2007 Audi A4 2.0T
I apologize if there is a thread for this that I've missed, but I have not found a good solution in the Audi forums. A few months back I got the wastegate rattle and loss of power upon deceleration that ended up being the diverter valve. I replaced it with the new OEM one at the dealership and the power was restored and everything seemed fine again. Here recently I'm getting a rattle/scraping (High speed marbles in a tin can) sound coming from what I believe is the wastegate at around 1500-2000 RPMS. I've taken it to the dealership where they tell me the turbo is performing as it should, but there is definitely a chattering sound. In researching I found that the VW guys have a similar problem where they are attaching a clip to the actuator rod to reduce or eliminate the sound. I've attached the part and information below - The post discusses 2008-2012, but seen a lot of 2007 2.0T VWs where they had the same issue and the solution worked.
Rattling Noises from Engine Compartment Area or Exhaust System" on 2008-2012 CCTA and CBFA engines. "Test drive the vehicle to duplicate and familiarize yourself with the noise. Noise can typically be duplicated by driving up a moderate incline, beginning at 35 mph in 4th gear (manual or automatic transmission) and accelerating through the RPM range of 1800-3000 RPM under moderate to heavy throttle. Obey all local traffic laws. " The explanation for the noise is "Because of exhaust gas pulsations the wastegate flap and actuator rod vibrate at the introduction of boost pressure."
The fix has been talked about in the past. Initially VW had techs put a small wheel weight on the actuator rod to determine if the noise was from there. At that point they started working on a fix, a handful of cars had a part installed by a QTM as it was not available to order. The fix worked and now it's out and readily available, it's a simple metal clip that goes on the waste gate rod part # 06J145220A
Has anyone had this with the 07 A4 2.0t? I feel like this may be the issue, but cant find anyone with A4's to confirm.
Ryan
