Results 1 to 40 of 57
    Senior Member Two Rings djsp00kyk's Avatar
    Jul 25 2009
    B9 Sq5, B7 A4, 2.5l swapped NC miata, LS swapped Jeep TJ
    Mississippi
    CVT to 6 speed manual swap
    Just starting a thread to keep people in the loop of my progress and issues with the swap. I will try to take as many pics as I can and may even do a DIY when I am finished.
    My parts list:
    FWD GVD transmission
    Complete pedal assembly
    Clutch switch
    master cylinder
    slave cylinder
    dual mass flywheel
    Luk clutch kit
    flywheel bolts
    pressure plate bolts
    JHM braided clutch line
    Shifter assembly with selector/connecting rods
    Left and right CV axles
    Vag-com cable (for possible recoding)
    I will update the list as I do the swap with whatever parts are missing. So far I have spent a little over 2k and I will add up the complete total once finished. Wish me luck!!
    Issues and discoveries:
    The manual tranny requires two longer bolts that the CVT to bolt to the block, plus a long nut bolt combo for the bottom passenger side and a "hammerhead" bolt for the driver side.
    Get a Manual STARTER as it differs from autos.
    The rear frame support is different on CVT cars than manual/quattros so either get a new support or make a new trans mount bracket as I did.
    Getting the wiper arm off is a bitch... so buy a puller or get creative!!
    Had to shim out the tranny just a hair more than the intermediate plate provided, I custom cut a spacer plate. (Didn't know it at the time but an 01E transmission ring is required which is why had the clearance issues)
    Clutch switch wire goes to PIN 41 on the larger 94 pin ecu plug. The other tapped into the second wire from the top of the brake switch harness (two wires merged into this one pin slot)
    2018 SQ5
    2012 Brilliant Red S4 DSG / Sport Diff / RS4 Grille / CF Supercharged Emblems / Resonated X-pipe, Muffler delete / epl stage1
    2006 A4 (CVT to 6 speed swap)
    Past Rides: E46 ///M3 Topaz Blue Metallic, Eclipse GS-T, Dodge Colt (4g63t)
    Senior Member Three Rings dbens's Avatar
    Jun 07 2011
    Montreal
    Awesome. Wish i had the balls to attempt something like this.... might i suggest you also do the FWD to AWD swap while youre at it? Theres a DIY on how to do it by viziers i believe.....
    2007 B7 A4 QG TI S-Line / Debadged / 35% front & 20% back tint/Evomsit stage 1 flash/ Neuspeed Springs / Emilgevor interior led kit / Hoen Xenon matched fog lights
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    If your going to convert it from cvt to 6sdd why not go the extra bit and go 6spd awd???
    Established Member Two Rings Avantageous's Avatar
    Oct 19 2011
    Dirty Glove Midwest
    I concur, 6spd and AWD!!!!!!!!!!!!!!!!!!!!
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    ya, there is pretty much no reason to go from a CVT to 6spd without also doing a FWD to AWD conversion as well.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by djsp00kyk View Post
    My parts list:
    Clutch switch
    master cylinder
    slave cylinder
    JHM SINGLE Mass Lightweight Flywheel and Clutch Combo
    Luk clutch kit
    flywheel bolts
    Fixed
    Senior Member Three Rings ultraleggera a4's Avatar
    Feb 27 2012
    Aurora, Colorado
    Nice!
    My parts list:
    Clutch switch
    master cylinder
    slave cylinder
    dual mass flywheel
    Luk clutch kit
    flywheel bolts
    I'm in the process myself of getting parts together to do a swap, keep my updated on your progress and foreseen expenses .
    239whp / 284wtq dyno proven (uncorrected)~270whp/305wtq with new goodies dyno results will be coming soon
    Stock K03
    Jun 30 2009
    Washington DC
    Just curious, but what is the price difference if you were to trade in your car for a comparable one with a manual quattro.
    Jan 27 2007
    NC
    Quote Originally Posted by pkny View Post
    For me it was cheaper to do the conversion.
