Results 1 to 29 of 29
Thread: Wheel Removal
    Jan 16 2013
    Naples, FL
    Wheel Removal
    So I wanted to put mud flaps on my car, but in order to do that I need to take off my Wheels. I got the 5 bolts off, but then theres the big center lock.... Do I need to take this off to get the wheel off? The tire won't budge otherwise. How do I get the wheel off?!
    Please help!
    Thanks in advance
    2013 Audi A4
    Veteran Member Three Rings AudiKerl's Avatar
    Jul 07 2012
    MN
    Quote Originally Posted by '13Phantomblack View Post
    2013 Audi A4
    Mods: Cool Audizine license plate frame.
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    That large nut is the axle bolt, do not undo it!
    If you have all 5 lug bolts removed the wheel should be able to be removed quite easily, especially on a 2013 car. Given your location there may be some corrosion on the hub which can make things stick together.
    Taking the nature of this post into consideration please be sure that the vehicle is properly jacked up and supported while working on the vehicle. The factory jack is absolutely not to be trusted on it's own.
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    Good advice above. Make sure the car is properly supported.
    You may need to spray some anti-sieze between the hub and the wheel. Then a couple swift kicks should knock it free.
    Again, only if properly supported!!!
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Veteran Member Four Rings Ajp428's Avatar
    Jan 12 2013
    1999 Mercedes E430 SOLD
    Long Island
    Quote Originally Posted by AudiKerl View Post
    ^hahaha^ but yeah what they also said don't undo it just give it a little force if its stuck, kick the bottom part of the tire lightly while pulling the top toward you maybe if it wont budge. if all 5 nuts are out wheel is out just gotta take it off
    Monsoon Gray 2013 Audi S5 Premium Plus
    Ibis White 2010 Audi A4 Premium SOLD
    instagram: @s5auce + eurograde_
    EUROgrade
    Oct 10 2012
    Zionsville and Saint John IN
    For the front, Id loosen (Just a tad, nothing crazy!) the lugs on the front wheels and then turn on the car and turn the wheels left and right. Then jack up the car and remove the bolts and the wheel should come right off.
    For the rear, Id lift the car up and place a jackstand under it, remove bolts, and kick the tire a couple of times ;) !
    Veteran Member Three Rings jesters22's Avatar
    Oct 14 2009
    new jersey
    is this a real thread?
    PARTING OUT A SILVER 2001.5 S4 PM ME FOR PARTS
    http://forums.vwvortex.com/showthrea...2#post83363922
    Veteran Member Four Rings FuchsB's Avatar
    Apr 01 2012
    AZ
    Quote Originally Posted by jesters22 View Post
    +1 my thoughts exactly. maybe next well get a how to get gas in the car thread...
    Current-
    2021 Audi RS6 Avant
    2015 Cayenne Diesel
    1986 LS Swapped Porsche 944
    1973 VW Fastback
    1972 C10 3 door LS swapped Suburban on Accuair
    1970 C50 Dually Duramax build
    1968 Suburban LS Swap- For sale soon
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    If this is for real, it probably needs to be re-iterated to follow the above advise about properly supporting your vehicle. Then give the wheel a good kick from behind and it should some off. I've had to use a gentle swing with a sledge hammer from behind on other vehicles but I live in eastern Canada, not Florida! Like they said above, on a 2013 I'm surprised it didn't just fall right off. If you do use a hammer, it should go without saying to try to make contact with the tire instead of the wheel.
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    While helping a friend, we used a sledge hammer and a 2x4 to knock stuck wheels off a camry. Put the piece of wood flat against the tire, knock the bottom with the sledge hammer and the wheel comes right off. Distributes the force across the bottom section of the tire (so it doesn't wreck your summer tire) and it protects your rims. First time I've seen that solution but it's a good one.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Sep 14 2006
    He probably forgot to jack the car...I'm being serious.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    May 21 2010
    Quote Originally Posted by richardm0025 View Post
    as Seinfeld would say to Kramer "oh I like this idea, what could go wrong..."
    Senior Member Four Rings r6_11b8's Avatar
    Oct 03 2013
    los ángeles
    you mean to tell me you can take off the wheels?!?!
