Page 1 of 3 123 LastLast
Results 1 to 40 of 88
    Senior Member Two Rings audifella's Avatar
    Apr 16 2009
    audi tt mk2 fwd 2.0
    los angeles
    Looking for ski racks
    Guys... I've given in to being unoriginal. I saw staticuxo's car and I fell in love with his ride. I have a white 2014 b8.5, lowered on H&R OE Sports and I have 19" peelers. I would have asked staticuxo directly, but I have a 2014, and Im assuming that the styles and fitments will be different. Anyone have some suggestions? Preferably under $200, if that's even possible. If not, I'm okay with spending a little more. Also, if anyone has mounted the racks on their 8.5, please share!
    Thanks
    Veteran Member Four Rings phillips2024's Avatar
    Mar 03 2011
    Southern NH
    I have the same rack as he does. Whispbars. Hands down the best available. Then you can throw on a fatcat and be done
    The roof line should all be the same. Here is my summer setup:
    Sent from my iPod shuffle
    2017 Audi S8+ | 2021 Audi RSQ8 | 2021 Cadillac Escalade Sport Platinum | 2007 Porsche Turbo
    2021 Sea Ray 350 SLX | 2020 Polaris Ranger Crew XP1000 | 2022 Polaris Indy VR1 850/650
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    I really like the Thule Aero Blades for my B8.5, and when I decide to switch cars, all I need is new clips and fit kit, while reusing the foot packs and bars. Easier to resell as well, if needed.
    Very thick and wide rubber feet that fit perfectly to the roofline and distributes load evenly.
    Each rubber coated metal clip has a pin that aligns to the factory hole on the door sills.
    Full clearance for moonroof tilt.
    Aeroblade profile reduces need for mileage sapping fairing. It's the quietest bar I've used from Thule to date (including their OEM Audi versions)
    Mar 03 2011
    Southern NH
    Apr 16 2009
    audi tt mk2 fwd 2.0
    los angeles
    Man. the Whispbars look awesome but it says they are about $400, which seems a bit pricey. I'll have to shop around.
    Apr 16 2009
    audi tt mk2 fwd 2.0
    los angeles
    The Aero Blades are apparently called "Edges". On the website, they look a bit different than yours. But I like the estimated pricing. Could you please show us some full pics of your car? I'd like to see how the ride looks. thanks
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    Here's a video with the Aeroblades on an S4. You're going to be spending $400-500 for either whispbars or aeroblades unless you go used....
    This is a close up of my aeroblades with rockymounts euro bike cariers and yakima ski rack
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Quote Originally Posted by audifella View Post
    Edges are only for vehicles with factory roof rails (e.g. Avants) and not for the sedan. They are sometimes on sale at places such as REI with 20 percent off coupons.
    Here is a side shot:
    Veteran Member Four Rings Toecutter's Avatar
    Dec 31 2007
    Oregon
    Whispbars on mine. I doubt you'll be able to find anything at $200 unless it is either used or sketchy.
    There are suction cup mounted racks but I'm not that brave:
    http://www.amazon.com/Eton-Magnetic-.../dp/B00369LIMG
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Yeah, any decent rack unless used will be 400-500 easily. I have been hoping for a used one to come up before I buy a new one.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    whispbar FTW! i've tried other mounts, including OEM and all were noisy and sat way too high, IMHO.. which ruins aesthetics.
    with bike:
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Apr 23 2009
    Forked River nj
    ^^^ That's a sick pic.
    Past
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    Have had the same rack since my B6 and carried it through my B7 and now B8 just modifying the Q-towers each time, so it's a bit dated. If I upgrade again I'll definitely go with the Yakima Whispbars, but the Fatcats have cut the noise down quite a bit compared to my old Yakima Powder Hounds. It does sit a bit high though. Like others have said, good luck finding a decent setup for under $400:
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Sep 16 2008
    Quote Originally Posted by schirm View Post
    thanks man!
    Quote Originally Posted by b6bydesign04 View Post
    agreed. the main bars alone were ~$400.. then you add in your attachments, locks, etc. and it's easily another $350+
    PREVIOUS:
    Established Member Two Rings squashman's Avatar
    Mar 05 2006
    North of the Wall
    Quote Originally Posted by audibmi View Post
    See bold - fairings reduce mileage? I thought they improved mileage by reducing drag and also had the added benefit of reducing wind noise.
