Not really showing much, but this is the gap between the tensioner and the roller, when torqued to 33 ft/lbs
This shows the same 8mm allen that is used to torque to the roller, fits snug in the gap between the tensioner and roller once its torqued
Within a few minutes, that gap closes to about 4.5mm. Im not positive this is a result of a failing tensioner.
A friend of mine stopped by that is more mechanically inclined when it comes to engine timing and sorts. Weve turned the crank several times, going through the firing order and things of the motor, and come to a bit of conclusion the driver side cams are off a few degrees. Still working on this.
