Results 1 to 24 of 24
    Aug 09 2011
    Brooklyn, NY
    2006 Audi A6 Adaptive Headlight Error Light
    Good Day All:
    I just copped another Audi A6. (No warranty.)
    I have the warning / error light for Adaptive Headlight Error.
    I have searched the forums.
    Some people have cleared the warning with an upgrade from the dealer.
    Others had to replace the whole unit with new motors and all.
    THe headlight has some hazing and could be refurbished. I would like to resolve this discrepancy the cheapest way possible.
    When I stand in front of the car neither the right nor the left headlights turn in the direction the steering wheel is being turned.
    I hate the warning light and would like to resolve this matter quickly and cheaply.
    Any assistance would be greatly appreciated.
    Calvin
    Senior Member Three Rings Jimingle10's Avatar
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    U might need a new light but....
    Mine don't move when car is stationary it has to be moving. Also vcds can test the full movement range. I've gotten the error when playing with vcds. I think it was from only running a partial test because it cleared after running them all
    Sent from my DROID BIONIC using Tapatalk now Free
    2014 RS7 Prestige - Suzuka Gray
    - OEM Options: Exclusive Pkg, B&O, Dynamic Pkg, Innovation Pkg, Driver Assistance, Soft Close
    - DS1 Stage 2 w/ Custom (KYLETUNEDIT), TCU Tune, Meth, E85, TGK Intake
    2012 A6 3.0T Prestige - Black
    - Jackal Stage2+ E40, 196.5mm/60mm, Merc HX
    - JHM Baffled Test Pipes w/ X pipe and HFC.
    - Westfalia Tow Hitch
    *SOLD*2012 A6 3.0T 270k mi & 2017 Q7 Prestige & 2005 A6 4.2L
    2011 Suzuki Hayabusa
    Established Member Two Rings primea6's Avatar
    Sep 17 2008
    2015 Audi A4 S-Line, Infiniti truck
    Paramus, NJ
    I would just buy a used headlight housing from ebay. I had the same problem. A used light cant be more than 200 dollars nowadays. That has to be cheaper than the dealer. I think they wanted a thousand, I lol'ed.
    2007 A6 4.2 Full S6 conversion |nav | tech |
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by Jimingle10 View Post
    My 09 a6. Adaptive headlights moves and operates when the vehicle is stationary. And in park.
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by primea6 View Post
    Have u replaced ur headlights? Should the new housing come with anything I.e motor
    May 08 2013
    2014 RS7 Dynamic
    Concord, NH
    I have the mmi update CDs if u need em
    Aug 09 2011
    Brooklyn, NY
    Hey Jimingle. How much do u want for update cd? Where are you located?
    I will try anything to clear the warning for pennies.
    Sep 27 2013
    Charlotte, NC
    Mine does that too intermittently, some nights are fine. I think mine only has a problem at a certain turning spot. Last time it did it was when I made a left going up hill.
    Does yours have an error code right away when you start the car?
    I would be interested too if you find a way to clear it or disable it.
    Nov 19 2012
    Mankato, MN
    Quote Originally Posted by SPONGE View Post
    Thats because you or someone else turned turned on "demo mode" or whatever they call it that allows it to operate the adaptive lights while parked. It's not something that comes enabled stock with the car but rather its usually enabled at showrooms to demo the functionality. It's very simple to enable/disable with a VagCom.
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by ibewess View Post
    The error comes on right away at each start up.
    Jan 03 2014
    Any resolution to this? Did updating MMI work?
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    I had the Adapted Hesdlight error and had the dealer replace both units. Problem fixed and the car looks much newer with clean headlight lenses.
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Sep 27 2013
    Charlotte, NC
    Well hooray! looks like im in the club now. My intermittent problem became permanent and is now every time I start the car
    When I get an oil change I will see if the dealer can reset or calibrate it and hopefully it will be solved.
    Oct 19 2008
    Long Island
    The car is nearly 9 years old with a 136k miles and Audi replaced one of mine under warranty so it was completely free. So at least ask if they will replace it instead of a reset. Of course my car did not look right with a new shiny unit next to the 9 year old unit so I had to replace the old one. ;)
    RIP Audis
    Jan 03 2014
    SO your car was out of warranty but they still replaced one?
    Oct 19 2008
    Long Island
    Quote Originally Posted by vert310 View Post
    That's right. I was years out of warranty. I was shocked when they said it was covered by Audi of America. Audi is a class act.
    RIP Audis
    Sep 27 2013
    Charlotte, NC
    Quote Originally Posted by Kevin1 View Post
    That's awesome i will definitely check with Audi if they can cover it! and as far as matching the lights, Im in luck because for a 9 year old car my headlights are still stock shiny.
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    This is EXTREMELY surprising. Audi is a class act, but that must have just been your dealership eating the cost. Do you regularly maintain your car with them?
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Oct 19 2008
    Long Island
    Quote Originally Posted by Klum00 View Post
    I maintain the car with them. AOA picked up the cost of the unit and the dealer picked up the labor.
    RIP Audis
    Oct 19 2008
    Long Island
    G]
    I had thought mine were still stock shiny until the new one was installed. That's when I discovered that I had been looking at my headlights through rose colored glasses. ;)
    RIP Audis
    Aug 09 2011
    Brooklyn, NY
    Update: I performed the MMI update and I still have the error.
    Apr 07 2010
    2019 A4, 2018 Subaru Outback
    Southington, CT
    The 2006 will not turn the headlights below 10 km/hr unless you put the car in showroom mode and that mode clears itself when the car is turned off.
    Aug 09 2011
    Brooklyn, NY
    Quote Originally Posted by ManyAudis View Post
    Thank you however the code still exists. :)
    Established Member Two Rings iamGHANA's Avatar
    Jun 25 2011
    2006 Audi A6 3.2L; 2003 Audi A6 3.0
    BrooklyN, NY
    Good Day All:
    Calvin
    i saw the word "copped" looked at your bio and saw your location to be Brooklyn lol