    2011 A4 ice silver metallic
    MODS- 25% tint rear, 75% front, 19" Rotiform BLQ, Solo Werkes coilovers, Custom FXR projectors
    upcoming mods - 10 inch sub
    2009 Yamaha R6 - Shogun FS-Zero Gravity-Custom FE-Hot Bodies Flush Mounts-MotoDynamic Integrated Tail Light-Supersprox -1+2-Taylormade Full Exhaust-PCV-OURY Grips-Corbin Seat-Ebay Shorty Levers
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    Gonna stick my neck out here -- I tried to remove a wheel and even after kicking / hammering it, it wouldn't budge. I gave up. Turns out you gotta not be a nancy about it, but I wasn't all too comfortable given the shitty jack.
    audi and hyundai disagreed on the lug nut / bolt argument, so it threw my original notion off. thought I was missing something (besides some masculinity, now found i think)
    Veteran Member Four Rings smetch's Avatar
    Jun 21 2013
    long island
    had to use a rubber mallet and a quite of few hits to get off my wheels for the first time after picking it up.. have a 2010
    Apr 29 2013
    Pittsburgh, PA
    Had a flat tire last Friday, not sure where to jack up the car and didn't have the owners manual with me, so I called audi roadside assistance who sent over some auto rescue dude.
    turns out he could not for the life of him get the wheel off after taking off all lug nuts. He basically gave up and I had to tow it to the dealership at 3am.
    I was told the second morning that I might have a wheel lock? so confused...
    and yes, this is a serious post....
    2012 Audi A4 Quattro 2.0T | Premium | Stock
    Jan 12 2013
    Long Island
    Quote Originally Posted by kongmw View Post
    im pretty sure a wheel lock would be included in one of the lug nuts you'd have to take off so its very odd that they'd tell you that. unless im mistaken
    EUROgrade
    Oct 10 2012
    F*ck the tow bill, I'm kicking that tire until it comes off! A wheel lock would be one of the Lug Bolts.
    Veteran Member Three Rings gunsmoker's Avatar
    Oct 24 2011
    Mansfield,MA
    I had the same issue when I changed my brakes. It took a lot of anti-seize and beating with a hammer on the inside through a piece of wood. It's galvanic corrosion between the wheel and the rotor. My new rotors have painted hats, but I put anti-seize on them before putting the wheel back on.
    2011 A4 2.0TFSI Quattro 6MT, Premium+, 18" Sport Package, Ice Silver, Light Grey, Dark Walnut, AWE Exhaust, STaSIS ECU Tune, Deval CF Splitter, aFe Pro Dry S Filter, ECode Turbo Inlet Hose, Alu Kreuz, Osir CF Valance, R8 Coil Packs, ECS Two-piece S4 Rotors, H&R Rear Sway Bar, 034 Trans Mount, RS5 Pedals, Ultra Racing Strut Bar
    Established Member Two Rings MatZo's Avatar
    Oct 26 2012
    Tampa
    I live in Florida and when I had a flat tire I couldn't get my wheel off at all, had to call Audi support and we had to lower the car and turn the steering for the friction to pop off the wheel. I had tried pulling the wheel off when I had the car jacked up but resulted in the car slipping and putting a small dent on the underside of my car :/
    I wouldn't recommend turning the steering by yourself and have someone with you, obviously.
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    The easiest way to get a seized wheel off is undo the nuts then lower the jack slightly. The weight of the car will usually pop it free..
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Kick bottom of tire... 3-4 short but firm kicks causes vibration.... Works every time for me
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Oct 10 2012
    Quote Originally Posted by MatZo View Post
    You should never turn the wheels with a jack under the car haha. If your by yourself, just loosen the lugs bolts up like a half a turn and then get in the car and turn the wheel. The lugs are still to tight for the tire to just come off!
    Feb 15 2014
    Florida
    Found this thread while trying to get my wheel off and couldnt. Lowering the car with the lugs off popped the wheel right off. Thanks for the tips everyone!
    '10 A4 .:[APR] - [aFe] - [AudiUP] - [R8] - [EC] - [VCDS]:.
    Senior Member Two Rings nerv81's Avatar
    Sep 09 2009
    New Jersey
    Loosen your lug nuts a little and try this...
    https://www.youtube.com/watch?v=jv4m41viy4I
    Established Member Two Rings holyShred24's Avatar
    Oct 28 2013
    Norfolk, VA
    Mine is an 09 and my wheels only got stuck once and it was when i first rotated em myself. Loosen bolts, jack the car up, take off all bolts and hit both sides (alternating left/right side) from the inside with a rubber mallet. I do the same thing with my truck and works like a charm. Always put some anti-seize before putting the wheels back on.
    Veteran Member Three Rings a2 4.0t's Avatar
    Jun 18 2012
    Jimmy Hoffa
    Ocean City / New Jersey
    Quote Originally Posted by nerv81 View Post
    lol this made my day
    2012 A4 s-line
    |Carbonio intake | APR quad outlet exhaust with tons of RSC technology | AWE downpipe | s4 rear valence | Vogtland coil overs | Rotiform BLQ's | stage 3+ Chinese turbo whistle |
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    rubber mallet x2 and then use anti-seize on the hub....nuf said
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
