Originally Posted by
mistral cytz
No I have not had this done. I figured since it's a 1 owner car with all dealer service records up to date and still has under 50k that this wouldn't be an issue to check for but I guess I will now.
Would a low oil level warning light be stored as a fault code? I scanned the car with Vagcom and didn't see any codes but they could have also been cleared in the past. I'm just thinking that if the car burned excessive oil the previous owner would have had that fault show up before.
I recently purchased an immaculate 2005 B6 S4 from it's original owner. He claimed it was consuming a quart of oil for every thousand miles driven which was I fine with. A week or so after buying the car, I surmised that the real oil consumption was around 1 quart every 250 miles. There were no stored fault codes for the oil consumption. I recently had Audi diagnose the problem and perform over $10,000 of work. I got the car back and within two weeks, it was down over a quart of oil again in less than 750 miles traveled. I've since opened an inquiry with Audi of America, but that's another story.
I find the dipstick to be a bit hard to read when I try to measure the oil level using the procedure outlined in the manual. There's oil all over the place even after you wipe it off and reinsert it. A tech at Audi told me to unscrew the oil filler cap prior to checking the level so the oil can drain down. I find waiting a few extra minutes after shutoff makes it much easier to read. I also frequently check my oil level cold (just for reference) and it's extremely easy to read then, although the level isn't necessarily accurate.
