Stoptech ST-60 BBK http://www.stoptech.com/Search/Produ...NA/BigBrakeKit
Performance gains: No acceleration performance but increased track performance from better and more confident braking
Cost: $3000? (I got them used so not sure)
Installation Difficulty: Fairly easy
Installation time: less than a day
The stock brakes on the S4 are actually quite decent for every day driving so this mod is more of a luxury if you're never going to track the car.
If you are going to track the car, the extra rotor size, stronger calipers, ease of swapping pads (from street to track and back) and to a certain degree, the curved vented rotor design will for sure help.
Now, I'll be outright honest and say that I haven't tracked this kit yet. I was planning to this year and even have brand spanking new track pads but
never got around to it. I hope to next year.
For street pads, I'm running Carbotech Bobcats. I started with the stoptech pads but didn't actually like them all that much and much prefer the
Bobcats. However, even those I was starting to get a little fading with hard driving in back country roads after 15 minutes of really hard driving. So in the end, the BBK is going
to be only as good as the pads you're running (and tires for braking distance). That said, you'll probably be able to last twice as long from hard
driving with this kit than on the stock setup (twice as long is a number I pulled out of my ass based on feelings, not a scientific number from actual controlled testing).
Summary: If you're never going to track the car and you don't go on extended hard driving cruises, there's no point in getting a BBK unless you want to
pay thousands for a minor weight reduction and a cool look. Also, remember that Stoptech doesn't provide a rear kit, only a front one so you will have a
disconnect between front and rear calipers from a looks perspective. From a braking perspective, Stoptech claims to take into account your stock rear
calipers. I certainly haven't felt any weird vehicle unbalancing from hard braking so it might be true.
If you are planning to track the car, it's a good option as these are considerably cheaper than official Brembos or Alcons and are 6 pistons as well. Just
remember to get a track pad set and make sure that they'll play nice with your street pads. I got the Carbotech Bobcats for street and Carbotech XP12s
for track which, according to Carbotech play well together but I still haven't tested it yet. I did ask for the XP12s to be pre-bedded though as bedding
in track pads is not easy to do on the street nor the track. Also, when installing the rotors, make sure the curved vents are placed correctly. The
vents should EXPEL air, not suck it in.
Alternative: JHM's Porsche Cayenne Brembo BBK for half the price of the Stoptechs. I hear those calipers aren't as good but they'll be better than stock.
