Hi all, new to the forums...first post concerning an issue. I've done tons of searching, and checked as recommended..but still in need of help.
Recently (within the last 500 miles or so), I've been getting this rubber squeak noise out of the front left (drivers side) suspension. Only occurs when I go over speed bumps, dips in the road, or pulling into an incline driveway.
My first thought was upper control arms, but those were replaced 10k miles ago by Canyon Racer Motorsports. I tried lubing up all the bushings in an attempt to see if the squeak temporarily went away, but it did not. Also checked to make sure everything was torqued down. Can you all give this vid a listen and try to point me in the right direction?
Things already checked:
Checked for play in the arms/bushings
Checked everything was torqued (arms, tie rods, calipers, subframe, end links, steering rack bolt under battery tray, strut mounts)
Lubed bushings
Thanks in advance!
