Have both the ABS and ESP lights come on every time I drive. I previously looked up these symptoms and some said brake switch. I replaced and it the lights still come on. I had a local person scan it with vagcom and it came up with this:
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 4529
Coding: 04275
Shop #: WSC 06435
VCID: 264335ACC28EFA287A7
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
35-10 - - - Intermittent
I had him clear all the codes and we drove around for a bit and it didn't return. It was fine probably for a week without coming on, but then they came back and now come on every time. I searched this and there were no resolutions to this code. The ABS appears to be working. What else could it be? I've heard potentially needing to rebuild ABS module, but how does one know this is exactly what is needed?
