Results 1 to 3 of 3
    Veteran Member Three Rings Koldham's Avatar
    Aug 12 2012
    Walnut Grove, Georgia
    valve cover question
    will a valve cover from a longitudinal 1.8t fit any other longitudinal 1.8t? i have a cover off a ~99 passat that i painted up very nice but it wouldn't fit all the way down and it made me mad. im pretty sure its possible but it wasn't working for me.
    1997 A4 1.8QTM AEB Pearl DD
    Deer Strikes:0 HELLASTOCK...ish WTB: pearl white body panels.
    1973 Ford Maverick Project Car(first car)
    200 I6 -> 302 V8, 3spd column shift, 8.8 with traklock. Bright Ass Orange.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    There are three different valve covers for the longitudinal 1.8T. While they all have some differences, they should all bolt up to the 1.8T head.
    The early AEB valve cover does not have the breather "hump" on the right side. It also doesn't have the mounting points for the larger engine cover that covers the fuel rail.
    By 1998 the late AEB had the breather hump added, but was not drilled through. It also does not have a "windage tray" beneath the hump that the AWM cover does.
    You can see the tray I'm talking about here.
    Lastly, the AWM cover has the hump, has a tray beneath the hump, and is drilled through for a breather connection.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    yes, all 20v 1.8t valve covers (longitudinal and transverse) will fit on all 20v heads. any combination will work. if you wouldn't fit it down, its probably cocked and you need to shimmy it on properly. but like lorge said, there are differences between covers. they will all fit, but remember the breathers are different and the coil holes are different
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
