To start things off, you first need to disconnect the breather hose going from your intake to your PCV system on the PCV side and move it around so its more easily accessible like so
Next you need to get a small clear hose about 2 feet long with a small tube to run through a tapered rubber grommet (or how ever else you would like to attach it) Im sure you can either put one together for under $15 or find one at a store somewhere. I just used the one at my work that another tech put together.
After that you need a can of engine cleaner, seafoam or whatever you would like to use, I used what we use on customer cars for this service since I had some laying around. Most likely if you were thinking about cleaning carbon you already have some or you were about to get some. I found that this stuff works great!
Now that you have your cleaner and attachment line ready connect the two together and then connect the line to the PCV line like so
For the cleaning process make sure your engine is already at operating temp and off. This part will require two people or a crafty way of holding your engine at 2500 RPM the whole time. I also recommend that you make sure you have access to VAGCOM or a scanner of some sort to clear faults as this will most likely throw several faults for misfires and possibly throw a check engine light.
As the engine is idling at 2500 RPM grab your can of cleaner and give it a spray just enough to fill the line running to the engine from the can every 3-5 seconds. A good rule of thumb is just to watch the line, once the engine pulls all the contents out of the line, give it another spray and fill the line back up. Be sure not to spray too much as too much cleaner can choke your engine out and stall it. Depending on how much carbon you have in your engine it may take two cans, or more if its really that bad.
As you run through the service your going to see your car spewing out black smoke out the exhaust, that is all the carbon its cleaning/burning out. When I performed the service on my car I used two cans and it was nothing but black smoke the whole time. You would have thought I owned a diesel truck with all the black smoke! You will know when your done cleaning as the smoke will become less and less until its nothing at all.
So once your done, if you have quick hands you can reconnect the PCV line back up without having to turn the engine off, but you can turn it off if you want. Once your line is hooked back up, clear the faults and take your car for a nice spirited drive for about 10 minutes and push whatever is left in the motor out. After that you are all done!
Its a quick and easy way to clean carbon out of your engine without having to pull the intake and scrub for however long. Now unfortunately I do not have any pictures at the moment of before and afters of the valves but I will try to get some ASAP for you guys. I can assure you though, this works great! I have used it on customer cars many times with lots of carbon on the valves and it cleaned them right up every time!
For all of you that read this and or perform it, ENJOY!
