Results 1 to 12 of 12
    Registered Member Two Rings afeezofasheezo's Avatar
    Sep 03 2004
    03 1.8TQ
    san jose, CA
    Coolant to water ratio; 50-50-, 60-40, 70-30???
    so i mixed some coolant and did about 50/50, but i think my cars running a bit hotter now...no, not cool. so whats the word on the street around here, what ratio are you running???
    Veteran Member Four Rings teutonic_blur's Avatar
    Puerto Rico
    Re: Coolant to water ratio; 50-50-, 60-40, 70-30???
    50/50.
    You didn't use regular coolant, did you?
    If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut.
    Albert Einstein
    It's not that I'm afraid to die, I just don't want to be there when it happens.
    Woody Allen
    2003 A4 1.8T FWD 5M
    Revo SPS1, K&N drop-in, NGK Coppers
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I'm at about 60/40.
    Sep 03 2004
    03 1.8TQ
    san jose, CA
    i used audi coolant which by the way for some reason costs more than bmw coolant. i think after i had already mixed it the bottle said you can use up to a max of 70/30 in our cars.
    Feb 12 2004
    Everywhere
    true, I use more coolant to water, but you're okay with 50/50.
    Registered Member Two Rings quattromadness's Avatar
    Oct 22 2004
    San Diego
    whats the best kind of coolant to use on our cars?...this 105+ degree weather in the SFV is killin' me
    Feb 12 2004
    Everywhere
    I'd just stick with OEM......get a front mount or dual side mount intercooler setup if the heat is robbing your power that much.
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    The primary purpose of Antifreeze/Coolant is to:
    1) Lubricate the waterpump and seals.
    2) Prevent freezing in cold weather (thus the name).
    In CA, you can run as much as 80%+ water, which has a lot better cooling efficiency than coolant. 50/50 is recommended for all climates, including below 0deg temps in the winter so your coolant doesnt freeze up...which you'll never see in CA. I was running 80% when up in Tahoe (it was -11deg iirc) and didn't have a problem.
    My coolant temps dropped as much as 5 degrees when warm just by increasing the water concentration.
    Feb 18 2004
    Los Angeles, CA
    OEM G12 or equivalent. If you plan on using green coolant, that is also fine, but you must completely DRAIN out your old G12 before filling...the two don't mix very well.
    Sep 03 2004
    03 1.8TQ
    san jose, CA
    oh wow, that f'er on the keyboard is insane, he freakin scares me....haha, so you say your car runs cooler with more water than cooant???a friend told me something about water being denser than coolant and being more cooling efficient, but i just cant grasp why!?!
    Feb 18 2004
    Los Angeles, CA
    Water is better because it has lower viscosity and thus makes more surface contact. This also allows it to circulate faster and pull heat away more efficiently.
    Sep 03 2004
    03 1.8TQ
    san jose, CA
    jeff my man, its good to see a real car guy on a forum! good looks on the info!!!
