Results 1 to 24 of 24
    Oct 12 2013
    Inland Empire, CA
    B7 A4 with Symphony II+ to Kenwood DNX570HD
    Hi guys, this is my first official post on the forums, so bare with me if I make stupid mistakes/break rules. I'm still learning!
    I picked up my A4 about a month ago, and have been disappointed with the fact that the factory Symphony II+ (non Bose) unit did not have integration for iPod and Aux inputs. Since I don't have Satellite Radio (I use my massive iPod library for music when I'm driving), I'm stuck with local radio stations, which drives me insane. I decided I wanted to upgrade the HU to something nicer, which had support for everything I wanted. I researched the RNS-E, but decided against it. I instead chose a Kenwood DNX570HD, due to the Parrot bluetooth system, Garmin navigation, and inputs for everything I wanted/needed. Here's where the nightmare began...
    My roommate is an MECP certified car audio tech, and quite good. He offered to be an awesome roommate and install my HU for me. What we didn't realize, is that the rear speakers in this car are powered by an amp, while the fronts are powered by the HU's internal amp.
    I bought a wiring harness from Metra (part number 70-9003), as well as an Amplified Antenna Adapter, ASWC steering wheel control, dash kit etc. After I received everything, we proceeded with the install. Immediately, we noticed the factory wiring harness has two separate harnesses embedded in the quadlock clip for the rear speakers, while the Metra harness does not accommodate that. Problem #1!
    We researched online, but had a very hard time finding anyone else doing installs with this setup (maybe I'm just not looking right? I'm a hell of a good internet sleuth, and this still eluded me!). The simplest solution we found was splicing RCA's into the HU's rear-out, to the rear speaker positive and negatives on the factory system's wiring harness. Yeah.. not gonna splice up my Audi's wiring harness to jimmy-rig shit, so I decided against that immediately. This seems like I'd be more than prone to engine wine coming through the speakers, as well as low signal strength and general shitty sound..
    We decided to test everything else I bought, since we'd run into problems immediately. We installed the antenna adapter, that worked like a charm (and is actually very small, which is great). We then installed my bluetooth mic into the factory position (above dome light), and installed the aftermarket GPS antenna (couldn't figure out how to integrate the OEM GPS antenna in the sharkfin, so we said fuck it haha). All of that was great, and functions just fine. Next was steering wheel controls. Just to give everyone a heads up, the ASWC-1 does NOT work without major modifications to the stock harness, and even then, it's a bitch. Don't bother with it if you have this setup...
    At this point, I'm frustrated.. We call the local car stereo shop and ask them about what harness would work. They recommended a harness they had in stock, so I picked it up. I get back home, and of course, the harness is STILL not right. Thankfully, they are great, and will let me return it.
    So, at this point, I'm about ready to return everything out of sheer frustration. My roommate is more than capable of splicing/cutting the stock harness to make this work, but I DO NOT want that (trade in/next buyer will appreciate the ability to revert to stock by just unplugging shit, I'm sure). After a few beers and playing GTAV to vent my frustrations, I decided to research more.
    After digging for an insurmountable amount of time, I discovered Enfig makes a number of harnesses just for this occasion. After I've already spent $250 on harnesses/shit that didn't work. COOL.
    Well, there are multiple parts that can potentially work for this setup, but I was trying to find the most straight-forward approach to get as close to a plug-and-play system as I could. I called Enfig, and chatted with one of their installers (I believe it was Mike, not entirely sure. EDIT: It was Christian :P haha). He informed me that the SRWH-AUD3-HILO harness they make would be what I need. This harness is plug-and-play for everything from powering the rear speakers properly (the issue is that the factory Symphony II+ HU has a higher output for the rear speakers than aftermarket units) and can seamlessly accommodate the steering wheel controls which are, of course, proprietary to Audi. It looks as though I may have FINALLY figured this out (about $1k or so in!), although I'm not holding my breath until I get everything in my hands and we get it installed and functioning...
    I returned my ASWC, in lieu of this harness, and a specific lead for my head unit. Once everything is shipped here (won't be until about the first week of December, as the Hi-lo harness won't ship until the 22nd of this month), I'll document the whole scenario step by step with photos, if you guys would like. I'm sure it will save someone the frustration I went through, so long as this works like it should! I'll keep everyone informed!
    Stage 2 Banner Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Carlstadt, NJ (outside of NYC)
    I saw a SRWH-AUD3-HILO order come in from CA today but it didn't include the PNP-KEN0016???
    And why does everyone always think my name is Mike!!!
    EnfigCarStereo.com - Audi Car Audio Integration Specialists
    ☎201-490-5015 - Instagram - Facebook - [email protected]
    Want to make some money while posting? Join our affiliate program.
    Oct 12 2013
    Inland Empire, CA
    Hahaha yeah that was me! Sorry man, I couldn't recall your name.
