Results 1 to 35 of 35
    Senior Member Two Rings scottns's Avatar
    Apr 10 2008
    MA, USA
    Can Chain broke!
    2006 with about 85k on it. I was driving home the other night. Car started fine. Running normal. Then all of a sudden my dash lights all light up... EPC, battery light... Loose all power. I pull over. Car is dead. Wait for AAA to flat bed it to my mechanic. I just spoke to him and he said the cam chain broke! WTF. Has this happen to anyone else? I'm looking at a minimum of $1000+ for repairs. He said the whole head might need to be replaced. I was hoping to keep the car for another 5 years but after this I'm ready to get rid of it.... :(
    Dec 23 2011
    Ouch that sucks. There are a few threads on the cam chain. Look at the first few pages or search the forums and you'll get some good information on how to deal with it. Best of luck moving forward.
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    tensioner failed perhaps? Depending on what the damage is you don't necessarily need to replace the head.... Could just be some bent valves.
    Oct 14 2009
    Okinawa Japan
    I know that flexcj5 saw a cam chain failure and it simply needed a new chain and to be timed. (no bent valves)
    best of luck, sorry to hear about this.
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Apr 10 2008
    MA, USA
    Thanks... So I thought of this after and should have asked my mechanic while I had him on the phone... This engine has a timing belt and chains? I had the belt replaced about 10k ago. The cams are driven at the back with a chain?
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    good sir... i hath felt thy pain... in spades
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    Quote Originally Posted by scottns View Post
    Exactly. The belt drives the front cam gear which in turn drives the other from the aft end cam sprocket.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Veteran Member Three Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    Can Chain broke!
    Make sure this shop knows what they're doing. I have a motor that had a chain failure and the dealer insisted it was scrap. Guy replaced the whole motor. Once I got into it, the only damage was the chain and chain housing. Motor and head were just fine.
    If the chain popped but belt still held properly, one cam was allowed to free spool or just stopped. If you're lucky, nothing impacted the pistons so the valves would be ok. A borescope will tell you for sure.
    Silver 05 2.0t B7 REVO stage 2+ w/ ER SMICs, RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
    Aug 19 2013
    Penn's woods
    I just got an est. to do this repair and they quoted me 900-1100 bucks, I guess thats cheaper than R&R a head with bent valves.
    07 S-line TI TQM Black on Black....
    Apr 10 2008
    MA, USA
    Quote Originally Posted by Flexcj5 View Post
    Not worried. I trust these guys. They have been around for about 30 years and specialize in European cars. I've see lots of high end cars there when I've been.
    I did not hear any big crash or clunks. It just lost all power and I coasted to the side of the road. I wasn't doing more that 30-40 mph so hoping just a new chain is all that needed.
    Apr 10 2008
    MA, USA
    So I need a new head. The cam is broken... My mechanic didn't even get into the valves but suspects those are shot too. He is having a hard time finding someone to sell him a complete head ready to bolt on with all the cam chain bits in the back, etc. Any suggestions?
    Veteran Member Four Rings Firefox250's Avatar
    Nov 17 2009
    BT B7 A4 Sedan Quattro & B7 A4 Avant Titanium 2.0T Quattro
    Aurora, Colorado
    I know Shokan.com had one but it needs to go to a machine shop before you install it.
    Tuned by UNITEDMOTORSPORT
    HTA3073 Build page
    Bluewaters Performance blog on my build
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Are your cams good? I have spare valves, throw $150 my way and I will install good valves into your head, install and time the cams, install the chain, and give you a head that you can just bolt on.
    Jun 27 2011
    The cam is broken? How?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Basically you would have to buy a new head entirely. that is very expensive.
    I've got some valves you can reuse, they are all in perfect condition, they have the usual carbon buildup but if you really wanted to, I could get them jet cleaned. new intake cam is roughly $200, cam chain is roughly $50 IIRC, other than that, you need new seals, sealant for the head, new cam follower, possibly a new hpfp, new cradle bolts, and that's it. But it is still roughly a $1000 unless you find some used parts, add on labor to rebuild the head and you are close to $1,500. and then of course the labor to install the head, I believe 7 hours for removal and reinstall is book time. So $2,200 assuming you get all new parts and pay some shop to rebuild it at a very expensive rate.
