Results 1 to 21 of 21
    Active Member One Ring Maz0106's Avatar
    Oct 08 2013
    2012 BMW 535xi, Acura TL
    New member. 2012 V8 S5 or 2014 V6?
    Thought I should see what you guys have to say before I go and purchase the car. Currently in a 2012 BMW 535 xi but need another car. I am looking at the S5 because I want a coupe but not sure which one to go with. I will end up doing performance mods for sure because the 535 is purely stock.
    Do you guys think I should go with the 2012 V8 or go for a new 2014 S5 V6
    Also manual vs auto what do you guys suggest.
    Any specific options that I should make sure are on the car if I go ahead and choose to go for the 2012 V8 S5?
    Veteran Member Four Rings Bomiz's Avatar
    May 01 2012
    You're going to get way more power out of the V6 for your buck. Plus with the 2013/2014 car you're going to get all the updated components.. Steering wheel, MMI, etc. These cars have a great auto(DSG) imo, but it's up to you whether you want a manual or not.
    2013 S4 | Monsoon Gray | Premium+ | Nav | B&O | Advanced Key | 19" | Carbon Atlas | Sports Diff | Build Thread!!
    Mods:Air 80 Tint all Around | Roc-Euro Intake | APR RSC Full Exhaust | Alu Kreuz | RS4 Grill from AMI | Miro 111 19x9.5 | Solo-Werks Coilovers | Deval Rear Carbon Fiber Diffuser | Vagcom |
    Oct 08 2013
    Quote Originally Posted by Bomiz View Post
    I used to mess around with a TL-s before. Fully Bolted and Supercharged but sucks having that much power on a front wheel drive. The 535 isn't meant to be modded really haha but just wondering whats up with the components on the S5. Like the M3 we'd change out to hi flow cats, X pipe and an exhaust to go fully bolted. Is the S5 separated into 3 sections like that. Going to do my research completely before I choose which S5. You really think id get much more power out of the 2014 V6? Im sure the other components would be more updated.
    May 01 2012
    Without a supercharger, you will get WAY more power. Just look at the stage 1 tuning difference.
    2012 S5 (v8):
    2013/2014 S5 (v6):
    Established Member Two Rings bdons's Avatar
    Oct 31 2012
    07 cayman s
    Raleigh NC
    Well with the 3.0T V6 being supercharged you will have almost another 100hp to squeeze out just with a pulley and tune. The V8 will give you maybe 20hp tips with full exhaust, tune, and intake. Also the drive select being standard on the 14 is a nice option and the mmi is a big difference IMHO. My roommate has a 07 535xi and my modded a5 will embarrass him in a straight line and takes no prisoners in the corners. A nicely modded 3.0T will be night and day to the 5 series.
    Oct 08 2013
    About how much does a tune cost on these cars
    Oct 08 2013
    Quote Originally Posted by bdons View Post
    So far most people have been telling me to go with the new V6
    Any MUST options that I should get? If i went with the prestige with 7 speed.....whats with the adaptive dampening and sports differential options
    What are the main differences between the premium plus and prestige?
    Oct 31 2012
    07 cayman s
    Raleigh NC
    P+ and prestige are packages. To know all the differences just go to audis website. It really depends on if you want good stock or great aftermarket products. I'd highly recommend a chip and pulley with full exhaust and high flows. Also look into alu kreuz and sway bars. Most importantly would be a drop and some spacers. E code headlights if you got the cash. However with any performance mods to the engine audi will void your warranty.
    Oct 08 2013
    Thanks man found the Tune info on the forum http://www.audizine.com/forum/showth...sis-ECU-is-out
    Senior Member Two Rings Mr. Three's Avatar
    Nov 27 2012
    Aptos, California
    Just got my 2014. Fantastic car. I sell Audis for a living so I know and drive all of them. The V-8 S5 is a nice car but is not as sharp as the later Supercharged cars. You buy that car for the lesser price and the sound of the engine. Even the automatic in the older V8 cars is the boring Tiptronic auto 6 speed. The 2013 and up cars get the double clutch S-Tronic transmission which is miles better for performance applications. Spend about 1800 bucks on the new V6 car and you go from about 340 hp to over 400 horsepower plus.
    2023 S3 Daytona PP, S Sport, EMD Springs, EMD 10mm, 034 insert
    Cars of the past: 83 A1 GTI / 83 Callaway stage 2 A1 GTI / 86 951 Turbo Porsche Autothority K-27 / 98 Dinan M3 / 95 3.2 OBD1 M3 / 02 E39 M5 / 88 E28 528i / 08 RS4 / 13 S5 / 14 S5 / 15 S5 GIAC Stage 2 / 16 APR tuned S6 /
    01 996 911 Turbo ByDesign Stage 4 / 2018 S4 DT Tuning and EMD suspension / 2019 Etron Quattro / 21 S4 DT Tuning EMD susp /
    Oct 08 2013
    Quote Originally Posted by Mr. Three View Post
    yeah was just doing my research. Only $1800 and those are SIGNIFICANT gains. 2014 seems to be the much better price. Around how much did the car cost you out the door
    Nov 27 2012
    Aptos, California
    Depending on options, figure about 62K plus about 10% for taxes and fees (at least in California.)
    Veteran Member Three Rings bkkchris's Avatar
    Dec 05 2006
    Los Angeles & Bangkok
    Def a 13/14 in my opinion, the V8 was nice, and sounded amazing, but the supercharged V6 is pretty fantastic and much more perf upgrade options.
    2018 RS5 COUPE // SONOMA GREEN
    - Gone -
    2017 TT Mythos
    2017 Macan GTS Rhodium
    2014 S5 Monsoon
    2013 S4 Phantom
    2012 S4 Monsoon
    2008 S4 Dolphin
    2006 S4 Moonlight
    2004 A4 Dolphin
    Sep 30 2009
    b
    The V6T is an amazing engine. Could not recommend the v8.
    Nov 27 2012
    Aptos, California
    Plus, if I understand the data right, the V8s are far more prone to carbon buildup.
    Jul 03 2013
    New York
    2011 S4 with the 3.0t threw a CEL at 36K miles. Carbon buildup...
    All the direct injection engines are prone to the carbon buildup, especially with lots of steady highway driving.
    Audi told me to drive it like i stole it once a month to lessen the build up.
    They cover the carbon build up for 10 years now tho.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Quote Originally Posted by Maz0106 View Post
    +1 for V6
    $2300 outdoor price if you go with APR Stage 2+ (software+pulley kit+labor+tax)
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Feb 04 2010
    Ottawa, Canada
    2012 S5 with APR Stage 3 supercharger :)
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance w/AWE SwitchPath, CETE Lowering Mod, 034 Sways, etc
    Oct 08 2013
    Quote Originally Posted by Runge View Post
    haha
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    Not exactly, only the emission controls is extended, a flapper valve in the PCV system as I recall. Cleaning intake valves is under normal warranty and then only with a CEL on.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Established Member Two Rings Fallen33's Avatar
    Oct 13 2013
    South Jersey
    V6 is better on gas, takes better to mods (if you're into that), and has blower whine. The V8 sounds epic, but drinks gas, drinks oil, doesn't get much gains with mods, and weighs more.
    I love my V8 S5, but a part of me wishes I had the s/c V6.
    2013 Audi S4: Sold.
    2011 Audi S4: Sepang Blue, Sold.
    2008 Audi S5: Sold.