    Talked to my installer, he was confident that he could wire up the harnesses without using the PNP (saved me $20). I did notice, however, that there was one added to my shipment with no charge. Wasn't sure if that was a mistake, or if you guys were just that badass and threw it in!
    Jul 26 2008
    Brisbane, Australia
    Quote Originally Posted by Christian@enfig View Post
    Because you look like a Mike!
    Jul 12 2004
    Quote Originally Posted by dcc236 View Post
    Don't make me start putting up pictures!!!
    Jul 12 2004
    Quote Originally Posted by sl33p View Post
    I figured I'm probably gonna link this thread to the product page so might as well have you tell people how awesome our plug and play is too...
    Oct 12 2013
    Inland Empire, CA
    Well thanks a lot man! I appreciate that! Will definitely post up pics as well as my install step by step so others can see how this whole thing works. Looking forward to getting my head unit in my damn car already haha.
    Registered Member One Ring dhaliwal925's Avatar
    Oct 29 2011
    Kent
    @sl33p Just got done installing the Enfig HiLo wiring harness, works awesomely There is plenty of space in the console to stuff the "boxes" on the sides. The only hick ups I had was the HiLo connection is kind of hard to line up, at first I thought it just didn't fit, but i kept applying pressure and it worked out fine. Also once it looks like a connection is made, apply some more pressure, for some reason it clicks before a full connection is made. Sound quality is amazing! I had the Metra set up for a week with just the front speakers running and there was some faint engine noise coming through, with this new harness NOTHING!
    @Christian Awesome and easy! Thank you.
    Jul 12 2004
    Awesome Thanks Dude!!!
    Established Member Two Rings JohnnyTooBad's Avatar
    Aug 14 2009
    NoVA
    I'm about to install a Kenwood DPX500DP for similar reasons. It's sitting here next to me, as is the ASWC-1. The difference between you and me is that I have no issues cutting and splicing wires. When I decide to get rid of this car and get a newer one, I'm not going to get more money for it because I used a plug-n-play harness, and the person that buys a 10+ year old car is going to be happy with the upgraded HU. If they decide to change it, they better own a pair of wire cutters. Hell, I already hacked my wiring harness in an attempt to use an aftermarket device that would play music stored on a USB drive, but the operation of it is beyond abysmal. So I figured I'd be doing more cutting and splicing anyway.
    Good luck on the enfig harness. I'm sure it will make the installation a breeze, while I'm doing lots of snipping, soldiering and heat shrinking. but I want mine in the dash this weekend for a road trip on Monday. (keeping my fingers crossed)
    (DEAD) 2006 B7 A4 Avant 2.0T. Blue/Tan, Auto. 100% Stock, except for some window tint
    Replaced with a unicorn.... 2011 A6 Avant 3.0T, also Blue/Tan. Premium Plus, S-Line, Cold Weather Package.
    Jul 12 2004
    Quote Originally Posted by JohnnyTooBad View Post
    You just hurt me deep in my soul lol...
    Oct 12 2013
    Inland Empire, CA
    Sorry for the delay, guys! It's been a busy, busy few weeks. Anywho:
    Quote Originally Posted by dhaliwal925 View Post
    I actually got around to installing mine this past weekend. I would have taken pics, but honestly, there really isn't much to take pictures of!
    First and foremost, Enfig was awesome as far as customer service and shipping. My shipping address is in a private community with a private mail center, so getting things shipped is a huge pain in the ass.. the package was sent back, and they were on it, calling me to correct the issue near immediately. Once my address was resolved, I got the package 2 days later. No kidding. From NJ to Southern California that fast. Crazy!
    The harnesses (I picked up the steering wheel lead, and Christian threw in the PNP harness for my head unit for me, on top of the HiLo. Enfig is awesome!) are completely plug and play. It literally took me a total of 10 minutes, and that was because I was fiddling with the EQ/setting up Bluetooth :D
    This was the only picture I had time to take during the install. As you can see, it's literally just snap in and go:
    I did notice the same thing with the harness to the Hi-Lo box. It fits very, very snug, and requires a slight bit more force than I'm used to to get it into place, but once in, it sounds great! My Bluetooth audio is a tiny bit staticy, but I think that's due to the Bluetooth connection. Everything else worked exactly as planned! I'm super happy with this purchase, and would recommend anyone looking to swap head units to go this route!
    In regards to space, we had a tough time stuffing everything back there. We found that tucking it into the small hole toward the steering wheel/drive shaft netted a lot more room. Everything does fit in there, but it required a bit of ingenuity haha.
    Overall, I'm very happy with both the product, and Enfig's great customer service. Shout out to Enfig and Christian for hooking it up!
