Results 1 to 22 of 22
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Best coil for high boost AMB engine?
    What version of the new style coil is best for a high boost AMB engine?
    Part number/suffix?
    Best source?
    Stock coils have 110k miles, and I am experiencing misfires at 20+ psi on at least one coil (colder NGK BKR7E plugs with 0.030 gap).
    Edit: My 2003 B6 has the 06A 905 115 D coils
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Revision "D".
    People will tell you to get FSI Coils, but those WILL crack and you will be back in the same boat you are in now.
    Dec 25 2004
    Earth
    Quote Originally Posted by EErie B6 View Post
    Revision "D".
    To date none of my TFSI coils have ever cracked.
    While I have seen post here about the issue on certain TFSI coils...there are those TFSI coils that do not crack.
    Feb 20 2010
    Brighton, MI
    status of roughly 2/2011.
    06A 905 115 A. Dropped on 01/11/2006. Use 06B 905 115 R as a replacement.
    06A 905 115 B. Dropped on 01/11/2006. Use 06B 905 115 R as a replacement.
    06A 905 115 C. Dropped on 01/08/2007. Use 06B 905 115 R as a replacement.
    06A 905 115 D.
    06B 905 115. Dropped on 01/02/2000. Use 06B 905 115 E as a replacement.
    06B 905 115 B. Dropped on 01/02/2000. Use 06B 905 115 E as a replacement.
    06B 905 115 D. Dropped on 01/08/2000. Use 06B 905 115 R as a replacement.
    06B 905 115 E.
    06B 905 115 G. Dropped on 01/11/2001. Use 06B 905 115 R as a replacement.
    06B 905 115 H. Dropped on 01/10/2002. Use 06B 905 115 R as a replacement.
    06B 905 115 J. Dropped on 01/08/2003. Use 06B 905 115 R as a replacement.
    06B 905 115 L. Dropped on 01/03/2006. Use 06B 905 115 R as a replacement.
    06B 905 115 M. Dropped on 01/10/2004. Use 06B 905 115 R as a replacement.
    06B 905 115 N. Dropped on 01/06/2006. Use 06B 905 115 R as a replacement.
    06B 905 115 P. Dropped on 01/06/2006. Use 06B 905 115 R as a replacement.
    06B 905 115 Q. Dropped on 01/06/2006. Use 06B 905 115 R as a replacement.
    06B 905 115 R.
    06C 905 115 A. Dropped on 01/10/2001. Use 06C 905 115 L as a replacement.
    06C 905 115 B. Dropped on 01/10/2002. Use 06C 905 115 L as a replacement.
    06C 905 115 C. Dropped on 01/10/2001. Use 06C 905 115 L as a replacement.
    06C 905 115 D. Dropped on 01/12/2002. Use 06C 905 115 L as a replacement.
    06C 905 115 E. Dropped on 01/07/2003. Use 06C 905 115 L as a replacement.
    06C 905 115 F. Dropped on 01/12/2004. Use 06C 905 115 L as a replacement.
    06C 905 115 G. Dropped on 01/11/2004. Use 06C 905 115 L as a replacement.
    06C 905 115 H. Dropped on 01/06/2006. Use 06C 905 115 L as a replacement.
    06C 905 115 J. Dropped on 01/04/2005 without replacement.
    06C 905 115 K. Dropped on 01/06/2006. Use 06C 905 115 L as a replacement.
    06C 905 115 L.
    • 06C905115M latest?
    05 Golf TDI
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Revision "D".
    The TFSI coils that come from a Mk VII GTI (with the long plastic cover) seems to crack on some people, but I've found the red FSI coils that come from the B8 A4 2.0T have been very reliable (no plastic cover to crack). Provides a smoother idle and smoother overall operation as it goes through the RPM range. Very happy customer with these.
    TFSI coil part number: 06E905115E
    Site: http://www.europaparts.com/ignition-...6e905115e.html
    If you go with TFSI coils, get the appropriate spark plugs to take advanatage of the hotter spark. NGK BKR7E-11 (copper) or NGK BRR7EIX-11 (iridium) offer the larger gap.
    USP CLUB MEMBER #34
    Dec 25 2004
    Earth
    Quote Originally Posted by vtraudt View Post
    06A 905 115 D.
    06B 905 115 E.
    06B 905 115 R.
    06C 905 115 L.
    Its 2013....
    On 8/2013 I installed 06e905115e with NGK Iridiums.