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Quote Originally Posted by squashman View Post
    The real benefit of a fairing is to reduce wind noise. Quote from clean mpg forums which best describes result of fairings on fuel savings...
    "They may improve noise by reducing turbulence, but that doesn't necessarily amount to fuel savings. The fairing adds several square feet to the frontal area of your vehicle. Increasing frontal area will increase air drag in exact proportion, since air drag equals frontal area * coefficient of drag (Cd) * the cube of speed. And the empty space behind the fairing/crossbar may very well create a vacuum that does no help to your Cd either."
    Established Member Two Rings jpbadonk's Avatar
    Feb 07 2013
    2013 x5, 1972 911, 1981 911
    I have the Whispbars and they are very quiet (have used both Thule and Yakima regular bars as a comparison). I like the pin-locator for the clamps, but the upright bike carriers I'm using (http://yakima.com/shop/bike/roof/highroller) try to pull the bars flat instead of letting them match the contour of the roof. Not an issues for skis/boards, but something I'm not happy with for the bike mount. I'm considering adding a hidden hitch (invisihitch?) and only using the rack in the winter for boards.
    '13 s4 premium plus, monsoon grey, sport diff, 19", yadda yadda yadda
    ____________________________________________
    Senior Member Four Rings riseabv's Avatar
    Sep 04 2013
    2010 Mercedes C350
    Southwest
    Where is the best place to buy whispers?8
    14 s4 glacier white | b&o | carbon atlas | h&r OE | SPC uca's | 19x9.5 Stance SC6 | Hoen fogs | 15% Pinnacle Tint | Roc-Euro | Magnaflow exhaust | Special Goodies ...
    Nov 14 2005
    Charlotte, NC
    Quote Originally Posted by riseabv View Post
    FWIW, when I was shopping for new Q-towers, I found the best prices to be on Amazon.
    -Sean
    Dec 31 2007
    Oregon
    REI. They often have a 20% off sale but even if you pay full price a $20 lifetime membership will pay for itself on your rack purchase by giving you about a 10% dividend payment.
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    Really nice Cannondale man! I was looking at the Lefty's a couple weeks ago. Sweet bikes!
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Veteran Member Three Rings NeedQuattro's Avatar
    Jan 04 2012
    Queens, NY
    After reading this thread now I ended up ordering the Whispbar S5 base racks, K390 fit kit, and WB300 snowboard carrier.
    I had the Thule Aero bars (not the blades) on my 11' STI and it looked very OEM. I bought new Thule legs to fit the S4 last season and it just sat too high for my taste. I used them for the season but knew I wanted something different, especially after seeing the whisbars on staticuxo's car.
    On a side note, I now have the Thule Aero Bars, S4 fitkit, Fairing and snowboard carrier if anyone is interested.
    Current:
    2014 Q5 3.0T, Scuba Blue, Premium Plus, MMI, B+O, S-Line, Sport package
    2012 Audi S4 - GIAC Stg2+
    2011 Subaru STI - Cobb Stg2+
    Apr 23 2009
    Forked River nj
    Quote Originally Posted by NeedQuattro View Post
    PM me with pics and price def interested.
    Past
    Registered Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    There was a set for sale in the B8A4 section but they've sold...to me
    Feb 07 2013
    Quote Originally Posted by Toecutter View Post
    +1. That's what I did.
    Apr 21 2013
    PA
    So the S5 flush kit is what you recommend over the other listings on the Yakima site ?
    http://www.yakima.com/fit/baseracks/
    Dec 31 2007
    Oregon
    Quote Originally Posted by C14 Rider View Post
    S5 for the cleanest look. S16 for more crossbar width if you expect to have a lot of carriers up top.
    Apr 21 2013
    PA
    Thank you for the quick reply, S5 it shall be..
    Aug 03 2013
    Renton, wa
    I love the look of the OEM bars however those whispbars look nice. Question for those that own them or know about them, I have my Thule accessories left over from my previous car that I use the T-bolt setup to mount. Will these accept the t-bolts or no? I can not tell from the picture it looks like they will but I want to be sure before I order some up.
    Thanks
    Edit: I found out the information, REI's website says they accept t-bolt attachemnts
    Edit Edit: Could someone that has the whispbars installed get a closeup of where the feet are installed? I like how the thule aeroblades are mounted closer to the door but the whispbars may be like this as well.