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jul 25 2009
    Mississippi
    Quote Originally Posted by PDX04a4 View Post
    I had a car lined up to to just that and even bid on drakes old ride on copart but all that fell through. I need to get my car going in the next week or so, which is why I am just going for fwd at the moment. I will AWD once my motor goes and I decide what engine to use to replace it. This is just a temporary step towards AWD 2.7.... or what ever I decide, motor wise.
    Jul 25 2009
    Mississippi
    Quote Originally Posted by Jake@JHM View Post
    Fixed
    I thought about just going all out on a clutch and single mass flywheel set, but I will do that once I go AWD. I may end up ordering the shifter/linkage kit from you guys though once its all said and done.
    @pkny, I have 252k on my car so I am stuck with it, so doing a conversion will end up being cheaper as Vizi stated earlier.
    Jun 07 2011
    Montreal
    wow! how do you rack up that kind of mileage? Im pretty sure you have the highest mileage b7 on the forum..... congrats!
    Jul 25 2009
    Mississippi
    Quote Originally Posted by dbens View Post
    Haha, I drive 130 miles a day for work. The A4 has been my reliable DD for years now. I've definitely got my money's worth out of her!
    Sent from my SCH-L710 using Tapatalk 2
    2018 SQ5
    Jul 25 2009
    Mississippi
    2018 SQ5
    Jul 25 2009
    Mississippi
    Does anyone have a picture of what goes in here it appears to be a wedge of some sort but I am missing it. Can this be fabricated? I'm sure the dealer doesn't have it and I can't wait till next week.
    2018 SQ5
    Jul 25 2009
    Mississippi
    Found a metal slave cylinder locally to go with my usp clutch line.
    Here are some pics of the shift levers, it would have helped me if someone would have posted these pics somewhere, to know what I needed to buy.
    2018 SQ5
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Very fun thread. I plan on attempting this if my tiptronic ever shits out on me. I came from a 5 speed for the past 2 years to an auto.. sucks a bit.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Jul 25 2009
    Mississippi
    First hurdle. Can't seem to login based off the ross-tech site to recode the Abs module. I did get the ecu coded to manual and the cluster so I am proceeding on with abs and esp errors. If anyone has any ideas or knows what the login chart is for the b7 please chime in, I would appreciate it greatly.
    2018 SQ5
    Jul 25 2009
    Mississippi
    Audi up in the air, would be nice to have a lift right now..
    2018 SQ5
    Jul 25 2009
    Mississippi
    Just some reference pics.
    2018 SQ5
    Jul 25 2009
    Mississippi
    I can confirm now that the manual crankshaft and cvt are indeed the same. I figured the cvt would use a pilot bearing but to my surprise it didn't, made installing my new one a breeze. Also the transmission bolts are different lengths for the 6 speed, I could only reuse 2 of the of the 5 that bolt to the block, three are too short.
    Also the starter is different on the manual transmission, slipped my mind until I tried to bolt the old one on..
    OP UPDATED.
    2018 SQ5
    Jul 25 2009
    Mississippi
    So I try to start my car after the swap and the starter clicks, ok... Check and charge battery, try again, click slow dragging roll for 1/2 sec then nothing. I pull the new starter check it out and it's fine. Try again and now grinding and engine attempts to run but is drug down almost immediately! What the hell could be binding up!? Is there a spacer or thicker tranny shim plate on a manual car? Not a good day! Looks like I'm pulling the transmission to investigate...!
    2018 SQ5
    Oct 29 2005
    10speed
    San Francisco, CA
    Can you spin the motor freely by the crank bolt?
    - Clint
    Oct 29 2005
    10speed
    San Francisco, CA
    BTW, why wouldn't you go AWD when you do 6 speed? Maybe because it costs a ton more. Also, could have used a B5 A4/Passat FWD 5 speed if you were strapped for cash.
    - Clint
    Jul 25 2009
    Mississippi
    Not sure yet. I have to jack her up and start troubleshooting here in a minute.
    2018 SQ5
    Jul 25 2009
    Mississippi
    Cost and time were definitely things to consider when sourcing parts. I'm sure the 5speed would bolt up but I'm not sure they are that much cheaper, and they have a different shift lever setup than the 6speed.
