I turned this Valve about 90 Degrees until I felt resistance. Nothing comes out? I've search this and it sounds like some folks suspect it's because there has been stop leak in the system. I don't think the previous owner would have used stop leak in this car but I can't be 100% Is it a common problem for that valve to fail or clog? How many turns should you get out of it? My the coolant valve on my galant does 1 full turn and it's open. Obviously I can pull the temp sensor to drain the coolant too put it seems odd that the valve wont open or wont drain when it's open....
