Hi all,
I've been a lazy member, sorry... Obviously as soon as there is a problem I turn to the forums hoping someone might be able to help... please, some advice would really be appreciated...
Here's some background
I just did a very looong trip, 1500km (non-stop, except a refuel) on the autobahn @ speeds of about 170km/h.
This in my A4 2.0TDI (143BHP) and quite heavily loaded.
Arrived fine at my destination and have since then for 3 days been doing some 'slow city driving'
So today, suddenly the DPF icon popped up with a beep on the board computer.
I continued to drive for about 15min, then switched the engine off for a good 2h.
Starting it up again and the DPF icon is longer there, but instead the 'check engine light' has come on and will not go away.
The car is not in 'limp mode' or anything like that, it drives/pulls just normally (so far)
I have a VAG-COM tool and I will read out the fault code(s) tomorrow but I would assume it will have something to do with the DPF.
Is there any point of doing a forced regen? I would have thought that after such a long trip, the DPF would be clean as a whistle?
I have heard that there is a way to see how clogged the DPF is using VAG-COM, and also, I have heard that there is a way to check the sensors using VAG-COM, can anyone help with a procedure?
I have the CAGA engine code, and the car is a 58reg (08/2008) A4 2.0TDI Avant (143BHP) S-line.
Please help... Thanks in advance