    '22 X3M - Stock...for now
    '14 S4 P+ DSG 034 Stage 2+ ECU/TCU 57.7/190, AWE Touring, MercRacing, AWE S-Flo, Stoptech STR-60 - Gone but not forgotten
    '14 A4 S-Line Sport Package 6MT - Totaled
    '12 Tiguan SEL 4MO.
    '03 Mustang Cobra "Stock"
    Oct 03 2013
    park city utah
    do you have any pics of them set up right now ?
    Senior Member Two Rings djshaunmichael's Avatar
    Mar 13 2013
    Boston
    beware I have the aerobars and after taking them off this past summer sand and salt got under all four feet in the winter and the paint was almost rubbed off completely and I really torqued them down and cleaned properly before. this year I will be using some autobahn underneath.
    2018 SQ5 Ibis White, Black Diamond Int, S Sport
    2014 SQ5, Estoril Blue
    2010 S4 Prestige ,Black/Black, Sport Dif, RS4 Front Grille, 30% Optic Tint
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    +1 For whispbars - My only complaint is the rubber feet don't look as clean as the Thules. Hate the window clips, but no choice being Audi doesn't have any factory rails or holes.
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Oct 14 2012
    Empty...for now...
    SE PA
    Semi off-topic question here: For you guys who consistently transport your skis/snowboards on roof racks, do you find signs of advanced corrosion on ski/snowboard edges and/or hardware, or any other accelerated wear? My wife refuses to use a roof rack because she thinks that our boards will take too much abuse from salt, road grime etc. mounted on the roof at 70-80 mph. I don't really have solid ground to argue against her, but I would love to get a rack so I can discontinue folding the rear seats down to fit our boards in. Plus, it kills our back seat area preventing us from taking friends along with us.
    SOLD 2015 Daytona Gray S4
    Senior Member Three Rings priceprince's Avatar
    Jul 26 2012
    Northern California
    ^ I've transported countless boards on the roof through big storms, and there is nothing that happens on the roof that your board doesn't see while you're riding it on the snow. A little bit if rust might build up on your metal edges, but that gets scraped right off when you get your board tuned anyway. Tell her not to worry about it, you're more likely to cut your interior of your S4 with the sharp edges than anything if you keep carrying your boards in the car. :)
    2010 Audi S4 Prestige / 6MT /Sport Differential / B&O
    Jan 04 2012
    Queens, NY
    Quote Originally Posted by SteveYem View Post
    Your boards/skis take a bigger beating on the slopes than from road debris. I just wipe my down when I take them off to avoid rust.
    Current:
    Oct 14 2012
    Empty...for now...
    SE PA
    Thanks for the input guys. I think her primary concern is that white crusty salt/road brine residue that gets all over the car would also get on the boards (which is not something that would occur on the mountain). To me, the solution is to quickly hose off the boards when we get home. I'll have to propose that approach again and see if I can't get her to budge.
    Mar 24 2013
    WA
    I have Thule Aero Blades with the same cross bars as audibmi and I hate them! I have hit my head on them multiple times. Unless you absolutely need the space, go with flush mounted cross bars like the pictures from Toecutter. Both Thule and Yakima offer them. BTW, I am happy to sell my Thule Aero Blades entire set at a discount.
    | 2013 S4 6MT | StopTech 380mm BBK | AWE Resonated Exhaust | Eibach Springs and Bars | Achtuning Control Arms | EuroCode ShortShifter| EuroCode Alu Kreuz | EuroCode Intake |
    VAG-COM: Driver Steering Recommendation OFF, Flashers under Braking, Comfort Close w\ Remote
    Feb 07 2012
    Quote Originally Posted by 1MORLAP View Post
    You can cut them (which I plan to eventually do) or audi0321 in the B8 A4 forum confirmed that the 47s fit even though Thule says you need the 53s. I do like the flush look of the whispbars though.
    Jan 22 2007
    NNJ
    Not an issue with a box! Yamika Skybox 16 on sale currently on backcountry.com.
    2012 Cayman S Track
    Oct 22 2009
    Massachusetts
    I have the Thule Aero Blades and cut them to 49". I agree at 53" they stuck out too much.
    '13 Monsoon, P+, 6spd MT, NAV, Sport Diff, 19" Peelers