    Otherwise I can help you source some used parts and do the labor for much cheaper. Send me a PM if you are interested.
    Aug 16 2011
    Cleveland, OH
    He shouldn't, when my cam follower failed the mechanic placed a call to Audi and they informed him that pre-assembled heads are kept in stock due to the high failure rates. Not cheap, but they are readily available.
    Apr 10 2008
    MA, USA
    Quote Originally Posted by ijbroussard View Post
    He's trying not to kill me on the bill which is why he didn't want to get a head from Audi. I can get a whole engine with 50k on it for $3000. Don't really want to do that either though. 3k for the engine. 2k for labor. I have 5k in a car worth 8k trade-in... Not making sense. Anyone want to buy a car :)
    Apr 10 2008
    MA, USA
    Got a call into them. thanks.
    Jun 17 2013
    jersey city nj
    2007
    Head(Cylinder)
    Audi A4 4 Cyl A 4739 $Call J.C. Recycling, Inc. USA-CT(Meriden) E-mail 1-888-247-1199 89
    2007
    Head(Cylinder)
    Volkswagen Passat 2.0L,SAME DAY SHIPPING A 1886 $Call Indoor Auto Parts USA-NY(Utica) Request_Quote 315-507-5440 Request_Insurance_Quote 177
    2007
    Head(Cylinder)
    Audi A4 2.0L,2 BENT VALVES 4479 $350 Inside Auto Parts, Inc. VARA USA-VA(Mineral) Request_Quote 1-800-469-4602 Request_Insurance_Quote
    276
    2005
    Head(Cylinder)
    Audi A4 CORE GOOD FOR PARTS $Call Best Foreign Auto Salvage USA-PA(Aliquippa) E-mail 1-800-370-6002 327
    2007
    Head(Cylinder)
    Volkswagen Eos B BAP $650 Butler Auto Parts - PRP-MA USA-NC(Forest-City) Request_Quote 1-800-835-4645 ext 200 Request_Insurance_Quote
    566
    2007
    Head(Cylinder)
    Volkswagen Golf PULL AND CHECK B BAP $650 Butler Auto Parts - PRP-MA USA-NC(Forest-City) Request_Quote 1-800-835-4645 ext 200 Request_Insurance_Quote
    566
    2005
    Head(Cylinder)
    Audi A4 2.0L 99% RESTOCKING FEE A 315005 $Call Waterloo Auto Parts, Inc. - QRP Central USA-IA(Waterloo) Request_Quote 1-800-728-5207 Request_Insurance_Quote
    947
    2006
    Head(Cylinder)
    Audi A3 ENGINE FIRE, REBUILDABLE ONLY A 9017 $650 Kelly's Auto Parts - ARAPro USA-MN(Faribault) Request_Quote 1-877-349-4947 Request_Insurance_Quote
    1007
    2006
    Head(Cylinder)
    Volkswagen Golf GTI ASSY,FOR PARTS ONLY,BAD CAMS/CAPS A M0700 $350 Pam's Auto - ARAPro USA-MN(St-Cloud) Request_Quote 1-800-560-7336 Request_Insurance_Quote
    1067
    2006
    Head(Cylinder)
    Volkswagen Passat ASSY,CORE,CAMS SCORED 5293Y $200 Dixie Auto Salvage USA-UT(Washington) Request_Quote 1-800-967-8894 Request_Insurance_Quote 2115
    2007
    Head(Cylinder)
    Audi A4 2.0L BURN STK-RKS $800 California Sports Auto Wrecking USA-CA(Chula-Vista) Request_Quote 619-656-7878 Request_Insurance_QuoteGo
    Try these good luck
    Apr 10 2008
    MA, USA
    Quote Originally Posted by vce1232000 View Post
    2007
    Head(Cylinder)
    2007
    Head(Cylinder)
    2007
    Head(Cylinder)
    276
    2005
    Head(Cylinder)
    2007
    Head(Cylinder)
    566
    2007
    Head(Cylinder)
    566
    2005
    Head(Cylinder)
    947
    2006
    Head(Cylinder)
    1007
    2006
    Head(Cylinder)
    1067
    2006
    Head(Cylinder)
    2007
    Head(Cylinder)
    Try these good luck
    Wow.. thank you!