    2018 SQ5
    Oct 29 2005
    10speed
    San Francisco, CA
    Well they're like $100 at the junkyard. Not sure how much you got yours for. Yes you would need different linkage. I was just saying in a pinch. You did it the right way
    - Clint
    Jul 25 2009
    Mississippi
    Damn that is cheap! I guess on a budget that would be the way to go.
    2018 SQ5
    Jul 25 2009
    Mississippi
    Well it looks like the clutch it contacting the bell housing... Just barely and just enough! Still don't understand why but at least I've found the binding problem!
    2018 SQ5
    Jul 25 2009
    Mississippi
    It looks like jumping out the neutral safety switch (blue clutch switch) is easier than I thought here is the relay to jump out. (black 395 on the left)
    Here is what it looks like jumped out
    2018 SQ5
    Jul 25 2009
    Mississippi
    To wire in the clutch switch just run a wire from pin 41 on the larger 96 pin ecu connector to the clutch switch. Then tap the other wire on the clutch switch to dual wire pin on the brake switch. I had to make a 'pull a part' run to find a small enough pin for the ecu. Luckily I found a perfect size (tiny) pin in a jetta, it was a yellow connector I'm assuming goes to the restaint system. Cruise control works and the rpms don't jump/hang as bad now when shifting, although they do seem to hang a when shifting quickly from 1st... I broke my white clutch switch, but substituted it with the blue one for now, not sure if that's the cause. I will post pics of everything when I edit them.
    2018 SQ5
    Jul 25 2009
    Mississippi
    Does anybody know what can cause "rev hang" issues. I have been trying to deal with and eliminate this issue ever since doing the swap. I have a working and functional F36 clutch switch. I have cleaned the MAF and even tried running with it unhooked. My next guess would be a new firmware flash but would an old flash cause the major hanging RPM's that cause me to wait, at least a second, in neutral between shifts just to engage the next gear?! Any input and ideas would be appreciated as I have yet to enjoy the pleasure of a real shift in the audi yet!
    2018 SQ5
    Feb 09 2014
    Trinidad and Tobago
    hey buddy did you ever fix the hang up issues? also the only wiring you will be doing when going from cvt to manual is the clutch switch reverse light and neutral safety switch?
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    [QUOTE=viziers;9170003]If your going to convert it from cvt to 6sdd why not go the extra bit and go 6spd awd???[/QUOT
    @djsp00kyk: More power I'm all for it. I think fwd GVT tranny is cool. Not as cool as awd conversation, but still cool.
    Jul 25 2009
    Mississippi
    Quote Originally Posted by Shimon View Post
    That's right those are the only things that have to be wired but the ecu, abs module and gauge cluster have to be reprogrammed. I never did get rid of the rev hang issue but I haven't been driving it for the last month or so due to the cam chain tensioner going out.
    2018 SQ5
    Jul 25 2009
    Mississippi
    [QUOTE=allstock;9956068]
    Quote Originally Posted by viziers View Post
    I agree but I was in a rush and the awd was going to take too long. If time wasn't an issue then I would have done the whole nine yards.
    2018 SQ5
    Mar 19 2014
    That's right those are the only things that have to be wired but the ecu, abs module and Guage cluster have to be reprogrammed. I never did get rid of the rev hang issue but I haven't been driving it for the last month or so due to the cam chain tensioner going out.
    So you still haven't had any assistance with reprogramming? I think there's another guy that swapped a b6 that has a write up. I wonder what would cause the rev issue. Maybe once reprogramming is done that'll fix??
    Jul 25 2009
    Mississippi
    Quote Originally Posted by allstock View Post
    I got reprogrammed but I think it's a firmware issue. I'm sure newer firmware would reduce the rev hang quite a bit, but I didn't want to take it to the dealer just for a firmware flash.
    2018 SQ5
    Mar 19 2014
    Ah okay that makes sense. Wonder how much it would be for them to reflashed if they did.
    And you got 250k out of your CVT without issue?!
    Jul 25 2009
    Mississippi
    Yea 252k but did have the TCM changed at around the 120k mark. Not sure how much they would charge to flash. I had a dude reprogram mine with Vag com but only the dealer can flash updated firmware as far as I know.
    2018 SQ5
