and third key made for my b7. Basically I ended up needing to send him my cluster as the tools required to interface with RB8 were VERY expensive, and unlike RB4, no free/hacked alternatives exist yet.
    -CP
    2017 Q7 3.0t
