so I have oil on 2 of my ignition coils. and its a decent amount Its enough oil to bring a drip of oil out with the coils when you pull them out. did some research and of course found out that this is a sign of a leaking valve cover gasket. I would assume the center part of the gasket that go around the spark plugs would be leaking. so I did my cct and halfmoon plug, and did new valve cover gasket. before I put the ignition coils back in, I cleaned them off. gave it about a week, pulled the 2 ignition coils and they still have oil on them. so my question is, when I change the valve cover gasket, should they not be getting oil on them anymore, or is that like oil that sitting in there when it was leaking. .
