In the next couple weeks I will be putting RS4 intercoolers and an 85mm MAF, and getting a new tune to go with it. Target is 450whp.
Old fuel pump is old and tired, and will probably struggle to keep up at that power level, so Im looking into replacing it before too long. I will replace the filter at the same time.
The question is, which pump?
-Aeromotive Stealth 340 and Deatschwerks DW300 are the Same price, Aeromotive flows a bit more but both should flow more than enough for my car. Seems like more people use the DW300, but the Aeromotive Stealth is still pretty new to the market. Both seem to be good quality.
-The stage 3 go-to back in the day was the Walbro 255, why have people moved away from this? Its cheaper than the others, and it should still be up to the task, right?
-Bosch 044 wont fit in the allroad, more expensive anyways.
Survey Says....
