I am looking for some feedback on a diagnosis that I received today from my tuner about an oil leak around the turbo. (Pictured below)
Here is a little background on my set-up. I have had the AWE GT kit & FMIC running for about 1 yr 8 months and 17,000 miles on my Avant. I have had the BSH Block off plate PCV solution going since Stage 2 @ about 25,000 miles around 2010, no problems. My oil consumption has been about 1 qt every 2,000 miles since I have owned the car, Got it with 10K now has 62K. Recently it had increased to 1 qt in 1,000 miles. I had also been noticing some smoke on wide open pulls now and again, but no smoke at start up, idle, or low boost. This lead me to believe the VC was bad, especially since I saw a little oil around the gasket and some of the Torx screws.
I was poking around in the motor and noticed a fine mist of oil residue on the silicon TIP and hose connected to the rear PCV passage (The GT kit removes the Rear PCV completely and its basically just a silicone hose going right into the Pre-turbo intake.) I bought another stock VC and gasket and replaced it, thinking problem solved. Nope, drove to work that day and and stretched her legs little bit on the freeway, got to work and checked my vc job for leaks. No VC leaks, but still a slight oily mist on the TIP. So, I probe deeper with a bright light and notice some oil on the Turbo housing. Never thought to check there before since the kit is still young and I wasn't having boost issues.
Now I am stressing out, so i take it back to TAG motorsports where I had the kit installed to check it out. Seems way to early in the kits life for the turbo seals to go bad. They looked at the car and came back with the below.
"Brett,
This is what my technician's response is to the oil buildup.... He is basically saying that the block off that you have in there, is causing excess pressure into the crank case preventing the oil flowing to/from the turbo to not flow properly causing excess oil in the turbo.
The recommended solution would be a catch can system/PCV fix which would then help bring the crank case pressure down, letting the oil to flow properly in/out of the turbo without causing too much drama.
Let me know your thoughts.
Begin forwarded message:
Here is a good explanation of possible causes for the issue.
If the oil return line of the turbocharger is clogged
or constricted by a kink, the oil can no longer flow out of the turbocharger.
A possible cause for clogged oil return lines is the coking of the return line,
which might be due to missing heat shields, a poorly routed return line,
heat soak, inadequate oil quality, or the use of liquid sealants. As the
turbocharger is still supplied with oil from the engine circuit, the oil then
escapes to the turbine or compressor side.
If the engine is supplied with too much oil, the oil can no longer flow
back out of the oil return line into the oil pan. The crankshaft also splashes up the oil. This results in the oil foaming, which
forms an additional barrier for the returning oil from the turbocharger
If the pressure in the crankcase is too high—either because of too high
blow-by or due to blocked crankcase ventilation, this pressure will also be transferred to the oil return
line of the turbocharger. The oil drainage from the turbocharger is thus
hindered, and the oil escapes from the turbine or compressor side.
Do you guys think the BSH Block plate could cause issues with the oil return line? The Block plate has a chamber carved out that links the rear PCV passage with the crankcase so its not really blocking that passage off. I feel like it would do the same thing as a catch can except with a catch can set up a hose runs from VC to Can and then back to VC before exiting into the intake. I don't know if that would lower the Crankcase pressure. I am trying to rule out a problem with the turbo, is it ruined?. I am happy to put in a catch can set up, but I am worried that it's not going to solve the problem.
I love to know if anyone with the APR or AWE kits have faced this issue, and what PCV solutions you are running.
Thanks for you expertise.