    So far the 06e905115e offer the best seat of the pants performance in my 1.8t.
    As Erie mantioned certain part number TFSI coils have been known to crack...
    You should search the 06C905115M part number here and see if those are them.
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    May 30 2008
    Honda HRX
    Penna.
    Quote Originally Posted by MikTip View Post
    Quote Originally Posted by CyberPMG View Post
    Good to know guys. I bought mine when the spacers were first introduced, i picked the model I did b/c that is what was recommended at the time and was also thought to be the most powerful OE version out there. Mine never saw the car with out spacers, i had the plugs gapped at .040, i noticed no performance change, and they still cracked. (Lots of speculation about the cause of the cracking at the time)... My plan was to run them till the car actually started missing, then to pitch them and go back to my "D" models.
    May 11 2008
    Columbus, OH
    My idle smoothed out and the car runs really well with these coils and the proper plugs pregapped to the spec for the coil. I have a motoza tune and no issues.
    Feb 20 2010
    Brighton, MI
    Its 2013....
    Those are the (black, Hitachi?) bolt downs, correct?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    [B]
    To find those is my intention.
    - non cracking
    - strongest spark (unless all those 'new' coils are electrically the same).
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    ==> My 2003 B6 has the 06A 905 115 D
    ==> for my high boost engine, I normally use copper (better heat dissipation) and 1 step colder NGK BKR7E, but still have to run nowhere near the 0.040 gap some suggest. ).030 max. Haven't tried the BKR7EIX to tell if they can handle 20+ psi.
    05 Golf TDI
    May 30 2008
    Honda HRX
    Penna.
    My claims that idle/performance/etc did not change was new revision Ds with new plugs gapped at .028 vs new MK6s with new plugs gapped at .040.
    You guys that saw a difference, were you comparing an old setup w/ old plugs to a new mk6 setup w/ new plugs? If this is the case then you should very much see a difference. If it was new vs new like I did, then I guess I did not get the same result. Which is about par for the course.
    Dec 25 2004
    Earth
    No
    They are red non bolt down.
    You can google the part number.....
    Dec 19 2007
    York, PA
    Revision "D".
    mine still arent cracked...and ive had them in there since the spacers made by issam, all around great upgrade. im using the 7e11's i believe.
    May 30 2008
    Honda HRX
    Penna.
    FR5DTC plugs were hands down the best plugs I tried. They are copper and about 1.5 steps colder than stock. I was able to get a hair more timing (2 or so degrees it seemed) out of them vs BKR7EIX plugs.
    From what I read somewhere along the way, the NGK "IX" plugs are about half a step warmer than their copper brothers due to the fine-wire tip. So a "7" IX would be something like a "6.5" Copper. If i was to try iridiums again, I would probably look for an BKR8EIX. (If they exist)
    Feb 17 2004
    Liberty Hill, TX
    06E-905-115-E + NGK BKR7EIX-11
    I've run the BKR8EIX as well, which are not available in a -11 variant (1.1mm / .044" gap), and they did not perform as well as the 7EIX-11
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    May 30 2008
    Honda HRX
    Penna.
    Quote Originally Posted by n7plus1 View Post
    Go knock on wood, quick! Lol.
    Mine were from Issam's thread too. I didn't drive my car much so it took longer for mine to crack, but like so many others, they eventually did. I know Dan's did too, and he also gave up and went back to traditionals. I used to give him hell about it... Then one day *womp*womp* mine did the same. (IIRC he did not feel a change in performance either)
    Not trying to actually deter anyone, just sharing my experiences.
    Feb 23 2004
    Stow, OH
    I'm running 26 psi with these plugs. I have the spacers that Issam first offered. I used to run the copper plugs (BRK7E-11), but decided to try the iridium plugs. They've done great for a full year. I plan on sticking with these plugs and will replace every 30k miles instead of every 5k miles with the copper versions.
    USP CLUB MEMBER #34
    Feb 23 2004
    Stow, OH
    The FSI ignition coils in question that had cracking issues:
    Part# 06H 905 115
    The FSI ignition coil that is now recommended:
    Part# 06E 905 115E
    USP CLUB MEMBER #34
    May 30 2008
    Honda HRX
    Penna.
    ^ got it. That was the problem then. Mine were "H"es.
    Good to know a reliable CP was found. If I still owned the car I'd probably give them a whirl.
    ...all water under the bridge now.
