Results 1 to 4 of 4
    Senior Member Three Rings fallingreason's Avatar
    Jul 07 2011
    Bicycles
    SF Bay Area
    How Long to Leave In Torn Control Arm Bushings?
    Hey AZ,
    I just got my state inspection and the only thing they found worth mentioning to me (but didn't affect my inspection) was that my front upper control arm bushings are tearing. At least 2 out of the 4 are torn.
    I am wondering how long I can let these go for? It's a big job to get in there and do that and would like to wait until I put in new suspension to replace the control arms since it will all be taken apart and realigned anyway.
    Is it critical to replace once they start to tear? Or can they go for another 5-10k miles? Less? I don't drive very hard and my car has about 89k miles on the clock.
    I have not noticed any noises and the steering does not seem sloppy to me, but I'm sure it would feel different with new front end components.
    Thanks for any input!
    2013 B8.5 Q5 2.0T
    Jun 01 2008
    Apopka, FL
    Depends on how far they're torn. If it wasn't enough to fail inspection, you can wait. Even with completely failed uppers this type of suspension geometry maintains enough angle to be able to drive the car normally.
    Jul 07 2011
    Bicycles
    SF Bay Area
    Thanks for the reply. Is it common to replace just the bushings, or do most just replace with a new control arm kit?
    2013 B8.5 Q5 2.0T
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by fallingreason View Post
    You *can* replace the bushings, but the ball joints usually warrant replacement by the time the bushings are worn. So people just buy all 8 CA's in a kit.
