I have steering angle faults which i believe to be cause by my alignment being off after i lowered the car. So i did an alignment and have been trying to get the car to initialize but i have had no luck doing it with my VCDS. Below is the instructions i have followed. If anyone has any feedback as to why this is not working for me please let me know. Thanks!
ABS/EDL/ASR/ESP control unit (J104)
Steering Angle Sensor (G85)
Steering Column
There are certain test conditions that must be met before doing this procedure:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
Procedure for performing the zero position calibration for the Steering Angle Sensor (G85) on VW Passat and Audi A4/S4, A6/S6, and A8/S8:
[Select]
[03 - ABS Brakes]
[Login - 11]
Enter 40168
[Do It!]
[Basic Settings - 04]
Group 001
[Go!]
