Greetings all,
I'm hoping someone may be able to shed to light or help me out with my current situation. Completely stock 01' S4 159K. My cats are bad per engine codes. Also had a code for bad bank 1 primary o2 sensor. I then replaced the bank 1 primary sensor. With hopes off not replacing the cats, I purchased a package of 2 spark plug non foulers. I drilled each of them out with a 1/2" drill bit. I have placed one drilled out non-fouler onto each of the two secondary o2 sensors. I wen tot get inspected with a mechanic buddy of mine an fit failed with the o2 and cat monitors nor ready. So I drove the car for 150 or so miles and all was good, no engine lights. Bring it back fro inspection and it passes. awesome On my way home from the inspection, just a few miles, the mil light comes on. I get home and read the code… P1176 Now I understand this is for bank 1 secondary o2 sensor limit attained. My question is what exactly does this mean?
Did placing the non foulers on the secondary sensors trip it? I still have the original bank 2 primary sensor in keep in mind. Is the new bank 1 primary sensor reading so much better than the original sensor that now the limit is attained across the cat? I am only seeing p1176 and not p1177 for the bank 2 sensor limit.
After asking around and doing some more research, I have seen many people doing this mod on gutted dp's and requiring two nonfoulers stacked, with one drilled out, and one not. Is there a chance my bank 1 cats are damaged to the point that I will need this? I am using single non foulers right now.
Any help would be greatly appreciated.
Judeman
