Hello,
To start off with, these are the three stages and associated problems I had:
1. Original Clutch, Original Slave, Original Clutch Line, Original Master - No problems, installed until about 155,000 miles
2. VAST Stage IV Clutch, Original Slave, Original Clutch Line, Original Master - Clutch pedal wouldn't fully return (had to be manually lifted up) every now and then during hard launching, only started after roughly 15,000 miles
3. Clutch Masters FX400, Meyle Metal Slave Cylinder, USP Stainless Steel Clutch Line, Original Master - Clutch pedal doesn't fully return after every WOT pull (has to be manually lifted up) in each gear (verified in 1st, 2nd, and 3rd), installed for roughly 400 miles
Mike of Ringer Racing is thinking either the slave, master, or blockage in the clutch line causing a restriction of flow on the way back. I'm going to check the clutch line and ensure I didn't kink it (though I would think this wouldn't allow the clutch pedal to come fully up during normal driving also) during the reinstallation of my engine and then I'm going to rebleed the clutch this weekend, and then order a new master cylinder... but in the meantime I was wondering if anyone experienced this same problem and could comment on what it took to fix it before I go wasting my time or throwing money at parts I don't need.
Thanks,
Brett
