Results 1 to 25 of 25
    Account Terminated Four Rings
    Oct 15 2013
    underdrive pulleys..are they worth it?
    what you say about thems?
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    From what I have research and read no. For specifics of why the answer is no do a search.
    What ever makes sense go with the opposite and you got it
    Senior Member Three Rings MedicCarter's Avatar
    Nov 26 2012
    70 Chevelle SS clone
    Sacramento
    From what I have heard is they don't give that much and if it's a DD it can cause problems with the charging system. They are more for track applications with minimal accessories but some people still like and use them on DD. That's all have heard when I asked a race shop I go to about them when looking at mods.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by esandes View Post
    Let's put it this way. You are shaving grams of weight off a 200 lb all wheel drive system.
    Not to mention introducing issues to the alternator. Can't remember who it was but they were having issues with voltage after installing the neuspeed pulley.
    Plus it's expensive. If you had custom tuning a fluidampr would be a good investment.
    Oct 15 2013
    done and done. no underdrive pulleys. i installed a set on my old mustang and they were advertising something like 8 HP gains. i never had issues with that set.
    Jun 27 2011
    In a word: No.
    The OEM Dampener cancels out a ton of vibrations. Getting rid of that effect, transmits all those vibrations through the accessory belt and will mess with all the ancillary systems on that belt (Power Steering, Alternator, etc). Its not that it will immediately cause problems, but the vibration introduced, over time, will wear out those systems sooner than normal.
    Also the gains are really not much in the scheme of things.
    A Fluidampr is, however, well worth the investment if you're running a BT or a built Head as the OEM dampener can't hold up to the higher revs.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    In a word: No.
    actually the oem dampner does just fine on bt, and keeps being a good harmonic balancer. The fluidampr just allows you to tune for more timing because it is a better balancer.
    Jun 27 2011
    When you up the revs past stock though, the dampener has proven to break on 1.8t engines. I assumed the 2.0t was the same deal.
    -CP
    2017 Q7 3.0t
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Well to be fair I don't think the average fsi by owner has even gotten to rev to 8 lol. I think one guy on the Vw forums got to 9k...haven't heard of any explosions on the oem one yet
    Senior Member Three Rings pule333's Avatar
    Jan 14 2013
    Mi4cxl
    london/UK
    I have ordered one from ECS once install it will report. But it seems only the people who never used one and only heard horror stories are against them.
    Vorsprung durch Technik
    Jun 27 2011
    True. Only the really nutty 1.8t builds truly need one. Many just use it because its a proven component and has no downside, aside from it costing $400...
    -CP
    2017 Q7 3.0t
    Oct 02 2006
    Wadsworth,OH
    FYI our crank pulley is just a light weight pulley. NOT an underdrive pulley. I'm having our product specialist change the product description. This pulley does not underdrive any of your accessories. At one point we did sell an "underdrive" pulley kit which had different size pulleys than OEM but this is the same size as an OEM crank pulley.
    Basically this is similar to a light weight flywheel. It just reduces rotational mass which will allow for better acceleration. Some engine vibrations are to be expected as you are removing the OEM dampening crank pulley.
    If any one has any other questions please let me know.
    Jason
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Jason
    How many milliseconds can we expect to shave off the 1/4 by utilizing this lightweight sucker?
    Oct 02 2006
    Wadsworth,OH
    7 exactly 7
    Jason
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    7 exactly 7
    Jason
    Jason... I'll take 2. 2 x 7 = 14... that would make my pig run a 11.3 in the 1/4. (25.3 - 14 = 11.3)
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Who needs tuning? Just get the pulley!
    Discover Your Vehicle's True Potential with JHMotorsports | Visit Us at JHMotorsports.com ๐Ÿš€๐Ÿ
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Hugh@EuropaParts View Post
    #becauseracecar
    Jason
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    7 exactly 7
    Jason
    Excellent. I am running 14.007 second quarter miles right now so this should put me in the 13's. If you're calculations are correct I should be running 13.999 second quarter miles.
    A quality improvement!
    Aug 31 2011
    Lathrop
    Do you happen to have your slips? I would love to take a look at them
    Oct 02 2006
    Wadsworth,OH
    Jason
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by pule333 View Post
    It's not even about the horror stories for me.
    It's about the concept.
    What's the product cost like $150? That's $150 going toward something ludicrous.
    Think about it, the serpentine belt pulley which is a harmonic balancer, maybe weighs 4 lbs? Give or take. Now let's say ecs was able to remove 1 pound of weight and now the new pulley only weighs 3 lbs.
    You have successfully removed 1 lb of weight from a 300lb awd system. I don't know what it actually weighs but the idea here is that you are shaving 1 lb from a 200-300 lb system so lets do the math.
    1/200= 0.5%
    1/300= 0.3%
    So under load(transmission connected to crankshaft, you might see a half percentage quicker rev, that is extremely negligible.
    Now press the clutch in and disengage the 200 lb awd system and certainly you might be able to notice a faster rev, but is it relevant? Nah you aren't moving. Might help slightly in between shifts. But if you really want to cut rotating weight, get lighter wheels, or lightweight rotors.
    However, cutting a margin of comfortability from my car for a negligible "enhancement" is not worth $150 to me, I would rather go have a good night out with some friends, or go skydiving, or <insert your favorite activity here>.
    Oct 02 2006
    Wadsworth,OH
    1/200= 0.5%
    1/300= 0.3%
    I'm not an engineer but something tells me that even though it may seam miniscule it might have a larger effect than you may think. It works the same way as a light weight flywheel. Even thought the drive train as a whole is a bunch of rotating parts, taking off any bit of rotating weight is always a good thing. Wheels, pulleys, flywheels, brake rotors, drives shafts, gears, anything that turns if it is lighter, can relieve stress on crucial components. If you want to squeeze out every OZ of acceleration you can reducing rotating weight is definitely a good start. It might not be for everyone, but it definitely will have some benefit over the factory piece. You aren't hurting anything by using it. Unless of course you feel you would rather spend the money on something else. But that's the beauty of individuality. Some might call me crazy for spending $450 on a pair of jeans when you can get them at any department store for $50, but it's my money and I am free to spend it as I wish.
    Jason
    Aug 31 2011
    Lathrop
    Expensive Jeans!
    Lightweight parts, especially ones that are moving really do help a lot.
    Aug 22 2010
    Piscataway, NJ
    I'm going to buy lightweight jeans...
    but in reality I would assume that Jason is right, I'm no rocket surgeon but it does make sense.
    Oct 02 2006
    Wadsworth,OH
    Made from Carbon fiber weave with titanium zippers and buttons.
    Jason
    ยฉ 2001-2025 Audizine, Audizine.com, and Driverzines.com
