Results 1 to 8 of 8
    Active Member Two Rings bandphreak587's Avatar
    Jul 02 2012
    2012 GMC terrain
    Crestview, Florida
    A3 Taillight halogen to LED conversion?
    Has anyone changed there halogen tail light bulbs to LED bulbs?
    Sent from my SCH-I535 using Tapatalk
    2007 Brillant Red Audi A3 2.0T
    Veteran Member Four Rings Das Ponto's Avatar
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    You mean running the facelift Tailights?
    Like this:
    Or you just referring to changing out the actual bulbs?
    Ponto
    2020 Glacier White A4 Allroad | 034 Dynamic Springs | 034 Intake | Unitronic Stage 1+ | Rotiform SGN
    2022 Daytona Grey Q7 | Quattro Magazine's Project Q7 Offroad | H&R Lift Springs | Black Rhino Volls | BFG KO2's | Rokblock Mud Flaps
    Instagram: Dasponto | Flickr
    Established Member Two Rings absolutt's Avatar
    Sep 15 2007
    '07 Audi A3 2.0T DSG 85k mi
    Weehawken, NJ
    Looks really great. But the cost for the whole kit is still really high. I was hoping it might come down a bit but it hasn't budged. LED bulbs in OEM incandescent housing always sucks. Never seen it look right. The newer bulbs with built-in resistors or VAG COM bulb-out defeat sound promising, but the issue is that the light dispersion just doesn't properly utilize the incandescent reflector.
    Current ►► 2007 A3 2.0T DSG/OS/TP/CW/CP Ocean Blue —— Previous2003 TTQR 225hp Ocean Blue
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Quote Originally Posted by absolutt View Post
    Not sure what you are getting at... but the tailights I posted are OEM... and they are only like 400 dollars for the entire set up.
    Ponto
    Jun 15 2009
    the price won't come down because that is roughly the OEM replacement cost.
    you can get the aftermarket tail lights that has the bunch of LED points of 10 yrs ago..they go for around $200.
    Sep 15 2007
    Weehawken, NJ
    Quote Originally Posted by Das Ponto View Post
    Sorry I never got back to this... got derailed. What I originally meant was LED bulbs in place of halogen rarely works well. The OEM LED light housing looks great. I've seen 2 different styles of this -- one that carries over the clear reflective slot of the reverse lights into the outer tails, called Marelli. The other does not. I'm assuming the inner housings remain the same?
    Dec 20 2012
    2022 Q7 S-line
    Edmonton, AB
    Yeah that's just the difference between north American (clear for reverse only) tailights and European (clear for reverse and amber signals)
    Sent from my igloo
    Ponto
    Sep 15 2007
    Weehawken, NJ
    I got you. I assume it's correct to say that all European tails come with rear fog light capability?
    Also, is VCDS programming a necessity to get the face-lift tails to work in 06-08 models? And is that due to the LED components (because otherwise, aren't the main bulbs halogen?).