    Apr 10 2008
    MA, USA
    Good news. Turns out the failure is from the cam follower failing. The fuel pump end got ground up and caused everything to break.... I just called my local Audi dealer and they said it should be covered so I just need to have the car moved over there. I had the follower replaced at about 42k and I have about 85k now so it didn't last very long. Amazing... The car ran 100% fine until it failed.
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    My cam Follower failed 2 times by the time I hit 120k. Second time was 15k after I replaced it the first time.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Apr 10 2008
    MA, USA
    Quote Originally Posted by schirm View Post
    Man... That's unreal. I hope to get at least another 4 years out of this. My wife's new car will be paid off and I can unload this damn thing.
    Apr 10 2008
    MA, USA
    Well this was quite the failure. I saw the parts today. The chain sprocket on one cam is broken off. The chain is broken. The follower is totally hollow. The end of the fuel pump is worn down to a nub. It's so worn that the spring behind it just fell out. Car is at the dealer now so it should be taken care of. When I get it back I'm just going to check it ever 10k from now on.
    Apr 10 2008
    MA, USA
    Dealer just called. All fixed and they covered it all. New cams, pump, follower, chain, etc. Valves were fine so the head is the same. Glad to be done with this.
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    glad to hear that.
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    This is a poorly engineered part and prone to failure.....luckily its covered.
    Give your car another chance...as you know they're sick cars.
    Learn how to check it once a year----easy DIY's all over the place.
    Apr 10 2008
    MA, USA
    I agree I should have been more pro active inspecting the follower. I had it replaced at about 45k. I thought by that logic I would go another 45k but that obviously didn't work out. I am keeping the car for now and plan to inspect the follower every 10k. In 4 more years the car will be over 10 years old so I'll want to get something newer at that point anyways. I do like the car, but after something like this happens you just get a bad taste in your mouth. You should not have to worry about catastrophic engine failures in a car at 84k, especially a higher end car like Audi. Maybe I'm expecting too much... Do the B8 have this issue at all or was the engine redesigned on those cars for the new platform?
    Nov 09 2011
    Columbus, OH
    I think I have the same issue. Glad to see yours was covered. Did you need to do any leg work or show documentation? Any other tips?
    I have my own thread.....
    http://www.audizine.com/forum/showth...ler-last-night
    Established Member Two Rings CHOLOKID's Avatar
    Dec 08 2012
    los angeles,CA
    I had a broken camshaft broke on my b7 with 83k on it I had 2 bent valves intakr side. So I had do.to my whole head. So I know that feeling :/
    Jun 27 2011
    My 2008's cam follower grenaded and destroyed my HPFP and Intake Cam at a mere 50k miles. Fun times.
    -CP
    2017 Q7 3.0t
    Jan 03 2014
    AUDI A4 2.0T 2007 & BMW 323i 2011
    Quebec
    same thing for me at 80k.
    Dec 08 2012
    los angeles,CA
    So your intake cam broke too?.
    Jun 27 2011
    Quote Originally Posted by CHOLOKID View Post
    Well the HPFP lobe was trashed. The cam is in fine shape aside from that.
    -CP
    2017 Q7 3.0t
    Jan 03 2014
    Toronto Ontario Canada
    Im sorry for your misfortune this happened to me after owning my car for 30 hrs...bought it halloween night 2013...went the following evening.
    Hope your luck was better then mine..needed to send head out to machine shop replace almost everything head wise. Did my timing belt, water pump, thermostat, all fluids flushed and changed...new cam, FP and follower etc...etc.
    Cost of all parts and labour and car gone for 2 1/2 weeks = EMPTY WALLET
    I love my car now tho...its basically new