    Well here's the deal. If I wanted to splice up my stock harness, I would. I know how. The issue is that this is a luxury vehicle, not a Honda Civic. Do it right, or don't do it at all (not saying your method is wrong, but having the luxury of returning to stock with literally no hassle is a no-brainer.. also, most people who are going to purchase these cars don't want aftermarket audio equipment in them, honestly). I want to ensure the next owner of the vehicle can return it to stock.. who knows, maybe I'll want to swap this head unit into my next vehicle. If that's the case, I don't want to re-wire, solder and heat shrink the factory harness, nor do I want to dump that on the next owner. It's just courtesy in my opinion.
    Jul 26 2008
    Brisbane, Australia
    wouldn't a better/cheaper solution have been to keep the symphony and add a Dension module for bluetooth & your iphone audio?
    Oct 12 2013
    Inland Empire, CA
    It would have, but I also wanted Navigation, and an upgraded interface. I wasn't very fond of the stock Symphony II+'s interface. This is much nicer, and ties the car together nicely. I'll snap some pics of it in the car on my lunch so you guys can see. It flows perfectly.
    Jul 12 2004
    hahah thanks bro Please please please leave a review on the SRWH-AUD3-HILO. It has no reviews on the site
    Established Member Two Rings AudiRay_722's Avatar
    Feb 28 2011
    Wisconsin
    I just finished installing my new pioneer unit. Well almost finished. I can't seem to get my faceplate to snap in. The top two clips barely snap in and the bottom two don't at all. I'm surprised by how strong the faceplate is since I've been using a lot of force out of frustration to get it in. Anyone else have this problem and have a solution to it?
    2008 Audi A4 S-Line Ti. Pkg. FT
    APR Stage 1
    RS4 Grille
    Bilstein Sport shocks
    "A turbo: exhaust gasses go into the turbocharger and spin it; witchcraft happens and you go faster." -Clarkson
    Jul 12 2004
    Quote Originally Posted by AudiRay_722 View Post
    Assuming you are using the enfig RMK8-A4B67. That means the radio is sticking out too far. You need to adjust the clips that hold the radio in so that the radio sits further back. Also make sure you did not tighten the bolts that hold the plastic frame to the car too much, That causes the kit to bow.
    Oct 12 2013
    Inland Empire, CA
    Done!!
    Jul 12 2004
    Done!!
    Thanks so much.
    Oct 12 2013
    Inland Empire, CA
    Thought I'd post a finished install pic for you guys. The head unit looks pretty OEM (of course, the UI is color matched to the rest of my red lighting.. family couldn't tell that it didn't come in the car stock). So far, I'm happy!
    Jan 09 2008
    Brielle, NJ
    SL33P, I looked at your pictures, which clip did you install your steering wheel adaptor wire too? I got mine the other day, and its not purple like yours, or like shown at Enfig's website, but brown. I dont think color of the wire makes a difference, but I hooked my brown steering wheel control lead (Enfig SWCL-KEN) to the brown wire coming from the plug & play device, and doesnt seem to be working.
    Also I purchased the HiLo adaptor, and Im still not getting any music in the back. Did you have to adjust any of the speaker volumn in the HiLo device?
    Christian any input would be graet too. I emailed you lastnight about my Sirius not working through my Kenwood DNN770. I purchased the following:
    Enfig PNP-KEN0016
    Enfig SWCL-KEN
    Enfig SRWH-AUD3-HILO
    Enfig RMK8-A4B67
    Also - does the top part of your instrument cluseter still work? Mine isn't... I dont care to see what song is playing. But I want to be notified if there is anything wrong with my car (ie tire pressure, service, lights out etc...). Just want to make sure these warnings till come up with the plug & plays.
    2008 - A4 Avant S-Line - Ibis White
    Tint 20%
    Jul 12 2004
    Looks good... Just so there is no misunderstanding sl33p used the enfig wiring harness but the dash kit above is not the enfig RMK8-A4B67. Our kit is seamless so the is no separate trim ring.
    Jul 12 2004
    Quote Originally Posted by Elemenohpee View Post
    Enfig PNP-KEN0016
    Enfig SWCL-KEN
    Enfig RMK8-A4B67
    The Kenwood steering wheel lead is usually blue with a yellow stripe. Verify this in your manual. The brown is usually the mute. So the brown off the kenwood SWCL-lead should go to the blue/yellow on the kenwood harness.
    If you aren't getting audio make sure the 2 blue wires on the SRWH-AUD3-HILO are connected.
    Call for help. I'm always answering calls so emails and forum posts are the last things I get to.
    This does not affect anything on the cluster. Since the factory radio is gone there is not radio display but everything else is the same...
    Oct 12 2013
    Inland Empire, CA
    This is correct! I already had this dash kit (had discovered Enfig's product line after I purchased a ton of shit.. whoops!). I would have purchased theirs, as it's rubberized and seamless, but no big deal. This works great, and looks great.
    Elemenohpee, I believe my steering wheel lead was the blue/yellow wire, not the brown. I can't remember though. It was plug and play. As far as the HiLo, no, I didn't have to do anything. Simply plugged it in, and was good to go. Ensure you have all connections clipped in firmly!
